    Chinese brand PSU_monitoring rs485 and Mango
    63 Posts 3 Posters 124.1k Views 4 Watching
      I mentioned how to fix that, you would turn your timeout down from 50000 ms to less than your polling interval, so less than 5000.
      • H Offline
        hengst
        That fixed it indeed.
        i noticed i can check scripting code by clicking on the "little green Script dot".
        Its still not clear to me.
        • Data source collects makes connection to device. ( interval for set here )
          that is the easy part,
        • tcp/ip Data point asks for data ( command data point )
        • tcp/ip Data point response listen for data
        • tcp/ip Data point "link" this to Scripting data point, "message queue" datapoint.
        • in the "link" script screen i put in ?? which pieces of code ?
        • in the Script Data source i also put in which pieces ?
        i tried a lot of combinations, but i don t see it.
          Response --> Point Link to parse values --> Scripting Data Source to process message queue into points' values
          • H Offline
            hengst
            Alright i got it. thnx.
            i had little play with :
            var busVoltage = /[0-9A-Fa-f]{46}([0-9A-Fa-f]{8}).*/.exec(source.value);
            var extractedValue = busVoltage[1];
            print (busVoltage[1]);
            Script result:
            42453939
            so that works, i found code for converting the hex to float, but no knowledge of writing (java) coding structure is a show stopper at the moment. but i do have fun learning , gehehe
              Nice!
              All the scripts use JavaScript.
              • H Offline
                hengst
                little update ,
                i found that i need to convert in javascript the with sort of
                function hex2float(num) {
                var sign = (num & 0x80000000) ? -1 : 1;
                var exponent = ((num >> 23) & 0xff) - 127;
                var mantissa = 1 + ((num & 0x7fffff) / 0x7fffff);
                return sign * mantissa * Math.pow(2, exponent);
                window.alert (hex2float("0xA4703942"));
                //flipped does the trick
                window.alert (hex2float("0x423970A4"));
                // outcome 46,36..... ( not rounded )
                so little progress here.
                • H Offline
                  hengst
                  Perfectum Resultativum ;
                  0_1478170444805_upload-5743d503-afdb-46f8-8648-2edc42e2fdcc
                  • H Offline
                    hengst
                    now put all this in Mango needs again some pointers i think..
                    • H Offline
                      hengst
                      i got this in " point links as script " , is this ok ?
                      0_1478275755900_upload-2b88dd9b-44ca-49ba-82c2-ab67bf96dfa0
                      and what to put in :
                      the script - source script. ?
                      i tried 1000 different combinations. and reading the wiki / manuals. but sorry, i don't
                      get it...
                        Looking at your message queue, there are no identifiers. I assume this is because this is always for the same point. You could connect the point link to a point directly representing that value, if there is only one point's value in a message. Otherwise, you'll want some identifiers so that your script can parse the message queue and set points identified by the identifier to the value. I would have the identifiers in an object, where the object looks something like...
                        { "identifier1" : p334, .....}
                        Where p334 is the variable name for the context point of the script.
                        • H Offline
                          hengst
                          identifiers, object etc, is probably JavaScript terms....hmm and i was thinking it was almost done, gehehe.
                          i need a neighbor with programming skills ( the neighbors house is for sale btw )
                          so back to learning books ..
                            Ha! Well, we'll see how the politics here go ;)
                            Identifier is just a name that you can use in both places. Object is a JavaScript term for things defined as { "key": value }. Other names are Map and Dictionary.
                            • H Offline
                              hengst
                              ok learned "Object"
                              Can someone point me some explanation links about :
                              var identifierMap = { "messageIdentifier" : contextPoint1 ....  }
                              cant find much on " indentifierMap " on internet somehow.
                                That's just a variable name, so that later in the script you can type
                                var ident = "messageIdentifier";
                                identifierMap[ ident ].set( /*your value here*/ );
                                Where context points are added to the script through the UI of the Scripting data source.
