    Not able to read analog values from device
    8 Posts 2 Posters 6.7k Views 1 Watching
      manjunathm
      public class Test {
      static LocalDevice lDevice;
      /static ResourceBundle resource = ResourceBundle
      .getBundle("com.serotonin.bacnet4j/bacnet4j");
      public Test() {
      public static void main(String args[]) {
      	initializeDevice();
      public static void initializeDevice() {
      	try {
      		System.out.println("Inicializando...");
      		IpNetwork ipNetwork = new IpNetwork("172.28.14.255", 47808,	"172.28.14.63");
      		Transport transport = new Transport(ipNetwork);
      		lDevice = new LocalDevice(9899, transport);
      		lDevice.initialize();
      		lDevice.getEventHandler().addListener(new Listener());
      		lDevice.sendGlobalBroadcast(new WhoIsRequest());
      		Thread.sleep(500);
      // RemoteDevice rd = new RemoteDevice(101, new Address(new byte[] { (byte) 1, (byte) 2, 3, (byte) 4 }, 47808), null);
      // lDevice.addRemoteDevice(rd);
      @SuppressWarnings("unused")
      ReadPropertyRequest read = new ReadPropertyRequest(
      new ObjectIdentifier(ObjectType.analogInput, 243),PropertyIdentifier.presentValue);
      getObjectList(lDevice, "172.28.14.63", 47808, 17800);
      } catch (Exception e) {
      System.out.println("Error al inicializar " + e.getMessage());
      } finally {
      closeDevice();
      public static AcknowledgementService send(LocalDevice d,
      		ConfirmedRequestService s) throws Exception {
      	Address a = new Address(InetAddrCache.get("localhost", 0xbac1));
      	return d.send(a, null, MaxApduLength.UP_TO_1476,	Segmentation.segmentedBoth, s);
      public static void closeDevice() {
      	try {
      		lDevice.terminate();
      		System.out.println(e.getMessage());
      private static void getObjectList(LocalDevice localDevice, String ip,
      		int port, int deviceId) {
      	for (RemoteDevice d : localDevice.getRemoteDevices()) {
      		ObjectIdentifier oid = d.getObjectIdentifier();
      // InetSocketAddress addr = new InetSocketAddress(
      // InetAddress.getByName(ip), port);
      // System.out.println(addr.toString());
      		ReadPropertyRequest read = new ReadPropertyRequest(new ObjectIdentifier(ObjectType.device, deviceId),
      				PropertyIdentifier.objectList);
      // ReadPropertyAck ack = (ReadPropertyAck) localDevice.send(d, new ReadPropertyRequest(oid, PropertyIdentifier.presentValue));
      // System.out.println("Value: " + ack.getValue());
      // InetSocketAddress addr1 = new InetSocketAddress(InetAddress.getByName(ip), port);
      // System.out.println(addr1.toString());
      // networkNumber=0, macAddress=[ac,1c,e,64,ba,c0]
      Address addr = new Address(0, "172.28.14.63");
      ReadPropertyAck ack;
      try {
      ack = (ReadPropertyAck) localDevice.send(addr, null, MaxApduLength.UP_TO_1476, Segmentation.segmentedBoth, read);
      } catch (BACnetException e) {
      // TODO Auto-generated catch block
      e.printStackTrace();
      // System.out.println(send(lDevice, new ReadPropertyRequest(oid, PropertyIdentifier.objectName, null)));
      // System.out.println(send(lDevice, new ReadPropertyRequest(created, PropertyIdentifier.presentValue, null)));
      // System.out.println(send(lDevice, new ReadPropertyRequest(oid, PropertyIdentifier.objectList,
      // new UnsignedInteger(0))));
      // new ReadPropertyRequest(oid,
      // PropertyIdentifier.protocolServicesSupported));
      	/*	@SuppressWarnings("unchecked")
      		SequenceOf<ObjectIdentifier> oids = (SequenceOf<ObjectIdentifier>) ack
      				.getValue();
      		for (ObjectIdentifier oid1 : oids) {
      			System.out.println("    " + oid1.getObjectType());
      		PropertyIdentifier pids = (PropertyIdentifier) ack.getValue();
      		System.out.println("    " + pids);*/
      am getting an exception
      com.serotonin.bacnet4j.exception.ErrorAPDUException: ErrorAPDU(choice=12, errorClass=Object, errorCode=Unknown object)
      at com.serotonin.bacnet4j.transport.Transport.send(Transport.java:202)
      at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:381)
      at com.lnt.test.Test.getObjectList(Test.java:99)
      at com.lnt.test.Test.initializeDevice(Test.java:55)
      at com.lnt.test.Test.main(Test.java:35)
      can some one help on this
        Hi there I think I may be able to point you in the right direction.
