    Converting from Derby to MySQL
    21 Posts 11 Posters 44.0k Views 1 Watching
      BTW, if you have any problems during conversion (e.g. a power failure, and error, etc), you can always restart the process by dropping all of the tables that Mango created in your MySQL schema and restarting Mango.
      • T Offline
        Thitiwat
        Dear sir,
        I try change databse from Derby to Mysql error message:
        INFO 2010-01-07 15:26:17,921 (org.springframework.web.context.ContextLoader.initWebApplicationContext:189) - Root WebApplicationContext: initialization started
        INFO 2010-01-07 15:26:17,968 (org.springframework.context.support.AbstractApplicationContext.prepareRefresh:412) - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@e0a386: display name [Root WebApplicationContext]; startup date [Thu Jan 07 15:26:17 ICT 2010]; root of context hierarchy
        INFO 2010-01-07 15:26:18,046 (org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions:323) - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext.xml]
        INFO 2010-01-07 15:26:18,093 (org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory:427) - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@e0a386]: org.springframework.beans.factory.support.DefaultListableBeanFactory@609959
        INFO 2010-01-07 15:26:18,203 (org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons:414) - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@609959: defining beans [CompoundEventsDwr,CustomViewDwr,DataPointDetailsDwr,DataPointEditDwr,DataSourceEditDwr,DataSourceListDwr,EmportDwr,EventHandlersDwr,EventsDwr,MailingListsDwr,MiscDwr,PointHierarchyDwr,PointLinksDwr,PublisherEditDwr,PublisherListDwr,ReportsDwr,ScheduledEventsDwr,SystemSettingsDwr,UsersDwr,ViewDwr,WatchListDwr,localeResolver,messageSource]; root of factory hierarchy
        INFO 2010-01-07 15:26:18,343 (org.springframework.web.context.ContextLoader.initWebApplicationContext:209) - Root WebApplicationContext: initialization completed in 406 ms
        INFO 2010-01-07 15:26:18,343 (com.serotonin.mango.MangoContextListener.contextInitialized:73) - Mango context starting
        INFO 2010-01-07 15:26:18,656 (com.serotonin.mango.db.BasePooledAccess.initializeImpl:54) - Initializing pooled connection manager
        WARN 2010-01-07 15:26:19,046 (com.serotonin.mango.db.upgrade.DBUpgrade.checkUpgrade:81) - Upgrading instance from 0.7.0 to 0.8.0
        INFO 2010-01-07 15:26:19,062 (org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions:323) - Loading XML bean definitions from class path resource [org/springframework/jdbc/support/sql-error-codes.xml]
        INFO 2010-01-07 15:26:19,109 (org.springframework.jdbc.support.SQLErrorCodesFactory.<init>:128) - SQLErrorCodes loaded: [DB2, Derby, H2, HSQL, Informix, MS-SQL, MySQL, Oracle, PostgreSQL, Sybase]
        INFO 2010-01-07 15:26:19,125 (com.serotonin.mango.MangoContextListener.contextDestroyed:101) - Mango context terminating
        INFO 2010-01-07 15:26:19,125 (com.serotonin.mango.db.BasePooledAccess.terminate:123) - Stopping database
        INFO 2010-01-07 15:26:19,125 (com.serotonin.mango.MangoContextListener.contextDestroyed:121) - Mango context terminated
        INFO 2010-01-07 15:26:19,125 (org.springframework.context.support.AbstractApplicationContext.doClose:816) - Closing org.springframework.web.context.support.XmlWebApplicationContext@e0a386: display name [Root WebApplicationContext]; startup date [Thu Jan 07 15:26:17 ICT 2010]; root of context hierarchy
        INFO 2010-01-07 15:26:19,125 (org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingletons:392) - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@609959: defining beans [CompoundEventsDwr,CustomViewDwr,DataPointDetailsDwr,DataPointEditDwr,DataSourceEditDwr,DataSourceListDwr,EmportDwr,EventHandlersDwr,EventsDwr,MailingListsDwr,MiscDwr,PointHierarchyDwr,PointLinksDwr,PublisherEditDwr,PublisherListDwr,ReportsDwr,ScheduledEventsDwr,SystemSettingsDwr,UsersDwr,ViewDwr,WatchListDwr,localeResolver,messageSource]; root of factory hierarchy
        How to solve is problem?
          Did you manually create the mysql tables? If so, drop them all and start again. You only need to create the database. Mango need to create the tables itself.
            jjconti
            I followed the spteps but after restarting Mango, the tables were created in the MySQL schema but there was no data on them bt the admin/amdin user/password.
              jjconti
              Done. I also needed to comment the following lines:
              #convert.db.type=
              #convert.db.url=
              #convert.db.username=
              #convert.db.password=
                SteveE
                I'm running Mango 1.9.0 and recently converted my derby db to mysql version 5.5.8. I ran into a couple of issues which I was able figure out and fix. Note: these issues may have already been addressed in the newer versions of Mango.
