    [SOLVED] correct point var name for scripts...
    11 Posts 2 Posters 7.2k Views 1 Watching
    • danD Offline
      dan
      Hey Guys, to set a data point which I've rendered to be say MANUAL and AUTO do I use that with ' ' inside the script or just 0 or 1 for on / off or true and false?
      if(p36.value == 'MANUAL')
      if(p36.value == MANUAL)
      if(p36.value == 1)
      if(p36.value == 0)
      same for p36.set(1) or p36.set('AUTO') ?
      The script seems to just not change anything on the live system.
      Attachment: download link
        Try true or false
        if(p36.value == true)
        if(p36.value == false)
        same for p36.set(true) or p36.set(true)
        • danD Offline
          dan
          ok I'll try that thanks, could you just confirm the cron operation for scripts..
          Does the cron time execute the script say each minute for example then the script stop at the end of the script and it won't run again for another minute?
          Just trying to get this script to run at a more regular interval and I don't think cron will support that.
          Cheers
            Yes the CRON pattern will run the script once at the time or times determined by the CRON.
            • danD Offline
              dan
              Sorry for all the questions, is there a simple function within the scripting to either send an alert/email or raise an event from which I can then send an email from?
              Cheers
              Dan
                No, you would have to do that via a data point, event detector and event handler.
                • danD Offline
                  dan
                  cool, thanks for that.
                  I'm not getting any debugging info in this script each time it runs (each minute)
                  apart from:-
                  administrator@water:~$ tail -f logs/scripting-10.log
                  INFO  2014-08-08 13:59:58,063 - Data source started
                  I've tried having it in either trace or debug mode inside the script editing screen. I'm not sure it's even running the cron job, nothing in ma.log relating to it being triggered apart from the source restarting when I hit save..
                  INFO  2014-08-08 13:59:57,969 (com.serotonin.m2m2.rt.RuntimeManager.stopDataSource:322) - Data source 'Tank Automation' stopped
                  INFO  2014-08-08 13:59:58,068 (com.serotonin.m2m2.rt.RuntimeManager.initializeDataSource:290) - Data source 'Tank Automation' initialized
                  INFO  2014-08-08 13:59:58,069 (com.serotonin.m2m2.rt.RuntimeManager.initializeDataSource:295) - Data source 'Tank Automation' took 14.278909ms to start
                  • danD Offline
                    dan
                    This is the latest version of the script on the system, it just doesn't seem to be running at all. There are no more entries in the logs nor any errors, I have it in debug Log Level also.
                    // check if in auto mode AND tank level below 5000L AND pump not running
                    if ((p31.value == 'AUTO') && (p7.value < 5000) && (p11.value == 'STOP')) {
                    // open north solenoid
                    p24.set('OPEN');
                    // close southern solenoid
                    p22.set('CLOSED');
                    // close western solenoid
                    p28.set('CLOSED');
                    // start pump
                    p11.set('RUN');
                    // check if in auto mode AND tank level above 22700L AND pump running AND northern solenoid OPEN
                    if((p31.value == 'AUTO') && (p7.value > 22700) && (p11.value == 'RUN') && (p24.value == 'OPEN')) {
                    // stop pump
                    p11.set('STOP');
                    // close northern solenoid
                    p24.set('CLOSED');
                    // check if in auto mode at Driveway Tank AND tank level below 5000L AND pump not running
                    else if((p36.value == 'AUTO') && (p23.value < 16000) && (p11.value == 'STOP')) {
                    // open southern solenoid
                    p22.set('OPEN');
                    p24.set('CLOSED');
                    p28.set('CLOSED');
                    // start pump
                    p11.set('RUN');
                    // check if in auto mode at Driveway Tank AND tank level above 22700L AND pump running AND southern solenoid OPEN
                    if((p36.value == 'AUTO') && (p23.value > p38.value) && (p11.value == 'RUN') && (p22.value == 'OPEN')) {
                    // stop pump
                    p11.set('STOP');
                    p22.set('CLOSED');
                    I'm just going through and updating the fill points and low points to be dynamic from settable data points, but still the script doesn't appear to be running?
                    • danD Offline
                      dan
                      I've been looking through logs etc, it's like the cron scripts aren't even running at all.
                      Nothing appears in the logs apart from
                      INFO  2014-08-08 22:09:06,934 - Data source started
                      That kind of thing. Nothing more.
                      Is there somewhere I need to maybe set the path to the systems cron bin? Or is it using a java version of cron?
                      Mango appears to be running as root, should that be ok?
                      The timing for every minute just seems to be ignored and the cron job never appears to run?
                      Cheers
                      Dan
                      • danD Offline
                        dan
                        SOLVED!!
                        I mucked around with this for a few hours and found if I changed all the labelled set points from say 'AUTO' and 'MANUAL' to just true and false it now works, brilliantly!!
                        Thanks Joel and team for all your assistance!
                        Although I do still notice nothing in the trace log for the script other than the Data source started line.
                        Cheers
                        Dan
