    Converting from Derby to MySQL
    21 Posts 11 Posters 37.6k Views 1 Watching
      If your instance of Mango has an installation of MySQL "nearby", you will likely be able to achieve much better overall performance by converting databases.
      The following is a basic set of instructions for converting from Derby to MySQL. Since 1.6.2, Mango shipped with a conversion utility that automatically will copy your data from Derby to a fresh MySQL schema (and theoretically in the other direction as well, although i'm not personally aware of anyone having done it). Note that one user reported issues when using this utility on a non-standard host, but that attempts have otherwise been successful.
      If this procedure does not work for you, please report your errors so that others can benefit from the experience.
      1. Ensure that your existing Derby instance is up to date with your Mango software. That is, do not download a new version of the software and attempt a conversion without giving Mango a chance to upgrade your existing database. Conversions will only work when source and target are exactly the same version.
      2. Create a new schema in your MySQL instance and provide a user account with full permissions to it. DO NOT create the Mango tables. Mango likes to do this itself.
      3. Edit the WEB-INF/classes/env.properties file. You will have existing "db." entries in there that point to the Derby database. Prepend these entries with "convert." They will then look something like this:
      convert.db.type=derby
      convert.db.url=~/../../bin/mangoDB
      convert.db.username=
      convert.db.password=
      Note that you may only have the "url" entry. This is fine.
      1. Add entries that point to your MySQL instance. The following are examples. Modify them to suit your environment.
      db.type=mysql
      db.url=jdbc:mysql://localhost/mango
      db.username=mangoUser
      db.password=mangoPass
      db.pool.maxActive=10
      db.pool.maxIdle=10
      Check the MySQL documentation for more information on connection URLs if you need help. The last two entries are for connection pooling configuration and are optional. Note that the ordering of these properties in the file is inconsequential.
      1. Save the changes.
      2. Important: check your WEB-INF/lib directory for old versions of the MySQL JDBC library. The correct version to have in there is mysql-connector-java-5.1.7-bin.jar. Remove any other versions, such as mysql-connector-java-3.1.8-bin.jar.
      3. Restart Mango.
      4. Watch the console messages. You will be given information on the steps and progress of the conversion as it occurs. Depending on the size of your Derby database and the power of your hardware this process could take seconds or hours.
        BTW, if you have any problems during conversion (e.g. a power failure, and error, etc), you can always restart the process by dropping all of the tables that Mango created in your MySQL schema and restarting Mango.
        • T Offline
          Thitiwat
          Dear sir,
          I try change databse from Derby to Mysql error message:
          INFO 2010-01-07 15:26:17,921 (org.springframework.web.context.ContextLoader.initWebApplicationContext:189) - Root WebApplicationContext: initialization started
          INFO 2010-01-07 15:26:17,968 (org.springframework.context.support.AbstractApplicationContext.prepareRefresh:412) - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@e0a386: display name [Root WebApplicationContext]; startup date [Thu Jan 07 15:26:17 ICT 2010]; root of context hierarchy
          INFO 2010-01-07 15:26:18,046 (org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions:323) - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext.xml]
          INFO 2010-01-07 15:26:18,093 (org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory:427) - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@e0a386]: org.springframework.beans.factory.support.DefaultListableBeanFactory@609959
