    Non unique Object Names???
    7 Posts 3 Posters 4.7k Views 1 Watching
    • G Offline
      Gatos
      I create and initiate a device with multiple objects with the same name.
      No problems, no exceptions, everything works "fine".
      But according to the BACnet standard, object names MUST be unique.
      Am I missing something?
      Thanks a lot in advance.
        japearson
        As far as I can tell it is the BACnet Object Identifier that must be unique. Although I have noticed that some third party BACnet devices get a bit confused when they see objects that have the same name. Although bacnet4j only cares about the object identifier being unique.
        I hope that helps
        • G Offline
          Gatos
          Yes, it helps, thanks a lot for your response.
          I see...
          Well, actually, according to the standard, the object name MUST be unique:
          http://www.bacnet.org/Bibliography/ES-7-96/ES-7-96.htm
          (This is not the specification document, but I have read the same in many BACnet sources)
          I don't doubt that there may be good arguments why this is not necessary or maybe even a bad strategy.
          However, strictly speaking, if we want to say that bacnet4j implements the BACnet specification, I think it should ensure the uniqueness of the object name.
            I've added a check for name uniqueness upon adding a new local object to the local device (check into CVS). Note that uniqueness could still be violated by changing the name of an existing object though.
            • G Offline
              Gatos
              Is then the same true when changing an ObjectIdentifier? Or is the latter simply not writable?
              Thanks + regards!
                Presumably yes, you can change the oid, although oids themselves are immutable.
