    Mango box crash
    20 Posts 3 Posters 8.0k Views 3 Watching
      Mircea
      Hi ,
      I have this error from mango box.
      Do you now way?
      Thanks.
      Mircea
      FATAL 2017-04-19 18:13:47,375 (com.serotonin.m2m2.util.timeout.RejectedHighPriorityTaskEventGenerator.rejected:47) - High priority task: com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager$PointDataCleaner rejected because Task Currently Running
      WARN 2017-04-19 18:13:47,375 (com.serotonin.m2m2.rt.dataSource.PollingDataSource.incrementUnsuccessfulPolls:107) - Data Source MangoES System aborted 1 polls since it started.
        Hi Mircea,
        What's your Point clean interval (ms) from the NoSQL section of the system settings?
        If there's only one of these I wouldn't worry about it. It shouldn't be logged at the FATAL level as the task will be rescheduled and carry on.
          Mircea
          Hi Phil,
          After the above message mango stop.
          Here is what I have for point clean interval.
          0_1492797400081_upload-0119578b-cbcc-4ff8-8027-2ed250e88ad7
          Here I put the log file too.
          [0_1492798979097_ma (1).log](Uploading 100%)
          [0_1492799016072_ma (1).log](Uploading 100%)
          Mircea
            I think 1000 for the point clean interval may be too fast. The default is 60000. This setting is probably the cause of that message.
              Mircea
              Hi Phil,
              Since i changed the point clean interval I get no record or update.
              0_1492808939581_upload-ee985988-cbe7-41e0-b2dc-510e3416b8d7
                Hi Mircea,
                That's really bizarre. I'll look into that, but the easy/fast resolution to that is probably to restart Mango.
                  Do point values report being logged on the internal metrics page? Did you get any errors when updating the settings? What version of Mango and Mango NoSQL is this?
                    Mircea
                    Hi Phil,
                    I don't know where I can find that info.
                    No
                    0_1492810231654_upload-ee798035-ab76-4fda-92af-b7ff5dcb3417
                    0_1492810267337_upload-4844e7ad-e3e1-425d-8528-b5b7c1eb66ed
                    I can give you access to mongo at 2222 port if you need.
                    Thansk
                    Mircea
                      That shouldn't be needed. I would advise updating the MangoNoSql module
                        Mircea
                        I get this when I try to check for updates
                        0_1492810700112_upload-f195c978-aaf4-4108-b71f-6773e8429619
                          If you check Mango/logs/ma.log I'm sure it's an UnknownHostException (ok, relatively sure) and the gateway or DNS settings may need adjustment.
                            Mircea
                            Hi Phil,
                            I updated mango with the latest MangoNoSql.
                            There are at least 2 variable that mango don't pull them.
                            0_1493033081706_upload-9ecfff6f-81ab-488e-b1b0-6b47af39121c
                            The read and blue lines are the 2 variable that with out reason stop recording.
                            The green and yellow are the same temperature but offset ( after a heat exchanger).
                            Zone 1 is previous updating mango.
                            Zone 2 when the sensor record on change ( not on time every 3 minute) .
                            Zone 3 after a wile the data base don`t record red line.
                            [0_1493033224309_ma_new.log](Uploading 100%)
                            I also attached the log file.
                            Mircea
                              Mircea
                              Hi Phill,
                              One more think. I found that if i stop and start that data base for that point the point start to be recorded for a wile but after stop to record. The period after which stop recording is sometime one hour sometime 10 hours.
                              0_1493038659340_upload-48ac4aa2-3f3d-456e-8bfa-aac90ba46ba9
                                Hi Mircea,
                                it looks like the log file didn't get uploaded quite right.
                                It looks like you're using BACnet, based on the port of that point. Is the point a COV subscription point, or regular polling?
                                  mihairosu
                                  I haven't had time to investigate any deeper and build up a case, but I also have trouble with BACnet subscription.
                                  The first time the BACnet data source is activated, the subscription works fine, but it does not renew.
                                  My current workaround is to poll every 10 sec, but I'd like to get that resolved as well at some point.
                                    Mircea
                                    Hi Phil,
                                    This is one point.
                                    0_1493052470532_upload-23f3d9fc-0694-4624-bbcd-a24aefc38ace
                                    And this is the second with the same problem.
                                    0_1493052537602_upload-66b87b0d-ed20-474e-9493-4d2db856e64f
                                      Mircea
                                      More info
                                      0_1493052811644_upload-65edb8ee-304b-45f1-9dbd-0614447ae64b
                                        Hmm.
                                        With regards to the OP, I am wondering if the lack of data getting polled is what is referred to in the title as crashing (I wouldn't think so).
                                        I know Matthew, Mango and BACnet4J's original author, has been doing work on BACnet4J to bring it up to date with some new specifications and to fix some bugs. That's the version that will be in Mango 3's initial release. I believe he's finished, so I'll try to take some time tomorrow to produce a 2.8 version of that code, and I can pass it along to you two if you'd like to test it out.
                                          mihairosu
                                          I'll wait for Mango 3. I don't have the time to devote to this at the moment, so it won't be worth your time.
                                            That may be for the best. When I started looking into doing this today I noticed the new BACnet4J was written using Java 8, while the 2.8.x series is limited to requiring Java 7.
                                            Also, you might be interested in checking out https://store.infiniteautomation.com/core
                                            But we'll have more announcements today.