          INFO 2010-01-07 15:26:18,203 (org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons:414) - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@609959: defining beans [CompoundEventsDwr,CustomViewDwr,DataPointDetailsDwr,DataPointEditDwr,DataSourceEditDwr,DataSourceListDwr,EmportDwr,EventHandlersDwr,EventsDwr,MailingListsDwr,MiscDwr,PointHierarchyDwr,PointLinksDwr,PublisherEditDwr,PublisherListDwr,ReportsDwr,ScheduledEventsDwr,SystemSettingsDwr,UsersDwr,ViewDwr,WatchListDwr,localeResolver,messageSource]; root of factory hierarchy
          INFO 2010-01-07 15:26:18,343 (org.springframework.web.context.ContextLoader.initWebApplicationContext:209) - Root WebApplicationContext: initialization completed in 406 ms
          INFO 2010-01-07 15:26:18,343 (com.serotonin.mango.MangoContextListener.contextInitialized:73) - Mango context starting
          INFO 2010-01-07 15:26:18,656 (com.serotonin.mango.db.BasePooledAccess.initializeImpl:54) - Initializing pooled connection manager
          WARN 2010-01-07 15:26:19,046 (com.serotonin.mango.db.upgrade.DBUpgrade.checkUpgrade:81) - Upgrading instance from 0.7.0 to 0.8.0
          INFO 2010-01-07 15:26:19,062 (org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions:323) - Loading XML bean definitions from class path resource [org/springframework/jdbc/support/sql-error-codes.xml]
          INFO 2010-01-07 15:26:19,109 (org.springframework.jdbc.support.SQLErrorCodesFactory.<init>:128) - SQLErrorCodes loaded: [DB2, Derby, H2, HSQL, Informix, MS-SQL, MySQL, Oracle, PostgreSQL, Sybase]
          INFO 2010-01-07 15:26:19,125 (com.serotonin.mango.MangoContextListener.contextDestroyed:101) - Mango context terminating
          INFO 2010-01-07 15:26:19,125 (com.serotonin.mango.db.BasePooledAccess.terminate:123) - Stopping database
          INFO 2010-01-07 15:26:19,125 (com.serotonin.mango.MangoContextListener.contextDestroyed:121) - Mango context terminated
          INFO 2010-01-07 15:26:19,125 (org.springframework.context.support.AbstractApplicationContext.doClose:816) - Closing org.springframework.web.context.support.XmlWebApplicationContext@e0a386: display name [Root WebApplicationContext]; startup date [Thu Jan 07 15:26:17 ICT 2010]; root of context hierarchy
          INFO 2010-01-07 15:26:19,125 (org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingletons:392) - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@609959: defining beans [CompoundEventsDwr,CustomViewDwr,DataPointDetailsDwr,DataPointEditDwr,DataSourceEditDwr,DataSourceListDwr,EmportDwr,EventHandlersDwr,EventsDwr,MailingListsDwr,MiscDwr,PointHierarchyDwr,PointLinksDwr,PublisherEditDwr,PublisherListDwr,ReportsDwr,ScheduledEventsDwr,SystemSettingsDwr,UsersDwr,ViewDwr,WatchListDwr,localeResolver,messageSource]; root of factory hierarchy
          How to solve is problem?
            Did you manually create the mysql tables? If so, drop them all and start again. You only need to create the database. Mango need to create the tables itself.
              jjconti
              I followed the spteps but after restarting Mango, the tables were created in the MySQL schema but there was no data on them bt the admin/amdin user/password.
                jjconti
                Done. I also needed to comment the following lines:
                #convert.db.type=
                #convert.db.url=
                #convert.db.username=
                #convert.db.password=
                  SteveE
                  I'm running Mango 1.9.0 and recently converted my derby db to mysql version 5.5.8. I ran into a couple of issues which I was able figure out and fix. Note: these issues may have already been addressed in the newer versions of Mango.
                  1. There is a new version of the mysql java connector jar available from the mysql website. Download mysql-connector-java-5.1.14.tar.gz, unzip it, and place mysql-connector-java-5.1.14-bin.jar in WEB-INF/lib directory.
                  2. Several sql scripts and db upgrade source files used a deprecated mysql keyword in 'create table' statements. Search for 'type=InnoDB' and replace with 'engine=InnoDB'.
                    You should also delete any previous versions of the connector jar file.
