    How to write code when get first value will be stop recevied the second value in meta ?
    6 Posts 2 Posters 1.9k Views 1 Watching
    • E Offline
      edmond
      Morning.everyone.
      Now I use mango received the data from equipment .and I set a meta point.the code as below,the datapoint in meta named p1.When I get the first value>2.0,I donot received the second value>2.only get first value>2 will go to end.How to write .thanks.
      if (p1.value>2.0)
      return p1.value;}
      else {
      return (NaN) ;
      • E Offline
        edmond
        No answer? :(
        • E Offline
          edmond
          have not answer?
          why for this question for so long time and no any answer?
            Rather than return NaN return my.value which will just returns it's current value.
            • E Offline
              edmond
              Thanks,Joels.
              In meta if I have 15 value,(I have set cron in the meta),from the 15th value start ,when 15th.value>2,then end.no need to continute 14th value. if 15th<2, then 14th value to compare with 2.if 14th.value>2 ,then end . if 14th.value<2, then 13th will compare with 2. if every value all 15 is less than 2.then will undisplay vlaue. this is my script. Is it right? Need your modify.
              var n=1
              switch (n)
              case 1:
              if (p15.value>2.0)
              { return p15.value;}
              break;
              case 2:
              if (p15.lastValue(1)>2.0)
              return p1.lastValue(1);
              break;
              case 3:
              if (p15.lastValue(2)>2.0)
              return p1.lastValue(2);
              break;
              case 4:
              if (p15.lastValue(3)>2.0)
              return p1.lastValue(3);
              break;
              case15
              if if (p15.lastValue(15)>2.0)
              break;
              return (NaN);
