    If want to get arry to out as csv file ?How to do ?
    3 Posts 1 Posters 1.7k Views 1 Watching
    • E Offline
      edmond
      Now I have received some sensor .and get the point value.
      If I want to as a array to get csv file
      for example: this is download the csv file when I click to "comma separated value(CSV)".
      Date Time XX1 XX2 XX3 XX4 XX5 XX6 XX7 XX8 XX10 XX11 XX12
      1/10/2014 19?13?20 0.411 3.554 3.111 1.021 433.33 777.91 22 29 23 65 5.0
      and I use meta add a script
      var arr=[p41.value,p42.value,p43.value,p40.value,p39.value,p1.value];
      var str="";
      for ( var i=0; i<arr.length; i++)
      {str+=arr*.toString();
      str+=","
      if (str.length >0)
      {return str.substr(0, str.length - 1);
      return str;
      Now I can get the data to display as attachment
      But I canot find get the csv the button.How to do get the csv file ?
      Thank in advance!!!
      • E Offline
        edmond
        var tableToExcel = function() {
        var uri = 'data:application/vnd.ms-excel;base64,',
        template = '<html xmlns:o="urn:schemas-microsoft-com:office:office" xmlns:x="urn:schemas-microsoft-com:office:excel" xmlns="http://www.w3.org/TR/REC-html40"><head><!--[if gte mso 9]><xml><x:ExcelWorkbook><x:ExcelWorksheets><x:ExcelWorksheet><x:Name>{worksheet}</x:Name><x:WorksheetOptions><x:DisplayGridlines/></x:WorksheetOptions></x:ExcelWorksheet></x:ExcelWorksheets></x:ExcelWorkbook></xml><![endif]--></head><body><table>{table}</table></body></html>',
        base64 = function(s) {
        return window.btoa(unescape(encodeURIComponent(s)))
        format = function(s, c) {
        return s.replace(/{(\w+)}/g,
        function(m, p) {
        return c[p];
        		var tableHTML="<tbody>";
        			tableHTML+="<tr>";
        			tableHTML+="<td>";
        			tableHTML+='p41.value';
        			tableHTML+="</td>";
        			tableHTML+="<td>";
        			tableHTML+='p42.value';
        			tableHTML+="</td>";
        			tableHTML+="<td>";
        			tableHTML+='p43.value';
        			tableHTML+="</td>";
        			tableHTML+="<td>";
        			tableHTML+='p40.value';
        			tableHTML+="</td>";
        			tableHTML+="<td>";
        			tableHTML+='p39.value';
        			tableHTML+="</td>";
        			tableHTML+="<td>";
        			tableHTML+='p1.value';
        			tableHTML+="</td>";
        			tableHTML+="</tr>";
        			tableHTML+="</tbody>";
        		return function(html, name) {
        			var ctx = {
        				worksheet: name || 'Worksheet',
        				table: html
        			window.location.href = uri + base64(format(template, ctx))
        		}(tableHTML, "???");
        tableToExcel();
        1, for the Script, whether the document can be output directly to excel in Script code inside.
        2, Script code is based on ECMAScript, which I have used in the script code embedded object browser window, such as window.location.href, then the error: "window" not defined, would like to ask why did not add to the browser embedded support objects
        3, if Script excel file can not be output through the code, so if there are other ways to generate excel file by writing code
        Is there a software system which can be called directly related to the function or function object and then output file?
