    Http retriever and cookies
    7 Posts 2 Posters 4.2k Views 1 Watching
    • D Offline
      djbakerman
      Hello -
      Any way to pass post variables and/or cookie information for the http retriever data source?
      From the command line using curl, the string would look something like this:
      curl -b "device-id=anonymous" http://webserver.web.com/~abspath/%23ac-c1a-01?as=action-set&oldlocation=7
      Regards,
      Daniel
        No, POST parameters are not currently supported. But since you already have GET parameters in the url, can you not just say:
        http://webserver.web.com/~abspath/%23ac-c1a-01?as=action-set&oldlocation=7&device-id=anonymous
        • D Offline
          djbakerman
          The webserver is looking for a cookie, apparently that's how the server authenticates. Using the -b with curl sets the cookie variables, but passing the same variable as a get does not seem to work.
          Is there a place in source code to modify the retriever?
          Is there a place in data source to run a script every x minutes? I could easily write a perl script or shell script to run the curl and parse the results as an output.
            I see.
            Mango doesn't do scripts because it is meant to be O/S agnostic. Ok, yeah, there is a vmstat data source, so that ideal has been blown. I guess it should be easy enough to create a new data source that can initiate a process and then handle the results.
            • D Offline
              djbakerman
              I can write this, as I need it, and pass it back to you. I'll take a look at the vmstat and see how that goes.
              -Daniel
              • D Offline
                djbakerman
                I ended up using net-snmp locally on the box, and passing an exec command. Then via mango, use SNMP data source to query the values. An expensive hack, but works fine on a small scale.
                -Dan
