    Text renderer properties bug?
    3 Posts 2 Posters 1.5k Views 1 Watching
    • sjobbeS Offline
      sjobbe
      Hello
      After adding "0.00" to Format under "Text Render Properties" I started getting this error:
      ERROR 2014-09-26 08:32:29,909 (com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter:38) - DWR invocation exception
      java.lang.NullPointerException
              at com.serotonin.m2m2.web.dwr.DataSourceEditDwr.getPoints(DataSourceEditDwr.java:87)
              at com.serotonin.m2m2.web.dwr.DataSourceEditDwr.validatePoint(DataSourceEditDwr.java:209)
              at com.serotonin.m2m2.web.dwr.DataSourceEditDwr.validatePoint(DataSourceEditDwr.java:145)
              at com.serotonin.m2m2.modbus.dwr.ModbusEditDwr.saveModbusPointLocator(ModbusEditDwr.java:73)
              at sun.reflect.GeneratedMethodAccessor211.invoke(Unknown Source)
              at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
              at java.lang.reflect.Method.invoke(Method.java:606)
              at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34)
              at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428)
              at com.serotonin.m2m2.web.dwr.util.TranslationsFilter.doFilter(TranslationsFilter.java:37)
              at com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter(ExceptionDetectionFilter.java:26)
              at com.serotonin.m2m2.web.dwr.util.DwrPermissionFilter.doFilter(DwrPermissionFilter.java:38)
              at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431)
              at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283)
              at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52)
              at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101)
              at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146)
              at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
              at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
              at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:538)
              at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1352)
              at org.eclipse.jetty.servlets.UserAgentFilter.doFilter(UserAgentFilter.java:77)
              at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:141)
              at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1323)
              at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:476)
              at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)
              at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:517)
              at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:225)
              at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:937)
              at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:406)
              at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:183)
              at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:871)
              at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
              at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:110)
              at org.eclipse.jetty.server.Server.handle(Server.java:346)
              at org.eclipse.jetty.server.HttpConnection.handleRequest(HttpConnection.java:589)
              at org.eclipse.jetty.server.HttpConnection$RequestHandler.content(HttpConnection.java:1065)
              at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:823)
              at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:214)
              at org.eclipse.jetty.server.HttpConnection.handle(HttpConnection.java:411)
              at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:535)
              at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:40)
              at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:529)
      Could this be caused by the difference how the Americas and Europe use dot and comma? Normally the OS expects comma (,) and not dot (.) when in Europe. (Example: 6,45 kW and not 6.45kW)
      Also the Unit in "Unit properties" does not recognize Wh (kWh) or VA (kVA). I find that odd since both are regularly used when measuring electricity.
      • jeremyhJ Offline
        jeremyh
        You can enter kW/h (with a slash). For kVA I usually leave the unit blank then set the unit suffix manually in the text renderer properties.
