    Read BACnet ObjectValues
    8 Posts 3 Posters 6.0k Views 1 Watching
      josher
      Hello everyone!
      I am beginning with BACnet4j project. I think it is a great project, so i am very glad with it.
      I am trying to read BACnet object values from my computer with a Java project. My code is:
      public class BACnetNetwork {
      	static LocalDevice lDevice;
      	static ResourceBundle resource = ResourceBundle.getBundle("resources/bacnet4j");
      	public BACnetNetwork(){}
      	public static void main(String args[]){
      		initializeDevice();
      	public static void initializeDevice(){
      		try{
      			System.out.println("Inicializando...");
      			lDevice = new LocalDevice(17800, resource.getString("localDeviceIP"));
      			lDevice.getEventHandler().addListener(new Listener());
      			lDevice.initialize();
      			//System.out.println("Remote Devices..."+lDevice.get);
      			@SuppressWarnings("unused")
      			ReadPropertyRequest read = new ReadPropertyRequest(new ObjectIdentifier(ObjectType.analogInput, 243), PropertyIdentifier.presentValue);
      	        getObjectList(lDevice, resource.getString("deviceIP"), Integer.valueOf(resource.getString("port")), 17800);
      		}catch(Exception e){
      			System.out.println("Error al inicializar "+e.getMessage());
      		}finally{
      			closeDevice();
      	public static void closeDevice(){
      		try{
      			lDevice.terminate();
      			System.out.println(e.getMessage());
      	private static void getObjectList(LocalDevice localDevice, String ip, int port, int deviceId) throws Exception {
              InetSocketAddress addr = new InetSocketAddress(InetAddress.getByName(ip), port);
              System.out.println(addr.toString());
              ReadPropertyRequest read = new ReadPropertyRequest(new ObjectIdentifier(ObjectType.device, deviceId), PropertyIdentifier.objectList);
              ReadPropertyAck ack = (ReadPropertyAck) localDevice.send(addr, null, 1476, Segmentation.segmentedBoth, read);
              System.out.println("IP: " + ip);
              @SuppressWarnings("unchecked")
      		SequenceOf<ObjectIdentifier> oids = (SequenceOf<ObjectIdentifier>) ack.getValue();
              for (ObjectIdentifier oid : oids) {
                  System.out.println("    " + oid.getObjectType());
      		PropertyIdentifier pids = (PropertyIdentifier) ack.getValue();
              System.out.println("    " + pids);
      	static class Listener extends DefaultDeviceEventListener {
              @Override
              public void iAmReceived(RemoteDevice d) {
                  System.out.println("I am received" + d);
      However, when I run, the output shows:
      P: 192.168.107.247
          Device 17800
          Analog Input 0
          Multi-state Input 0
          Analog Input 1
          Trend Log 1
          Trend Log 2
          Trend Log 3
          File 0
      I have been studying a BACnet frame from Wireshark, but I do not see any value.
      How could I read values from a device?
      Thank you very much!!
      Regards!
        BACnet4J does not store present values for objects. You need to request them using ReadProperty or ReadPropertyMultiple requests, asking objects for their present value property.
          josher
          But in my code I am already using "ReadPropertyRequest". Another option is "ReadPropertyMultipleRequest"
          Thanks!
            The only property that you are reading is objectList.
              josher
              Ok!! Thank you very much!! I solve the problem. So, do I need send a ReadPropertyRequest and a ReadPropertyAck for each property? I have tried with PropertyIdentifier.all, however it throws an Exception. If I send a request for each property I can see that property, but I think it could be a lot of load in BAcnet network...
              Regards!
                Using the "all" identifier will often result in an exception because the content is too much to put into a single response. BACnet4J will try to compensate in come cases, but it doesn't always work out.
                You can ask for multiple properties with a ReadPropertyMultiple request, as long as your equipment supports it.
                • D Offline
                  djrosu
                  Hello, I am trying to figure out how to use bacnet4j and this thread is helpful however I am still stuck on the various IP addresses and ports used? Can you explain the difference between resource.getString("localDeviceIP"), resource.getString("deviceIP") and resource.getString("port")? Thanks in advance.
