Script help
. I have a ModBus device connected to Mango. I have a couple of ModBus Data Points. I then have a Meta Data point referencing the Modbus Data points with the following script.
var a=p1.value; var le=p9.value; var re=p10.value; if (le==true) { var x = " Left"; } else if (re==true) { var x = " Right"; } if (a>0) { var y = "Pkey"; var result = y +" "+ a +" "+ x; } else if (a==0) { var result = "No fault" else if(typeof(p9.value || p10.value)=='undefined'){var result = "No fault"} return result;It works as expected except that it throws undefined errors into the result.
No fault 06:44:46
Pkey 1 undefined 06:44:44
Pkey 1 Left 06:44:37
No fault Feb 09 12:28
Pkey 1 undefined Feb 09 12:28
Pkey 1 Right Feb 09 12:28Could anyone possibly assist.
Many thanks,
Duncan
At a quick glance, it looks like you aren't handling when le and re might both be false. If that is the case, x is never initialized.
I think CraziFuzzy does have the root of what's causing that output, but there are some other things you might want to fix in your script,
(typeof(p9.value || p10.value)=='undefined')will not work, anything that can be logical or'ed tends to be boolean by its very nature. You have to split that into
(typeof(p9.value) == 'undefined' || typeof(p10.value)=='undefined')There is also no definition for result when a < 0 to return.