                1. There is a new version of the mysql java connector jar available from the mysql website. Download mysql-connector-java-5.1.14.tar.gz, unzip it, and place mysql-connector-java-5.1.14-bin.jar in WEB-INF/lib directory.
                2. Several sql scripts and db upgrade source files used a deprecated mysql keyword in 'create table' statements. Search for 'type=InnoDB' and replace with 'engine=InnoDB'.
                  You should also delete any previous versions of the connector jar file.
                  • G Offline
                    gus
                    Hello, I am having trouble converting to MySQL - I have tried all the above and no success - I am running version 1.12.4. Logs as follows:
                    un 9, 2011 2:05:30 PM org.apache.catalina.core.ApplicationContext log
                    INFO: Initializing Spring root WebApplicationContext
                    Jun 9, 2011 2:05:30 PM org.apache.catalina.core.StandardContext listenerStart
                    SEVERE: Exception sending context initialized event to listener instance of class com.serotonin.mango.MangoContextListener
                    java.lang.IllegalArgumentException: No enum const class com.serotonin.mango.db.DatabaseAccess$DatabaseType.MYSQL
                    at java.lang.Enum.valueOf(Enum.java:214)
                    at com.serotonin.mango.db.DatabaseAccess$DatabaseType.valueOf(DatabaseAccess.java:48)
                    at com.serotonin.mango.db.DatabaseAccess.createDatabaseAccess(DatabaseAccess.java:73)
                    at com.serotonin.mango.MangoContextListener.databaseInitialize(MangoContextListener.java:253)
                    at com.serotonin.mango.MangoContextListener.contextInitialized(MangoContextListener.java:94)
                    at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3934)
                    at org.apache.catalina.core.StandardContext.start(StandardContext.java:4429)
                    at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
                    at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
                    at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:526)
                    at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:987)
                    at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:909)
                    at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:495)
                    at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1206)
                    at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:314)
                    at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
                    at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
                    at org.apache.catalina.core.StandardHost.start(StandardHost.java:722)
                    at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
                    at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
                    at org.apache.catalina.core.StandardService.start(StandardService.java:516)
                    at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
                    at org.apache.catalina.startup.Catalina.start(Catalina.java:583)
                    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
                    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                    at java.lang.reflect.Method.invoke(Method.java:616)
                    at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
                    at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
                    Jun 9, 2011 2:05:30 PM org.apache.catalina.core.ApplicationContext log
                    INFO: Closing Spring root WebApplicationContext
                    env.properties
                    convert.db.type=derby
                    convert.db.url=~/../../bin/mangoDB
                    convert.db.username=admin
                    convert.db.password=admin
                    db.type=mysql
                    db.url=jdbc:mysql://localhost/mangodb
                    db.username=mango
                    db.password=mango
                    db.pool.maxActive=10
                    db.pool.maxIdle=10
                    Any help much appreciated.
                    I have also tried with a fresh copy of Mango with just the MySQL settings but no success..
                    Thanks Gus
                      cora
                      I have the same problem that gus mentioned before. Is there a solution? anyone has a suggestion?
                        rcopeland
                        Hi I'm having trouble with this conversion. I've performed the steps listed on the first page, but when I go to localhost:8080 I get a HTTP Status 404 Error: The requested resource is not available.
                        On the Tomcat console, the errors appear to start around here:> SEVERE: Error listenerStart
                        Jan 24, 2012 9:35:40 AM org.apache.catalina.core.StandardContext start
                        SEVERE: Context [] startup failed due to previous errors
                        INFO 2012-01-24 09:35:40,093 (com.serotonin.mango.MangoContextListener.contextD
                        estroyed:124) - Mango context terminating
                        INFO 2012-01-24 09:35:40,093 (com.serotonin.mango.db.BasePooledAccess.terminate
                        :123) - Stopping database Anyone have any idea why this happens? My Information for the MySQL connection is correct, as when I put in a wrong password on purpose I get different and more errors.
                        Additionally, does anyone know the user/password login information to log into the derby database? I would like to browse the database with a program I have, but havent been able to make the connection as I havent found where the user/password is kept.
                        Thanks!
                          Richard, check the <tomcat>/logs/localhost<date>.log file for error messages.
                            Antsu
                            I'm tried to setup Mango on my new computer. OS is Ubuntu 12.04 LTS and then Mysql version is 5.5.24-0ubuntu0.12.04.1 and Mango 1.13.0.
