    Chinese brand PSU_monitoring rs485 and Mango
    63 Posts 3 Posters 126.6k Views 4 Watching
    • H Offline
      hengst
      That fixed it indeed.
      i noticed i can check scripting code by clicking on the "little green Script dot".
      Its still not clear to me.
      • Data source collects makes connection to device. ( interval for set here )
        that is the easy part,
      • tcp/ip Data point asks for data ( command data point )
      • tcp/ip Data point response listen for data
      • tcp/ip Data point "link" this to Scripting data point, "message queue" datapoint.
      • in the "link" script screen i put in ?? which pieces of code ?
      • in the Script Data source i also put in which pieces ?
      i tried a lot of combinations, but i don t see it.
        Response --> Point Link to parse values --> Scripting Data Source to process message queue into points' values
        • H Offline
          hengst
          Alright i got it. thnx.
          i had little play with :
          var busVoltage = /[0-9A-Fa-f]{46}([0-9A-Fa-f]{8}).*/.exec(source.value);
          var extractedValue = busVoltage[1];
          print (busVoltage[1]);
          Script result:
          42453939
          so that works, i found code for converting the hex to float, but no knowledge of writing (java) coding structure is a show stopper at the moment. but i do have fun learning , gehehe
            Nice!
            All the scripts use JavaScript.
            • H Offline
              hengst
              little update ,
              i found that i need to convert in javascript the with sort of
              function hex2float(num) {
              var sign = (num & 0x80000000) ? -1 : 1;
              var exponent = ((num >> 23) & 0xff) - 127;
              var mantissa = 1 + ((num & 0x7fffff) / 0x7fffff);
              return sign * mantissa * Math.pow(2, exponent);
              window.alert (hex2float("0xA4703942"));
              //flipped does the trick
              window.alert (hex2float("0x423970A4"));
              // outcome 46,36..... ( not rounded )
              so little progress here.
              • H Offline
                hengst
                Perfectum Resultativum ;
                0_1478170444805_upload-5743d503-afdb-46f8-8648-2edc42e2fdcc
                • H Offline
                  hengst
                  now put all this in Mango needs again some pointers i think..
                  • H Offline
                    hengst
                    i got this in " point links as script " , is this ok ?
                    0_1478275755900_upload-2b88dd9b-44ca-49ba-82c2-ab67bf96dfa0
                    and what to put in :
                    the script - source script. ?
                    i tried 1000 different combinations. and reading the wiki / manuals. but sorry, i don't
                    get it...
                      Looking at your message queue, there are no identifiers. I assume this is because this is always for the same point. You could connect the point link to a point directly representing that value, if there is only one point's value in a message. Otherwise, you'll want some identifiers so that your script can parse the message queue and set points identified by the identifier to the value. I would have the identifiers in an object, where the object looks something like...
                      { "identifier1" : p334, .....}
                      Where p334 is the variable name for the context point of the script.
                      • H Offline
                        hengst
                        identifiers, object etc, is probably JavaScript terms....hmm and i was thinking it was almost done, gehehe.
                        i need a neighbor with programming skills ( the neighbors house is for sale btw )
                        so back to learning books ..
                          Ha! Well, we'll see how the politics here go ;)
                          Identifier is just a name that you can use in both places. Object is a JavaScript term for things defined as { "key": value }. Other names are Map and Dictionary.
                          • H Offline
                            hengst
                            ok learned "Object"
                            Can someone point me some explanation links about :
                            var identifierMap = { "messageIdentifier" : contextPoint1 ....  }
                            cant find much on " indentifierMap " on internet somehow.
                              That's just a variable name, so that later in the script you can type
                              var ident = "messageIdentifier";
                              identifierMap[ ident ].set( /*your value here*/ );
                              Where context points are added to the script through the UI of the Scripting data source.
                              • H Offline
                                hengst
                                "messageIdentiefier" is the variable/object coming from point link script right ?
                                  Yeah. It looks like right now you're setting message queue to something like
                                  49.73;49.73;49.73;
                                  The identifier would be useful if you have multiple values to get out of a message. You explicitly know their positions when you extract the values, so you can give them something you can identify them with. So instead your message queue may look like,
                                  busVoltage-49.73;busVoltage-49.73;busVoltage-49.73;otherValue-106.2;yetAnotherValue-78.1;
                                  such that you could identify where to set those values out to in the script.
