    Error while installing Mango Automation
    2 Posts 2 Posters 2.4k Views 1 Watching
    • J Offline
      Jonatas
      Hi, i need some help to install mango on Armbian (debian 8 based) system. Some information:
      root@orangepiplus2:/opt/mango# java -version
      java version "1.7.0_95"
      OpenJDK Runtime Environment (IcedTea 2.6.4) (7u95-2.6.4-1~deb8u1)
      OpenJDK Zero VM (build 24.95-b01, mixed mode)
      root@orangepiplus2:/opt/mango# javac -version
      javac 1.8.0_72-internal
      Tomcat 8 is installed, but when i access http://localhost:8080 then i get the message "It Works" from tomcat7.
      Only apt-get remove, and install not solved the problem.
      And the error by start of mango:
      INFO  2016-05-10 08:34:48,551 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'http', v1.5.2 by Infinite Automation Systems Inc.
      INFO  2016-05-10 08:34:48,578 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'dnp3', v1.6.1 by Infinite Automation Systems Inc.
      ERROR 2016-05-10 08:34:53,405 (com.serotonin.m2m2.Main.main:120) - Error during initialization
      java.lang.RuntimeException: java.net.BindException: Address already in use
      	at com.serotonin.m2m2.Lifecycle.webServerInitialize(Lifecycle.java:802)
      	at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:216)
      	at com.serotonin.m2m2.Main.main(Main.java:116)
      Caused by: java.net.BindException: Address already in use
      	at sun.nio.ch.Net.bind0(Native Method)
      	at sun.nio.ch.Net.bind(Net.java:463)
      	at sun.nio.ch.Net.bind(Net.java:455)
      	at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
      	at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
      	at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:321)
      	at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80)
      	at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:236)
      	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
      	at org.eclipse.jetty.server.Server.doStart(Server.java:366)
      	at com.serotonin.m2m2.Lifecycle.webServerInitialize(Lifecycle.java:799)
      	... 2 more
      INFO  2016-05-10 08:34:53,419 (com.serotonin.m2m2.Lifecycle.terminate:344) - Mango Lifecycle terminating...
      ERROR 2016-05-10 08:34:53,444 (com.serotonin.m2m2.Lifecycle.terminate:418) - com.serotonin.provider.InputStreamEPollProvider
      ERROR 2016-05-10 08:34:53,448 (com.serotonin.m2m2.Lifecycle.terminate:426) - com.serotonin.provider.ProcessEPollProvider
      INFO  2016-05-10 08:34:53,449 (com.serotonin.m2m2.Lifecycle.terminate:446) - Mango Lifecycle terminated.
      INFO  2016-05-10 08:34:53,452 (com.serotonin.m2m2.Lifecycle.terminate:344) - Mango Lifecycle terminating...
      ma-start: no restart flag found, not restarting MA
      ma-start: MA done
        Mango does not require tomcat. Please see our installation documentation here: https://help.infiniteautomation.com/support/solutions/folders/14000092094
        Mango also uses port 8080 by default so there is a conflict with tomcat. You can either shut down tomcat or change Mango to run on a different port in the env.properties file:https://help.infiniteautomation.com/support/solutions/articles/14000020052-installation-configuration
        Hope that helps.
