    Can't find point view c4
    19 Posts 3 Posters 12.7k Views 1 Watching
      What kind of machine is that running on? The charts take forever to render. How many samples are being plotted on your charts?
      I know where in the code the "can't find point view" message is displayed, but without being able to reproduce the problem, it is not possible to diagnose. Can you post an export of the view?
      Re the ???, i don't see any of those either. I've attached an updated jar file that will provide more information on the issue. Note that your current version of Mango may not work with this version, so make sure you save the old one just in case. You should now see "(99:xx)" before the last "???", where the "xx" is the language it is trying to look up. Post the entire message that you see - everything between the "???" delimiters - back here.
        sprokkie
        Its running on a Nagasaki MS2100.
        I have 9 one wire device's attached to it.
        The charts are really slow i know, it takes a lot of patients.
        that is why i was looking for a way to publish it on internet without the a connection to the pc
        the question marks are here
        How do i use jar the file ?
          300MHz CPU. Yeah, that would do it. Unfortunately, the host with the data is the host that will generate the content. To paraphrase Ron Schneider, you're going to need a bigger box.
          Replace the existing seroUtils.jar file in WEB-INF/lib with the attached and restart.
            sprokkie
            I replaced the file
            now i onlysee the logobuildingblocks
            no temperature's and no tekst.
            so i cannot see the language before the ??
            the ms2100 performs wel for sunnydatacontrol and logtemp.
            I thought mango was not that a heavy program for the ms2100
            i use it because of the low powerconsumtion only 9W
              Do you see any error messages in the console?
              The Mango runtime is very light, but view generation not as much so. In particular the generation of charts - especially if you are plotting, say, thousands of point values - takes effort. Try removing the charts or restricting the number of values to plot.
                sprokkie
                i have no console.
                  When you start Mango you see a list of messages like the following:
                  Feb 19, 2010 9:01:57 PM org.apache.catalina.core.AprLifecycleListener init
                  INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not fou
                  nd on the java.library.path: C:\Program Files\Java\jdk1.6.0_14\bin;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WIND
                  OWS;E:\Program Files\PHP\;E:\Program Files\PHP\ext;C:\Program Files\Java\jdk1.6.0_14\bin;C:\WINDOWS\system32;C:\WINDOWS;
                  C:\WINDOWS\System32\Wbem;C:\Program Files\Intel\DMIX;C:\JavaApis\apache-ant-1.7.0\bin;C:\Program Files\Common Files\GTK\
                  2.0\bin;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Common Files\DivX Shared\;C:\WINDOWS\syst
                  em32\WindowsPowerShell\v1.0;C:\Program Files\QuickTime\QTSystem\
                  Feb 19, 2010 9:01:57 PM org.apache.coyote.http11.Http11Protocol init
                  INFO: Initializing Coyote HTTP/1.1 on http-8080
                  Feb 19, 2010 9:01:57 PM org.apache.catalina.startup.Catalina load
                  INFO: Initialization processed in 1910 ms
                  Feb 19, 2010 9:01:58 PM org.apache.catalina.core.StandardService start
                  INFO: Starting service Catalina
                  Feb 19, 2010 9:01:58 PM org.apache.catalina.core.StandardEngine start
                  INFO: Starting Servlet Engine: Apache Tomcat/6.0.20
                  That's your console. Everyone has it.
                    sprokkie
                    When i start mango, i click the icon in the systray and then ckick start
                    The mango wil startup automaticaly in the background.
                    tomcat runs as a service.
                    ill gues there is some kind of logfile somewhere
                    tell me what log you need
                      Andras
                      Sprokkie,
                      I live in NL like you. My browser (like yours probably) has NL set as default language. If you change the default language to EN/US, the ???? will disappear and the proper text will appear in it's place (I tried it with your solar boiler site and it worked).
                      Luckily for you, I have made an NL I18n translation so you get NL text in your NL browser and you don't have to change the language settings. It will probably ship with the next version of Mango.
                        sprokkie
                        Hi Andres,
                        can you send me the file ?
                          I can confirm that it will indeed ship with the next version.
                            sprokkie
                            That's great.
                              Andras
                              You can get it here:
                              http://www.tucsni.nl/mango/mango-i18n-nl.zip