                                  • H Offline
                                    hengst
                                    this is what i got,
                                    0_1478292636682_upload-dbe30c51-4e24-4816-b5c5-ae67b8d033fc
                                    and point link details :
                                    0_1478292718157_upload-66e0378e-4c51-419e-81e5-ae06d0dbb617
                                      I would then modify the
                                      return target.value + result + ";" ;
                                      to
                                      return target.value + "busvolt-" + result + ";" ;
                                      But I think you will want to support multiple data extractions from the same message, like,
                                      return target.value + "busvolt-" + result + ";otherMeasuredValue-" + result2 ;
                                      Also, you may have to have call parseFloat, like so:
                                      identifierMap[ messageInfo[0] ].set( parseFloat( messageInfo[1] ));
                                      • H Offline
                                        hengst
                                        Well, looks something is working :
                                        0_1478299096889_upload-f087c10f-9c3c-4807-abed-a0e87d2523ed
                                        i ques this is normal ?
                                        • H Offline
                                          hengst
                                          Alright. made some changes as, reading where not what the should be. now i get the right results from reading the Hex.
                                          Script "message Queue"
                                          // get Hex from source
                                          var busVoltage = /[0-9A-Fa-f]{30}([0-9A-Fa-f]{16}).*/.exec(source.value);
                                          var PsuLoad = /[0-9A-Fa-f]{78}([0-9A-Fa-f]{16}).*/.exec(source.value);
                                          var extractedValue = PsuLoad[1];
                                          // Alarm relays Bit ( 1 is Alarm )
                                          var Alarm = /[0-9A-Fa-f]{185}([0-9A-Fa-f]{1}).*/.exec(source.value);
                                          var extractedValue = Alarm[1];
                                          // door alarm Bit (1 is Door open )
                                          var DoorAlarm = /[0-9A-Fa-f]{185}([0-9A-Fa-f]{1}).*/.exec(source.value);
                                          var extractedValue = DoorAlarm[1];
                                          var message = busVoltage[1];
                                          function toASCII(message) {
                                            var result = "";
                                            while(message.length > 1) { //parse two characters at a time
                                               var charCode = message.substr(0, 2);
                                               result += String.fromCharCode( "0x" + charCode );
                                               message = message.substr(2);
                                            return result;
                                          // swap bytes /hex
                                          function swap32(val) {
                                          return ((val & 0xFF) << 24)
                                                 | ((val & 0xFF00) << 8)
                                                 | ((val >> 8) & 0xFF00)
                                                 | ((val >> 24) & 0xFF);
                                          //print (message);
                                          function roundToTwo(num) {
                                              return +(Math.round(num + "e+2")  + "e-2");
                                          // covert Hex to String
                                          var subresult = (toASCII(message));
                                          // create human readabe number
                                          var result = (roundToTwo(hex2float("0x" +subresult)));
                                          // send payload
                                          return target.value + "MainAlarm-" + Alarm[1] + ";" + "Door-" + DoorAlarm[1] + ";" + "busvolt-" + result + ";" ;
                                          at this point i get as result : MainAlarm-0;Door-0;busvolt-53.68;
                                          thats correct.
                                          so i have right input , further i am still completely lost in how i should proceed.
                                          i added my other (modbus) device and thats straight forward , enter the source and add data points to it. thats easy.
                                          now why cant i see the logic for the other source..
                                          • H Offline
                                            hengst
                                            Did made some progress, via an other approach ;
                                            Created : tcp/ip source ( 2 sec update period )
                                            Created : Data Point to that :
                                                 "loggingType":"NONE",
                                                 "dataType":"ALPHANUMERIC",
                                                 "queryable":true,
                                                  "readCommand":"<your_hex_request_for_your_device>",
                                                  "settable":false,
                                                  "valueIndex":0,
                                                  "valueRegex":".*",
                                            Created META-source
                                                 "name":"DoorAlarm",
                                                 "enabled":true,
                                                 "updateContext":true,
                                                 "varName":"p110"
                                            added in script field :
                                            var DoorAlarm = /[0-9A-Fa-f]{185}([0-9A-Fa-f]{1}).*/.exec(p110.value);
                                            // payload
                                            return "DoorAlarm- " + DoorAlarm[1];
                                            So i added some other "Meta-data points" for other values.
                                            This works ok, and i can understand how it works.
                                            Now the first approach has probably benefits in setting up many same kind devices/values i guess , so i am focusing on that as well , as i would like to understand how that should work.
