How to force old not calculated metadata to be calculated ?
Hi, I've set some metadata datapoints based on other datapoints, but new metadata is only applied for new datapoints values ...
How can I force mango to recalculate all allready past existing points medatada ?
There is a generate history button on the metapoint in the datasource page. Unfortunately, this button has some known issues associated with it, and may not work quite as expected.
I believe the best results with that button can be achieved by changing the meta point's update/logging information to be 1. run on context update and 2. log on change.
:-( can't find that button. Could you please tell me where exactly is suposed to be ?
In line with the data point on its data source page. The table should be:
Name --< Type --> Enable/Disable Button --> Generate History Button --> Edit Point Button -
OK. Im' afraid ScadaBR fork doesn't have this feature :-(
Thank you !
You could theoretically perform this task with a scripting datasource. Say you have a need to generate the last 1000 points...
- Add all the context points to your script as you would your meta point.
- Write a big for loop, iterate i :
var dt = new Date(); for(var i = 1; i < 1000; ++i) { pnt1 = point1.prev(MINUTE, i).firstValue; ... pntN = pointN.prev(MINUTE, i).firstValue; result = //do work on the pnt values meta.set(result, dt.getTime()-(i*60*1000)); }and you could just have it get generated in one run of the script. Not pretty, but it should work.
Note: This is for numeric points. Binaries and multistates would have a different solution.
It's good workaround. Thankyou
