    Error editing e-mail address
    14 Posts 4 Posters 8.0k Views 1 Watching
      What is your O/S?
        To answer your question, yes, others have reported this problem, but it was never reproducable. I have added some code to try to protect against it based on information from Derby forums, and some logging in case it still happens. Hopefully, one way or another, this will be dealt with. The changes will be in the next release.
          craig
          the OS is windows 7. It does happen every time.
            Sorry, by "reproduceable", i meant not reproduceable in a development environment.
              craig
              on my local machine it is reproduceable if you would like me to test any patches
                Unfortunately, the UserDao class has undergone changes for multiple purposes, so i can't just send you a class file. But if you're feeling ambitious, you could modify the code by changing the updateUser method to that below. I have not tested this in 1.12.4, so ymmv.
                    void updateUser(User user) {
                        // Potential fix for "An attempt was made to get a data value of type 'VARCHAR' from a data value of type 'null'"
                        if (user.getPhone() == null)
                            user.setPhone("");
                        if (user.getHomeUrl() == null)
                            user.setHomeUrl("");
                        try {
                            ejt.update(
                                    USER_UPDATE,
                                    new Object[] { user.getUsername(), user.getPassword(), user.getEmail(), user.getPhone(),
                                            boolToChar(user.isAdmin()), boolToChar(user.isDisabled()), user.getHomeUrl(),
                                            user.getReceiveAlarmEmails(), boolToChar(user.isReceiveOwnAuditEvents()),
                                            user.getId() }, new int[] { Types.VARCHAR, Types.VARCHAR,
                                            Types.VARCHAR, Types.VARCHAR, Types.VARCHAR, Types.VARCHAR, Types.VARCHAR, Types.INTEGER,
                                            Types.VARCHAR, Types.INTEGER });
                            saveRelationalData(user);
                        catch (DataIntegrityViolationException e) {
                            // Log some information about the user object.
                            LOG.error("Error updating user: " + user, e);
                            throw e;
                  craig
                  that fixed it. thanks.
                    Awesome. Thanks Craig.
                    • V Offline
                      Victorino
                      Can you make the updated library available for 1.12.4? I'm also having the same error when changing data point permissions on any users.
                      Actually I get the error when changing anything on a user.
                        You should consider using Mango Automation. http://m2m2.serotoninsoftware.com/
                          craig
                          I have attached the patched UserDao classes off of an instance of 1.12.4.
                          Good Luck
                          • L Offline
                            lordportux
                            I had the same problem in mango 1.12.3 and I solved it using the Derby.jar file from mango 1.12.5
