    BACNet MS/TP
    5 Posts 2 Posters 3.3k Views 1 Watching
    • R Offline
      ray
      I found that Mango support a lot of protocols. However, I have some equipment access through BACNet MS/TP. If Mango can support this protocol will be great.
        I believe MS/TP requires Ethernet, which Java does not speak. However, you should be able to get hardware that will do IP to MS/TP mediation.
        • R Offline
          ray
          The physical layer is just the same as MODBus RTU which use RS485 connector and behaves like token ring. It does not have anything to do with the Ethernet.
            Ok, but a larger problem is that we don't have any equipment on hand with which to develop and test. Do you have a budget associated with your project? Also, are you using M2M or Automation?
