    Bind a point value directly to a slider
    3 Posts 2 Posters 2.3k Views 2 Watching
    • J Offline
      jmln5000
      How would you bind a data point directly to a slider component without using the dropdown in the examples? I would like to use a slider similar to the way you can use a set point value component in dashboard designer just by giving it the point name.
      for example: set point value component works great just giving it point="(point's XID)" but slider is looking for ng-model="myPoint.valueFn". how would I define myPoint as a point that I have created in data sources.
      • Will GellerW Offline
        Will Geller
        I believe doing this is partially demonstrated in this example page:
        http://localhost:8080/ui/examples/setting-point-values/sliders
        but it sounds like you want to hard code a data point rather then using a dropdown to select one, so you would use <ma-get-point-value> rather then <ma-point-list>. I updated the example to show you how to do so:
        <div layout="column">
            <h2>Hard Coded Point Slider</h2>
            <ma-get-point-value point="myPoint" point-xid="Demo 01-setpoint"></ma-get-point-value>
            <md-slider ng-disabled="!myPoint.enabled" md-discrete step="1" min="0" max="100" ng-model="myPoint.valueFn" ng-model-options="{getterSetter:true}">
            </md-slider>
        </div>
        <md-slider-container ng-disabled="!myPoint.enabled">
            <md-input-container>
                <input flex step="1" min="0" max="100" type="number" ng-model="myPoint.valueFn" ng-model-options="{getterSetter:true}">
            </md-input-container>
            <md-slider step="1" min="0" max="100" md-discrete ng-model="myPoint.valueFn" ng-model-options="{getterSetter:true}" md-vertical></md-slider>
            <h5>Value: {{myPoint.value}}</h5>
        </md-slider-container>
        Just update the point-xid attribute to match that of your point
        • J Offline
          jmln5000
          That's what I needed. Thank you so much!
