    High CPU usage
    32 Posts 4 Posters 46.4k Views 3 Watching
      I agree, you shouldn't need to dedicate the server. I would expect using the MAPPED_BYTE_BUFFER to provide the most substantial benefit. You would need to restart after changing that. We should be doing a release this week that will include a new version of the NoSQL module that may help as well.
      • B Offline
        btrombo
        I changed to MAPPED_BYTE_BUFFER and also tried the 200 and 50 settings. The 50 setting has no change that I could notice but changing it to 200 had even higher CPU usage. I put it at 500 and looks reasonable now. The core is no longer pinned and looks like the major issue has been resolved.
          Great! Thanks for your patience through the investigation and glad to hear it!
          • C Offline
            craig
            what is the takeaway from this issue?
            On unix OS with a read heavy query load and lots of bacnet data sources use db.shardStreamType=MAPPED_BYTE_BUFFER and increase the "Batch write behind spawn threshold" to 500 and "Max batch write behind tasks" to 50?
              Hi Craig, I would consider the following the things to take away:
              On *nix operating systems MAPPED_BYTE_BUFFER is the fastest stream, but does not currently work on Windows. INPUT_STREAM is likely still the fastest option for Windows.
              Having write behind instances between 2 and 8 is most efficient for most users, with 2-3 (active, not maximum) probably being best, but 1 being totally sufficient in a system not under heavy load. But, you can experiment with this through the spawn threshold setting very easily.
              Meta points will expand their caches to requests for fixed numbers of values but not for time ranges, so if you're being weighted down by Meta points you can convert something like p.pointValuesSince( now - oneMinute ); into p.last(30); //knowing it's a 2 second poll and see performance improvments.
              • B Offline
                btrombo
                Well this problem has come back, all the changes we did before are still in place so I'm guessing those changes just helped the root cause be less of an issue or another issue has come up maybe just all the restarts during the last debugging helped. All cores are pinned this time.
                0_1483469260587_upload-ba7b39ae-2044-489b-b680-a7979fba96b4
                  Hi btrombo,
                  There is a new version of the database our that does some more efficient batch processing. I would consider updating to get that version. We have an instance running on this latest version and it's been intaking 300,000 values/s for months. This takes the shape of new Mango NoSQL system settings.
                  We could also try to troubleshoot it through the same steps again (getting thread dumps) but I would speculate it's a combination of meta points putting a heavy query load and something else.
                  • B Offline
                    btrombo
                    A restart fixed the issue, it looks like the issue takes some time to come back or maybe some task we do causes the issue to come back but here is a CPU non kernal over 4 weeks. The drops are all manual restarts. We will try to upgrade again today, the last try failed so we rolled back.
                    0_1483554948162_upload-6432a910-8f9a-43e1-968f-ff0a4a611424
                      Can you post a graph of your memory usage over the same time period?
                      • B Offline
                        btrombo
                        Basically 0 swap over the timeframe.
                        Virtual Memory Used
                        0_1483556698222_upload-b766f83e-eab8-44ba-b7b7-c7fb31f9e4d6
                        Idle Memory
                        0_1483556730579_upload-e50e4dfa-5b0b-43cb-a5a0-604e50c35cd9
                        Cache
                        0_1483556790369_upload-2b960cfd-bec7-4e37-add7-31203d2f1781
                          You could experiment with using the concurrent garbage collector instead of the parallel garbage collector. There is the script Mango/bin/ext-available/concurrent-garbage-collector.sh to be placed in Mango/bin/ext-enabled/ if you're on Linux or Mac. GC tuning can take some effort, and it helps to log the output as well to know the effects changes have.
                          Another suggestion may be to encourage you to play with it and give us more information to work with.
                          • B Offline
                            btrombo
                            We did get the upgrade to work today so we will let that sit as is for a while before I start changing things again. We do get a few of these now:
                            High priority task: com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager$PointDataCleaner was rejected because it is already running.
                            0_1483647051378_upload-6d19dbf0-b286-4052-8954-4c8b2b3dcf50