                            When I try to start Mango, browser says:
                                        *  HTTP Status 404 -*
                            Localhost.log says:
                            *Jun 19, 2012 7:03:10 PM org.apache.catalina.core.ApplicationContext log
                            Jun 19, 2012 7:03:13 PM org.apache.catalina.core.StandardContext listenerStart
                            org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [ create table systemSettings ( settingName varchar(32) not null, settingValue longtext, primary key (settingName) ) engine=InnoDB; ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'mango.systemSettings' already exists
                            at org.springframework.jdbc.support.SQLExceptionSubclassTranslator.doTranslate(SQLExceptionSubclassTranslator.java:94)
                            at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:72)
                            at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80)
                            at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:406)
                            at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:427)
                            at com.serotonin.mango.db.BasePooledAccess.runScript(BasePooledAccess.java:89)
                            at com.serotonin.mango.db.BasePooledAccess.createSchema(BasePooledAccess.java:106)
                            at com.serotonin.mango.db.MySQLAccess.newDatabaseCheck(MySQLAccess.java:79)
                            at com.serotonin.mango.db.DatabaseAccess.initialize(DatabaseAccess.java:102)
                            at com.serotonin.mango.MangoContextListener.databaseInitialize(MangoContextListener.java:259)
                            at com.serotonin.mango.MangoContextListener.contextInitialized(MangoContextListener.java:98)
                            at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4206)
                            at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
                            at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
                            at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
                            at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
                            at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:675)
                            at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:601)
                            at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:502)
                            at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
                            at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
                            at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
                            at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
                            at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
                            at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
                            at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
                            at org.apache.catalina.core.StandardService.start(StandardService.java:525)
                            at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
                            at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
                            at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
                            at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
                            Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'mango.systemSettings' already exists
                            at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
                            at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
                            at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
                            at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
                            at com.mysql.jdbc.Util.getInstance(Util.java:381)
                            at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1030)
                            at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956)
                            at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3515)
                            at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3447)
                            at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1951)
                            at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2101)
                            at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2548)
                            at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2477)
                            at com.mysql.jdbc.StatementImpl.execute(StatementImpl.java:741)
                            at com.mysql.jdbc.StatementImpl.execute(StatementImpl.java:587)
                            at org.apache.commons.dbcp.DelegatingStatement.execute(DelegatingStatement.java:266)
                            at org.springframework.jdbc.core.JdbcTemplate$1ExecuteStatementCallback.doInStatement(JdbcTemplate.java:420)
                            at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:395)
                            ... 31 more
                            Jun 19, 2012 7:03:13 PM org.apache.catalina.core.ApplicationContext log
                            What went wrong?
                            BR
                            Antsu
                              Can you post your db.* and db.convert.* properties?
                                Antsu
                                Did you mean that env.properties?
                                db.type=mysql
                                db.username=mangoUser
                                db.password=mangoPass
                                db.pool.maxIdle=10
                                db.update.log.dir=${catalina.base}/logs/
                                convert.db.url=~/../..mangoDB
                                  Yes. The properties look ok. But you seem to have existing tables in your mysql schema. You'll need to drop those first, and then try starting up again.
                                    Rgantwer
                                    Hey friends,
                                    I did this using Squirrel SQL, this software bring a plugin that let you copy a table from a derby database and paste that table on MYSql database, so you can export/import copying the tables from one database to another. its helpful .
                                      Maybe not as helpful as you think. Mango will do all of that for you. You just need to create a schema for it to use, and Mango will copy over everything from Derby to MySQL for you.
                                        mrblue106
                                        I had the same problem: I solved this removing the trailing spaces at every lines of env.properties
                                        in my file (probably after a cut&paste from somewhere) I noticed that:
                                        my db.type=mysql was ->> db.type=mysql[space][space]
                                        after deleting the trailing spaces from every lines (I noticed the same problem on username/password and host)the conversion process worked like a charme!
                                        I hope this could help someone else.
                                        Regards
                                        • L Offline
                                          lansoul80
                                          hello all.
