    Building Mango in Eclipse
    42 Posts 13 Posters 89.6k Views 1 Watching
      johnparker16
      In addition, i suggest modifying the code in your tomcat-users computer file. There is a known crawler that looks for credit card Tomcat circumstances and uses the administrator to publish and start programs.
        chahin
        am trying to run th build.xml file but i found some Error :shock: :
        for example : /*** Compiling 616 source files to C:\workspace-pfe\mango\build\WEB-INF\classes
        [javac] C:\workspace-pfe\mango\src\com\serotonin\mango\vo\User.java:26: error: package javax.servlet.http does not exist
        [javac] import javax.servlet.http.HttpSessionBindingEvent; ***/
        help please :cry:
        REM: i download the code source from http://sourceforge.net/projects/scadabr/files/Software/mango-src/mango-source-1.12.3.zip/download (VERSION 1.12.3)
        • D Offline
          Dusan
          I had similar problem with javax.servlet.http.... I resolved it with adding all libraries in the project. Right click on the project/Build Path/Configure Build Path/Choose Java Build Path on the left and add all .jar files from war/WEB-INF/lib.
          That should be ok.
          I have another problem:
          My build is successful, but I can't see it in my browser. I copy files from webapps/test to webapps/ROOT, but http://localhost:8080/ returnes error. Please, help!
          Thank you very much!
          Dusan
            Can you provide some more details on the nature of the error? Is there anything in the Tomcat log?
            • D Offline
              Dusan
              thank you for answering!
              http://localhost:8080/test returnes this:
              HTTP Status 500 -
              type Exception report
              message
              description The server encountered an internal error () that prevented it from fulfilling this request.
              exception
              org.apache.jasper.JasperException: Unable to compile class for JSP:
              An error occurred at line: 22 in the generated java file
              The method getJspApplicationContext(ServletContext) is undefined for the type JspFactory
              Stacktrace:
              org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:92)
              org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:330)
              org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:439)
              org.apache.jasper.compiler.Compiler.compile(Compiler.java:356)
              org.apache.jasper.compiler.Compiler.compile(Compiler.java:334)
              org.apache.jasper.compiler.Compiler.compile(Compiler.java:321)
              org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:592)
              org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:328)
              org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
              org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
              javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
              note The full stack trace of the root cause is available in the Apache Tomcat/6.0.35 logs.
              http://localhost:8080/mango works (folder mango contains extracted mango-1.13.0.zip downloaded from Mango Website).
              I built it as Andreas did (on the first page). That is:
              -get Eclipse IDE for Java EE Developers
              -get Mango source code, unpack it
              -add empty subdirectories lib, src_gen and src_test to Mango source
              -add RXTXcomm.jar in lib directory
              -in file build.properties, edit tomcat.home to point at the tomcat location on your system.
              C:/Program Files/Apache Software Foundation/Tomcat 6.0
              -get axis-ant.jar and put it into the WEB-INF/lib directory
              -In Eclipse choose import->general and browse to the mango source
              -I used "add jar" to add these jars in war/WEB-INF/lib :
              modbus4J
              seroUtils
              common-httputils
              quartz
              bacnet4J
              commons-codec
              joda-time
              servlet-api
              jsp-api
              -I added the rest of .jar files
              -right-click build.xml in the project explorer and choose run as->2(3).ant-build...
              choose the createconfigfiles target
              -right-click build.xml again and again choose run as->2(3).ant-build...
              choose the default deploy
              The newly built Mango is now copied to the tomcat webapps/test directory
              I don't think it is connected to the problem, but I see WARNING signs on several packages in src folder (in Eclipse).
              Also, I see "C:\Documents and Settings\Administrator\Desktop\mango-source-1.12.4\build.xml:82: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds" in console, after building it.
              Dusan
                There's not really an error message there beyond, "there was an error", so it's hard to say. I'd suggest looking for differences between the "test" deployment and the "mango" deployment.
                • D Offline
                  Dusan
                  OK, I'll try to figure it out.
                  Dusan
                  • D Offline
                    Dusan
                    Hi again,
                    I'm analysing Mango source code. I don't know how JSP pages are connected.
                    For example: the first page is login.jsp (in WEB-INF/jsp/). When user clicks on Log in button,
                    what is the next jsp page that will be shown to him?
                    Where can I define navigation rules?
                    In JSF there is a file faces-config.xml where navigation rules are defined (start JSP page, servlet which checks username and password, and the next JSP page).
                    I imported Mango source code in Eclipse as General/Existing Project into Workspace.
                    P.S. I opened new topic about it, Programming in Mango.
                    Dusan
                    • W Offline
                      wangkai2010
                      @craig said:
                      I do the following:
                      1. make sure you have eclipse release which includes the web tools project.
                      2. unpack mango source in a directory called "myMangoBranch" inside the eclipse workspace directory
                      3. Do File->New->Other, choose "Dynamic Web project" from under "Web"
                      4. Make Project name "myMangoBranch" (must match existing directory name)
                      5. I don't have to change any other options on the new dynamic web project dialog, target runtime is apache tomcat 6.0 (you may have to add a target runtime), so I hit next.
                      6. Source folders on the build path i leave as "src" and default output folder I leave as build/classes, so i hit next
                      7. Content Directory I change from "WebContent" to war. Hit finish!
                      In accordance with the above steps.I build the project,but I meet fatal error:
                      Exception sending context initialized event to listener instance of class com.serotonin.mango.MangoContextListener
                      java.util.MissingResourceException: Can't find bundle for base name env, locale zh_CN
                      at java.util.ResourceBundle.throwMissingResourceException(Unknown Source)
                      at java.util.ResourceBundle.getBundleImpl(Unknown Source)
                      at java.util.ResourceBundle.getBundle(Unknown Source)
                      at com.serotonin.util.PropertiesUtils.<init>(PropertiesUtils.java:30)
                      at com.serotonin.util.PropertiesUtils.<init>(PropertiesUtils.java:24)
                      at com.serotonin.mango.Common.getEnvironmentProfile(Common.java:300)
                      at com.serotonin.mango.db.DatabaseAccess.createDatabaseAccess(DatabaseAccess.java:72)
                      at com.serotonin.mango.MangoContextListener.databaseInitialize(MangoContextListener.java:253)
                      at com.serotonin.mango.MangoContextListener.contextInitialized(MangoContextListener.java:94)
                      at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4206)
                      at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
                      at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
                      at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
                      at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
                      at org.apache.catalina.core.StandardService.start(StandardService.java:525)
                      at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
                      at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
                      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                      at java.lang.reflect.Method.invoke(Unknown Source)
                      at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
                      at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
                      2012-11-26 10:07:22 org.apache.catalina.core.StandardContext start
                      I need help.Could someone helps me.Thank you!!
                        abhig4488
                        Hi all
                        i followed all the steps told by craig.
                        But it showed error Eclipse that the myMangoBranch directory already exists (and suggests to use import existing project). & if i import the project cannot be run properly using tomcat..
                        Can anyone help please?
