    Modbus problem
    3 Posts 2 Posters 3.7k Views 1 Watching
    • I Offline
      iaininglis
      Hi
      I've been having a recent issue and I'm in the need for some help, if there's someone who can help it will be greatly appreciated.
      Situation:
      I've set up a DGBox and I have 1 serial modbus RTU line connected via one of the USB ports using an RS-485-USB converter (http://www.ftdichip.com/Support/Documents/DataSheets/Cables/DS_USB_RS485_CABLES.pdf).The modbus devices I have connected are a Socomec Diris A10 electricity meter (http://www.socomec.com/range-multi-function-meter_en.html?product=/dirisa10_en.html) and also a Novus Digirail-4C Digital Input Counter (https://novusautomation.co.uk/acatalog/digirail_4c_modbus_io.html).
      When the Data Source is enabled and i have only the electricity meter connected i get readings back, although i always get fault messages like 'Feb 12 16:57 - No response from slave 1 (8024 occurrences, most recent at 07:31:18)'. When i have only the digirail connected i get a similar outcome. But when i connect both i get no readings at all, just fault messages on both devices.
      Data Source Configuration is as follows,
      Bit Rate, 9600
      Flow control in, none
      Flow control out, none
      Data bits, 8
      Stop bits, 1
      Parity, Even
      Encoding, RTU
      Echo, Off
      Concurrency, Slave
      Timeout, 500 ms
      Retries 3
      A10 Meter (26 data points)
      slave address, 1
      baud, 9600
      parity, even
      stop bits, 1
      data bits, 8
      Digirail (2 data points)
      slave address, 11
      baud, 9600
      parity, even
      stop bits, 1
      data bits, 8
      I did have slave addresses of 1 & 2 but that also did not work so i changed one of them to see of it helped, but it did not. Devices are being polled at a 30 seconds frequency.
      I really don't know what is going on.
      Hope you can help me out.
      Iain
        This is not a DGBox forum.
