    How to implement a filter algorithm
    7 Posts 2 Posters 5.5k Views 1 Watching
      sundeepgoel
      how can i implement a filtering algorithm to give me the median value from a set of sensor readings. i need this for some digital sensors which sometime give false readings - basically want to put all readings of say the last one minute in an array, sort it and then pick the median (middle value).
      is there an easy way to do this, any pointers will be appreciated...
        The best way to do this is with a meta point. Write the code necessary to get all your points into an array, here's some code I stole:
        var myArr = new Array();
        values.push(sens1.value)
        values.push(sensN.value)
        values.sort( function(a,b) {return a - b;} ); //works for our numeric values
        var half = Math.floor(values.length/2);
        if(values.length % 2)
           return values[half];
        else
           return (values[half-1] + values[half]) / 2.0;
        Hope that helps.
          sundeepgoel
          Hope that helps.
          Thanks for the quick response, a clarification please :-
          sens1.value
          sensN.value
          wont this be value of n different points, i need to get the last n values of the same point into the array, how can i do that ?
            Oh, I apologize, I misunderstood your question.
            So 'sens' will be our point that we want the history of.
            values.push(sens.prev(MINUTE, 1).firstValue)
            values.push(sens.prev(MINUTE, 2).firstValue)
            values.push(sens.prev(MINUTE, 3).firstValue)
            values.push(sens.prev(MINUTE, n).firstValue)
              sundeepgoel
              thanks, this seems exactly what i need.
              one other request, where do i find documentation on what you have described above e.g. prev(MINUTE,1).firstvalue - what other functions etc are there which could be used ?
                Most of the available data is documented in the help question mark on the page. I went to the source code for the 'firstValue' attribute, which is not listed in the help document. The public repo can be seen at www.github.com/infiniteautomation
