    Chinese brand PSU_monitoring rs485 and Mango
    63 Posts 3 Posters 119.7k Views 4 Watching
    • H Offline
      hengst
      little update ,
      i found that i need to convert in javascript the with sort of
      function hex2float(num) {
      var sign = (num & 0x80000000) ? -1 : 1;
      var exponent = ((num >> 23) & 0xff) - 127;
      var mantissa = 1 + ((num & 0x7fffff) / 0x7fffff);
      return sign * mantissa * Math.pow(2, exponent);
      window.alert (hex2float("0xA4703942"));
      //flipped does the trick
      window.alert (hex2float("0x423970A4"));
      // outcome 46,36..... ( not rounded )
      so little progress here.
      • H Offline
        hengst
        Perfectum Resultativum ;
        0_1478170444805_upload-5743d503-afdb-46f8-8648-2edc42e2fdcc
        • H Offline
          hengst
          now put all this in Mango needs again some pointers i think..
          • H Offline
            hengst
            i got this in " point links as script " , is this ok ?
            0_1478275755900_upload-2b88dd9b-44ca-49ba-82c2-ab67bf96dfa0
            and what to put in :
            the script - source script. ?
            i tried 1000 different combinations. and reading the wiki / manuals. but sorry, i don't
            get it...
              Looking at your message queue, there are no identifiers. I assume this is because this is always for the same point. You could connect the point link to a point directly representing that value, if there is only one point's value in a message. Otherwise, you'll want some identifiers so that your script can parse the message queue and set points identified by the identifier to the value. I would have the identifiers in an object, where the object looks something like...
              { "identifier1" : p334, .....}
              Where p334 is the variable name for the context point of the script.
              • H Offline
                hengst
                identifiers, object etc, is probably JavaScript terms....hmm and i was thinking it was almost done, gehehe.
                i need a neighbor with programming skills ( the neighbors house is for sale btw )
                so back to learning books ..
                  Ha! Well, we'll see how the politics here go ;)
                  Identifier is just a name that you can use in both places. Object is a JavaScript term for things defined as { "key": value }. Other names are Map and Dictionary.
                  • H Offline
                    hengst
                    ok learned "Object"
                    Can someone point me some explanation links about :
                    var identifierMap = { "messageIdentifier" : contextPoint1 ....  }
                    cant find much on " indentifierMap " on internet somehow.
                      That's just a variable name, so that later in the script you can type
                      var ident = "messageIdentifier";
                      identifierMap[ ident ].set( /*your value here*/ );
                      Where context points are added to the script through the UI of the Scripting data source.
                      • H Offline
                        hengst
                        "messageIdentiefier" is the variable/object coming from point link script right ?
                          Yeah. It looks like right now you're setting message queue to something like
                          49.73;49.73;49.73;
                          The identifier would be useful if you have multiple values to get out of a message. You explicitly know their positions when you extract the values, so you can give them something you can identify them with. So instead your message queue may look like,
                          busVoltage-49.73;busVoltage-49.73;busVoltage-49.73;otherValue-106.2;yetAnotherValue-78.1;
                          such that you could identify where to set those values out to in the script.
                          • H Offline
                            hengst
                            this is what i got,
                            0_1478292636682_upload-dbe30c51-4e24-4816-b5c5-ae67b8d033fc
                            and point link details :
                            0_1478292718157_upload-66e0378e-4c51-419e-81e5-ae06d0dbb617
                              I would then modify the
                              return target.value + result + ";" ;
                              to
                              return target.value + "busvolt-" + result + ";" ;
                              But I think you will want to support multiple data extractions from the same message, like,
                              return target.value + "busvolt-" + result + ";otherMeasuredValue-" + result2 ;
                              Also, you may have to have call parseFloat, like so:
                              identifierMap[ messageInfo[0] ].set( parseFloat( messageInfo[1] ));
                              • H Offline
                                hengst
                                Well, looks something is working :
                                0_1478299096889_upload-f087c10f-9c3c-4807-abed-a0e87d2523ed
                                i ques this is normal ?
                                • H Offline
                                  hengst
                                  Alright. made some changes as, reading where not what the should be. now i get the right results from reading the Hex.
