    How to force old not calculated metadata to be calculated ?
    8 Posts 2 Posters 3.4k Views 1 Watching
    • B Offline
      bitelxux
      Hi, I've set some metadata datapoints based on other datapoints, but new metadata is only applied for new datapoints values ...
      How can I force mango to recalculate all allready past existing points medatada ?
        There is a generate history button on the metapoint in the datasource page. Unfortunately, this button has some known issues associated with it, and may not work quite as expected.
        I believe the best results with that button can be achieved by changing the meta point's update/logging information to be 1. run on context update and 2. log on change.
        • B Offline
          bitelxux
          :-( can't find that button. Could you please tell me where exactly is suposed to be ?
            In line with the data point on its data source page. The table should be:
            Name --< Type --> Enable/Disable Button --> Generate History Button --> Edit Point Button
            • B Offline
              bitelxux
              OK. Im' afraid ScadaBR fork doesn't have this feature :-(
              Thank you !
                You could theoretically perform this task with a scripting datasource. Say you have a need to generate the last 1000 points...
                1. Add all the context points to your script as you would your meta point.
                2. Write a big for loop, iterate i :
                var dt = new Date();
                for(var i = 1; i < 1000; ++i) {
                pnt1 = point1.prev(MINUTE, i).firstValue;
                pntN = pointN.prev(MINUTE, i).firstValue;
                result = //do work on the pnt values
                meta.set(result, dt.getTime()-(i*60*1000));
                and you could just have it get generated in one run of the script. Not pretty, but it should work.
                Note: This is for numeric points. Binaries and multistates would have a different solution.
                • B Offline
                  bitelxux
                  It's good workaround. Thankyou