                                          I get below messages when I convert derby to mysql, mango 2.2
                                          INFO 2014-05-28 11:22:10,698 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'BACnet', v2.0.5 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,744 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'dataFile', v1.0.1 by Infinite Automation
                                          INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'dataImport', v1.3.1 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'dglux', v1.0.8 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'dnp3', v1.4.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'galil', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'graphicalViews', v1.4.5 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,791 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'http', v1.4.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,791 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'internal', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,807 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'jmxds', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,807 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'jspViews', v2.0.1 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,823 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'log4JReset', v1.0.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,838 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'maintenanceEvents', v1.4.4 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,838 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'mbus', v1.0.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,838 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'meta', v2.0.1 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,854 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'modbus', v1.4.5 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,854 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'modbusPublisher', v1.2.1 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,869 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'onewire', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,869 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'opcda', v1.5.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,869 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'pachube', v1.4.5 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,885 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'persistent', v1.4.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,885 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'pointLinks', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,901 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'pop3', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'reports', v2.0.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'scheduledEvents', v1.4.3 by (unknown vendor)
                                          INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'scripting', v1.0.4 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'serial', v1.1.0 by Infinite Automation
                                          INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'snmp', v1.4.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,932 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sqlConsole', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,932 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sqlds', v1.5.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,948 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sstGlobalScripts', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,948 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sstGraphics', v1.0.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,948 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sstTheme', v1.0.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,963 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'templateConfig', v1.0.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,963 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'virtualDS', v1.4.2 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,963 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'vmstat', v1.4.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:10,979 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'watchlists', v1.5.3 by Infinite Automation Software
                                          INFO 2014-05-28 11:22:12,213 (com.serotonin.m2m2.web.M2M2ContextListener.contextInitialized:31) - Mango Automation context starting
                                          INFO 2014-05-28 11:22:12,213 (com.serotonin.m2m2.web.M2M2ContextListener.contextInitialized:39) - Mango Automation context started
                                          INFO 2014-05-28 11:22:12,854 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/users.shtm] onto handler 'usersController'
                                          INFO 2014-05-28 11:22:12,885 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_source.shtm] onto handler 'dataSourceController'
                                          INFO 2014-05-28 11:22:12,994 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/publisher_edit.shtm] onto handler 'publisherEditController'
                                          INFO 2014-05-28 11:22:13,057 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/login.htm] onto handler 'loginController'
                                          INFO 2014-05-28 11:22:13,057 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/shutdown.htm] onto handler 'shutdownController'
                                          INFO 2014-05-28 11:22:13,088 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_source_properties.shtm] onto handler 'dataSourcePropertiesController'
                                          INFO 2014-05-28 11:22:13,088 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/startup.htm] onto handler 'startupController'
                                          INFO 2014-05-28 11:22:13,119 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/webcam_live_feed.htm] onto handler 'webcamLiveFeedController'
                                          INFO 2014-05-28 11:22:13,135 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/unauthorized.htm] onto handler 'unauthorizedController'
                                          INFO 2014-05-28 11:22:13,135 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_point_edit.shtm] onto handler 'dataPointEditController'
                                          INFO 2014-05-28 11:22:13,166 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_source_properties_error.shtm] onto handler 'dataSourceErrorController'
                                          INFO 2014-05-28 11:22:13,182 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_source_edit.shtm] onto handler 'dataSourceEditController'
                                          INFO 2014-05-28 11:22:13,182 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile/users.shtm] onto handler 'usersController'
                                          INFO 2014-05-28 11:22:13,244 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile.shtm] onto handler 'mobileController'
                                          INFO 2014-05-28 11:22:13,244 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/help.shtm] onto handler 'helpController'
                                          INFO 2014-05-28 11:22:13,244 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/logout.htm] onto handler 'logoutController'
                                          INFO 2014-05-28 11:22:13,869 (com.serotonin.m2m2.Lifecycle.lic:400) - Checking license...
                                          INFO 2014-05-28 11:22:13,869 (com.serotonin.m2m2.Lifecycle.loadLic:514) - License file not found
                                          INFO 2014-05-28 11:22:13,963 (com.serotonin.m2m2.db.BasePooledProxy.initializeImpl:36) - Initializing pooled connection manager
                                          INFO 2014-05-28 11:22:14,682 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:36) - Starting instance with core version 2.2.2, db 9
                                          INFO 2014-05-28 11:22:15,635 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
                                          INFO 2014-05-28 11:22:15,651 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.modbus.dwr.ModbusEditDwr
                                          INFO 2014-05-28 11:22:15,651 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
                                          INFO 2014-05-28 11:22:15,682 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
                                          INFO 2014-05-28 11:22:15,682 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: br.org.scadabr.dnp3.dwr.DnpEditDwr
                                          INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_point_details.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/pending_alarms.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/event_handlers.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_sources.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/point_hierarchy.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mailing_lists.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/publishers.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/system_settings.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/modules.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/emport.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/upload.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/download.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile_data_point_details.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/templateConfig.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/dataImport.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/dglux.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/dglux/login.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/views.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/public_view.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/view_edit.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/maintenance_events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/point_links.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/reportChart.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/reports.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/scheduled_events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/sqlConsole.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/globalScripts.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/watch_list.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile/login.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile/watch_list.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile/logout.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                          it looks there is no error, but it stops here everytime I start mango.
                                          I checked mysql database, all the tables were created, but not all of the datas converted into mysql.