                                • H Offline
                                  hengst
                                  "messageIdentiefier" is the variable/object coming from point link script right ?
                                    Yeah. It looks like right now you're setting message queue to something like
                                    49.73;49.73;49.73;
                                    The identifier would be useful if you have multiple values to get out of a message. You explicitly know their positions when you extract the values, so you can give them something you can identify them with. So instead your message queue may look like,
                                    busVoltage-49.73;busVoltage-49.73;busVoltage-49.73;otherValue-106.2;yetAnotherValue-78.1;
                                    such that you could identify where to set those values out to in the script.
                                    • H Offline
                                      hengst
                                      this is what i got,
                                      0_1478292636682_upload-dbe30c51-4e24-4816-b5c5-ae67b8d033fc
                                      and point link details :
                                      0_1478292718157_upload-66e0378e-4c51-419e-81e5-ae06d0dbb617
                                        I would then modify the
                                        return target.value + result + ";" ;
                                        to
                                        return target.value + "busvolt-" + result + ";" ;
                                        But I think you will want to support multiple data extractions from the same message, like,
                                        return target.value + "busvolt-" + result + ";otherMeasuredValue-" + result2 ;
                                        Also, you may have to have call parseFloat, like so:
                                        identifierMap[ messageInfo[0] ].set( parseFloat( messageInfo[1] ));
                                        • H Offline
                                          hengst
                                          Well, looks something is working :
                                          0_1478299096889_upload-f087c10f-9c3c-4807-abed-a0e87d2523ed
                                          i ques this is normal ?
                                          • H Offline
                                            hengst
                                            Alright. made some changes as, reading where not what the should be. now i get the right results from reading the Hex.
                                            Script "message Queue"
                                            // get Hex from source
                                            var busVoltage = /[0-9A-Fa-f]{30}([0-9A-Fa-f]{16}).*/.exec(source.value);
                                            var PsuLoad = /[0-9A-Fa-f]{78}([0-9A-Fa-f]{16}).*/.exec(source.value);
                                            var extractedValue = PsuLoad[1];
                                            // Alarm relays Bit ( 1 is Alarm )
                                            var Alarm = /[0-9A-Fa-f]{185}([0-9A-Fa-f]{1}).*/.exec(source.value);
                                            var extractedValue = Alarm[1];
                                            // door alarm Bit (1 is Door open )
                                            var DoorAlarm = /[0-9A-Fa-f]{185}([0-9A-Fa-f]{1}).*/.exec(source.value);
                                            var extractedValue = DoorAlarm[1];
                                            var message = busVoltage[1];
                                            function toASCII(message) {
                                              var result = "";
                                              while(message.length > 1) { //parse two characters at a time
                                                 var charCode = message.substr(0, 2);
                                                 result += String.fromCharCode( "0x" + charCode );
                                                 message = message.substr(2);
                                              return result;
                                            // swap bytes /hex
                                            function swap32(val) {
                                            return ((val & 0xFF) << 24)
                                                   | ((val & 0xFF00) << 8)
                                                   | ((val >> 8) & 0xFF00)
                                                   | ((val >> 24) & 0xFF);
                                            //print (message);
                                            function roundToTwo(num) {
                                                return +(Math.round(num + "e+2")  + "e-2");
                                            // covert Hex to String
                                            var subresult = (toASCII(message));
                                            // create human readabe number
                                            var result = (roundToTwo(hex2float("0x" +subresult)));
                                            // send payload
                                            return target.value + "MainAlarm-" + Alarm[1] + ";" + "Door-" + DoorAlarm[1] + ";" + "busvolt-" + result + ";" ;
                                            at this point i get as result : MainAlarm-0;Door-0;busvolt-53.68;
                                            thats correct.
                                            so i have right input , further i am still completely lost in how i should proceed.
                                            i added my other (modbus) device and thats straight forward , enter the source and add data points to it. thats easy.
                                            now why cant i see the logic for the other source..
