<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Non unique Object Names???]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I create and initiate a device with multiple objects with the same name.<br />
No problems, no exceptions, everything works "fine".<br />
But according to the BACnet standard, object names MUST be unique.</p>
<p dir="auto">Am I missing something?</p>
<p dir="auto">Thanks a lot in advance.</p>
]]></description><link>https://forum.mango-os.com/topic/1162/non-unique-object-names</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 05:05:49 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1162.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Oct 2012 15:38:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Non unique Object Names??? on Mon, 29 Oct 2012 19:15:07 GMT]]></title><description><![CDATA[<p dir="auto">Presumably yes, you can change the oid, although oids themselves are immutable.</p>
]]></description><link>https://forum.mango-os.com/post/7088</link><guid isPermaLink="true">https://forum.mango-os.com/post/7088</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 29 Oct 2012 19:15:07 GMT</pubDate></item><item><title><![CDATA[Reply to Non unique Object Names??? on Mon, 29 Oct 2012 19:09:07 GMT]]></title><description><![CDATA[<p dir="auto">Is then the same true when changing an ObjectIdentifier? Or is the latter simply not writable?</p>
<p dir="auto">Thanks + regards!</p>
]]></description><link>https://forum.mango-os.com/post/7086</link><guid isPermaLink="true">https://forum.mango-os.com/post/7086</guid><dc:creator><![CDATA[Gatos]]></dc:creator><pubDate>Mon, 29 Oct 2012 19:09:07 GMT</pubDate></item><item><title><![CDATA[Reply to Non unique Object Names??? on Mon, 29 Oct 2012 18:18:45 GMT]]></title><description><![CDATA[<p dir="auto">I've added a check for name uniqueness upon adding a new local object to the local device (check into CVS). Note that uniqueness could still be violated by changing the name of an existing object though.</p>
]]></description><link>https://forum.mango-os.com/post/7084</link><guid isPermaLink="true">https://forum.mango-os.com/post/7084</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 29 Oct 2012 18:18:45 GMT</pubDate></item><item><title><![CDATA[Reply to Non unique Object Names??? on Mon, 29 Oct 2012 12:32:44 GMT]]></title><description><![CDATA[<p dir="auto">Yes, it helps, thanks a lot for your response.<br />
I see...<br />
Well, actually, according to the standard, the object name MUST be unique:<br />
<a href="http://www.bacnet.org/Bibliography/ES-7-96/ES-7-96.htm" rel="nofollow ugc">http://www.bacnet.org/Bibliography/ES-7-96/ES-7-96.htm</a><br />
(This is not the specification document, but I have read the same in many BACnet sources)<br />
I don't doubt that there may be good arguments why this is not necessary or maybe even a bad strategy.<br />
However, strictly speaking, if we want to say that bacnet4j implements the BACnet specification, I think it should ensure the uniqueness of the object name.</p>
]]></description><link>https://forum.mango-os.com/post/7080</link><guid isPermaLink="true">https://forum.mango-os.com/post/7080</guid><dc:creator><![CDATA[Gatos]]></dc:creator><pubDate>Mon, 29 Oct 2012 12:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to Non unique Object Names??? on Mon, 29 Oct 2012 09:58:06 GMT]]></title><description><![CDATA[<p dir="auto">As far as I can tell it is the BACnet Object Identifier that must be unique.  Although I have noticed that some third party BACnet devices get a bit confused when they see objects that have the same name.  Although bacnet4j only cares about the object identifier being unique.</p>
<p dir="auto">I hope that helps</p>
]]></description><link>https://forum.mango-os.com/post/7079</link><guid isPermaLink="true">https://forum.mango-os.com/post/7079</guid><dc:creator><![CDATA[japearson]]></dc:creator><pubDate>Mon, 29 Oct 2012 09:58:06 GMT</pubDate></item></channel></rss>