                                  Script "message Queue"
                                  // get Hex from source
                                  var busVoltage = /[0-9A-Fa-f]{30}([0-9A-Fa-f]{16}).*/.exec(source.value);
                                  var extractedValue = busVoltage[1];
                                  var PsuLoad = /[0-9A-Fa-f]{78}([0-9A-Fa-f]{16}).*/.exec(source.value);
                                  var extractedValue = PsuLoad[1];
                                  // Alarm relays Bit ( 1 is Alarm )
                                  var Alarm = /[0-9A-Fa-f]{185}([0-9A-Fa-f]{1}).*/.exec(source.value);
                                  var extractedValue = Alarm[1];
                                  // door alarm Bit (1 is Door open )
                                  var DoorAlarm = /[0-9A-Fa-f]{185}([0-9A-Fa-f]{1}).*/.exec(source.value);
                                  var extractedValue = DoorAlarm[1];
                                  var message = busVoltage[1];
                                  function toASCII(message) {
                                    var result = "";
                                    while(message.length > 1) { //parse two characters at a time
                                       var charCode = message.substr(0, 2);
                                       result += String.fromCharCode( "0x" + charCode );
                                       message = message.substr(2);
                                    return result;
                                  // swap bytes /hex
                                  function swap32(val) {
                                  return ((val & 0xFF) << 24)
                                         | ((val & 0xFF00) << 8)
                                         | ((val >> 8) & 0xFF00)
                                         | ((val >> 24) & 0xFF);
                                  //print (message);
                                  function roundToTwo(num) {
                                      return +(Math.round(num + "e+2")  + "e-2");
                                  // covert Hex to String
                                  var subresult = (toASCII(message));
                                  // create human readabe number
                                  var result = (roundToTwo(hex2float("0x" +subresult)));
                                  // send payload
                                  return target.value + "MainAlarm-" + Alarm[1] + ";" + "Door-" + DoorAlarm[1] + ";" + "busvolt-" + result + ";" ;
                                  at this point i get as result : MainAlarm-0;Door-0;busvolt-53.68;
                                  thats correct.
                                  so i have right input , further i am still completely lost in how i should proceed.
                                  i added my other (modbus) device and thats straight forward , enter the source and add data points to it. thats easy.
                                  now why cant i see the logic for the other source..
                                  • H Offline
                                    hengst
                                    Did made some progress, via an other approach ;
                                    Created : tcp/ip source ( 2 sec update period )
                                    Created : Data Point to that :
                                         "loggingType":"NONE",
                                         "dataType":"ALPHANUMERIC",
                                         "queryable":true,
                                          "readCommand":"<your_hex_request_for_your_device>",
                                          "settable":false,
                                          "valueIndex":0,
                                          "valueRegex":".*",
                                    Created META-source
                                         "name":"DoorAlarm",
                                         "enabled":true,
                                         "updateContext":true,
                                         "varName":"p110"
                                    added in script field :
                                    var DoorAlarm = /[0-9A-Fa-f]{185}([0-9A-Fa-f]{1}).*/.exec(p110.value);
                                    // payload
                                    return "DoorAlarm- " + DoorAlarm[1];
                                    So i added some other "Meta-data points" for other values.
                                    This works ok, and i can understand how it works.
                                    Now the first approach has probably benefits in setting up many same kind devices/values i guess , so i am focusing on that as well , as i would like to understand how that should work.
                                      The first approach's benefit is just somewhat more efficiently extract many points' values from a single message. You can still do that with meta points, where the incoming message provides a context update to all the meta points. Also, you can return the DoorAlarm[1] in the meta point if the meta point is Numeric and it will be treated as a Numeric. The "DoorAlarm" string portion is just to identify the point in the object (map, dictionary) in the script, where the value portion would be set out to data points created on the scripting data source. Those points on the scripting data source would ultimately be used for displays or dashboards.
                                      • H Offline
                                        hengst
                                        Thanks Phil(lips) , i am going to play with it , little stupid off topic question :
                                        "How to purge all Information on "Urgent events" or "information " . seems there is no option/knob when viewing the list. ( clear dates , seem to do nothing when selected periode )
                                          Events can be purged from the system settings page, as well as setting a system policy for purging old events, and you can set the data source's event levels to DO_NOT_LOG if you expect it to generate a lot of events on the data source's edit page.
                                          I am not sure what you're refering to as 'clear dates' so I may not have understood exactly correct. Events on the events page (/events.shtm) get 'Acknowledged' to clear them from a user's view in the header. Actual deleting is handled by the purge settings in the system settings page, under "Purge settings"
                                          • H Offline
                                            hengst
                                            i was refering to this :
                                            0_1478634603932_upload-0ef18116-152a-4813-84f0-59d3cf60c4e5