        In your method getObjectList(localDevice, ip, port, deviceId) you may be using the wrong Object Identifier. You are hard coding the deviceId to 17800 but you are requesting the object list for all remote devices that have been discovered. I was able to get your code to work on my test platform by changing the following:
        ReadPropertyRequest read = new ReadPropertyRequest(new ObjectIdentifier(ObjectType.device, deviceId), PropertyIdentifier.objectList);
        to:
        ReadPropertyRequest read = new ReadPropertyRequest(oid,PropertyIdentifier.objectList);
        This change ensures that you are using the ObjectIdentifier for the remote devices that have been discovered.
          manjunathm
          Thanks a lot for your replay !!!
          ya i tried in your way am ...please see this code
          now my source code is ...
          package com.lnt.TestApp;
          import java.util.List;
          import com.serotonin.bacnet4j.LocalDevice;
          import com.serotonin.bacnet4j.RemoteDevice;
          import com.serotonin.bacnet4j.enums.MaxApduLength;
          import com.serotonin.bacnet4j.npdu.ip.IpNetwork;
          import com.serotonin.bacnet4j.service.acknowledgement.AcknowledgementService;
          import com.serotonin.bacnet4j.service.acknowledgement.ReadPropertyAck;
          import com.serotonin.bacnet4j.service.confirmed.ConfirmedRequestService;
          import com.serotonin.bacnet4j.service.confirmed.ReadPropertyRequest;
          import com.serotonin.bacnet4j.service.unconfirmed.WhoIsRequest;
          import com.serotonin.bacnet4j.transport.Transport;
          import com.serotonin.bacnet4j.type.constructed.Address;
          import com.serotonin.bacnet4j.type.constructed.SequenceOf;
          import com.serotonin.bacnet4j.type.enumerated.PropertyIdentifier;
          import com.serotonin.bacnet4j.type.enumerated.Segmentation;
          import com.serotonin.bacnet4j.type.primitive.ObjectIdentifier;
          import com.serotonin.bacnet4j.util.RequestUtils;
          public class Test {
          static Address addr = new Address(0, "172.28.14.100");
          public Test() {
          	initializeDevice();
          	try {
          		System.out.println("Initializing...");
          		Thread.sleep(500);
          		getObjectList(lDevice, "172.28.14.100",	47808, 0);
          		System.out.println("Error : " + e.getMessage());
          	} finally {
          		closeDevice();
          // Address a = new Address(InetAddrCache.get("localhost", 0xbac1));
          return d.send(addr, null, MaxApduLength.UP_TO_1476, Segmentation.segmentedBoth, s);
          	try {
          		int port, int deviceId) throws Exception {
          // ObjectIdentifier oid = d.getObjectIdentifier();
          List<ObjectIdentifier> oids = ((SequenceOf<ObjectIdentifier>) RequestUtils
          .sendReadPropertyAllowNull(localDevice, d, d.getObjectIdentifier(),PropertyIdentifier.objectList)).getValues();
          		for (int i = 0; i < oids.size(); i++) {
          			System.out.println("OBjectIdentifier"+oids);
          		for (ObjectIdentifier oid : oids) {
          			ReadPropertyRequest read = new ReadPropertyRequest(oid,	PropertyIdentifier.deviceAddressBinding);
          			ReadPropertyAck ack = (ReadPropertyAck) localDevice.send(d, read);
          and my optpuit is
          Segmentation: both
          OBjectIdentifier[Device 9899]
          Value: []
          OBjectIdentifier[Device 0, Analog Value 1, Analog Value 2, Trend Log 1, Trend Log 2, File 0]
          but i want analog values form that any hint ???
            manjunathm
            can u please replay ,,
            can u please see my code where am going wrong????
              manjunathm
              can u send the code for ReadRangeRequest, and ReadRangeAck
                Sorry I have been very busy lately with other work. All BACNet4j source is here http://sourceforge.net/projects/bacnet4j/
                Also, the code you posted isn't complete, you have not provided the source for the Listener class so I was unable to run the code you posted.
                  I just realized the new BACNet4j code is located in GitHub here: https://github.com/mlohbihler/BACnet4J
                  Sorry for the confusion.
