Navigation
    • Search
    MA-START
    Mango Automation Installation
    2
    3
    2639
    • B
      b3charlie last edited by
      Hey Joel,
      What causes dos to open and then close when trying to boot up in ma-start ?
      Do i need to modify something in java?
      Thanks, Charlie :oops:
      • JoelHaggar
        JoelHaggar last edited by
        It means there is an error in the start up process. Could be a port conflict, cant' find your JAVA_HOME environmental variable or a database connection issue.
        If you open the terminal from the start menu: search for CMD on the start menu > right click and run as administrator.
        Then CD <your mango install folder> now you can type ma-start.bat and if it errors it won't close so you can see the error in the terminal. You can copy and past if here if you can't figure out what is causing it. You can also look in your /logs/ma.log file and it should contain the error from the last start up attempt.
        Joe.