                    • G Offline
                      gus
                      Hello, I am having trouble converting to MySQL - I have tried all the above and no success - I am running version 1.12.4. Logs as follows:
                      un 9, 2011 2:05:30 PM org.apache.catalina.core.ApplicationContext log
                      INFO: Initializing Spring root WebApplicationContext
                      Jun 9, 2011 2:05:30 PM org.apache.catalina.core.StandardContext listenerStart
                      SEVERE: Exception sending context initialized event to listener instance of class com.serotonin.mango.MangoContextListener
                      java.lang.IllegalArgumentException: No enum const class com.serotonin.mango.db.DatabaseAccess$DatabaseType.MYSQL
                      at java.lang.Enum.valueOf(Enum.java:214)
                      at com.serotonin.mango.db.DatabaseAccess$DatabaseType.valueOf(DatabaseAccess.java:48)
                      at com.serotonin.mango.db.DatabaseAccess.createDatabaseAccess(DatabaseAccess.java:73)
                      at com.serotonin.mango.MangoContextListener.databaseInitialize(MangoContextListener.java:253)
                      at com.serotonin.mango.MangoContextListener.contextInitialized(MangoContextListener.java:94)
                      at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3934)
                      at org.apache.catalina.core.StandardContext.start(StandardContext.java:4429)
                      at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
                      at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
                      at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:526)
                      at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:987)
                      at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:909)
                      at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:495)
                      at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1206)
                      at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:314)
                      at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
                      at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
                      at org.apache.catalina.core.StandardHost.start(StandardHost.java:722)
                      at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
                      at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
                      at org.apache.catalina.core.StandardService.start(StandardService.java:516)
                      at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
                      at org.apache.catalina.startup.Catalina.start(Catalina.java:583)
                      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
                      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                      at java.lang.reflect.Method.invoke(Method.java:616)
                      at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
                      at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
                      Jun 9, 2011 2:05:30 PM org.apache.catalina.core.ApplicationContext log
                      INFO: Closing Spring root WebApplicationContext
                      env.properties
                      convert.db.username=admin
                      convert.db.password=admin
                      db.type=mysql
                      db.url=jdbc:mysql://localhost/mangodb
                      db.username=mango
                      db.password=mango
                      db.pool.maxIdle=10
                      Any help much appreciated.
                      I have also tried with a fresh copy of Mango with just the MySQL settings but no success..
                      Thanks Gus
                        cora
                        I have the same problem that gus mentioned before. Is there a solution? anyone has a suggestion?
                          rcopeland
                          Hi I'm having trouble with this conversion. I've performed the steps listed on the first page, but when I go to localhost:8080 I get a HTTP Status 404 Error: The requested resource is not available.
                          On the Tomcat console, the errors appear to start around here:> SEVERE: Error listenerStart
                          Jan 24, 2012 9:35:40 AM org.apache.catalina.core.StandardContext start
                          SEVERE: Context [] startup failed due to previous errors
                          INFO 2012-01-24 09:35:40,093 (com.serotonin.mango.MangoContextListener.contextD
                          estroyed:124) - Mango context terminating
                          INFO 2012-01-24 09:35:40,093 (com.serotonin.mango.db.BasePooledAccess.terminate
                          :123) - Stopping database Anyone have any idea why this happens? My Information for the MySQL connection is correct, as when I put in a wrong password on purpose I get different and more errors.
                          Additionally, does anyone know the user/password login information to log into the derby database? I would like to browse the database with a program I have, but havent been able to make the connection as I havent found where the user/password is kept.
                          Thanks!
                            Richard, check the <tomcat>/logs/localhost<date>.log file for error messages.
                              Antsu
                              I'm tried to setup Mango on my new computer. OS is Ubuntu 12.04 LTS and then Mysql version is 5.5.24-0ubuntu0.12.04.1 and Mango 1.13.0.
                              When I try to start Mango, browser says:
                                          *  HTTP Status 404 -*
                              Localhost.log says:
                              *Jun 19, 2012 7:03:10 PM org.apache.catalina.core.ApplicationContext log
                              Jun 19, 2012 7:03:13 PM org.apache.catalina.core.StandardContext listenerStart
                              org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [ create table systemSettings ( settingName varchar(32) not null, settingValue longtext, primary key (settingName) ) engine=InnoDB; ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'mango.systemSettings' already exists
                              at org.springframework.jdbc.support.SQLExceptionSubclassTranslator.doTranslate(SQLExceptionSubclassTranslator.java:94)
                              at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:72)
                              at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80)
                              at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:406)
                              at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:427)
                              at com.serotonin.mango.db.BasePooledAccess.runScript(BasePooledAccess.java:89)
                              at com.serotonin.mango.db.BasePooledAccess.createSchema(BasePooledAccess.java:106)
                              at com.serotonin.mango.db.MySQLAccess.newDatabaseCheck(MySQLAccess.java:79)
                              at com.serotonin.mango.db.DatabaseAccess.initialize(DatabaseAccess.java:102)
                              at com.serotonin.mango.MangoContextListener.databaseInitialize(MangoContextListener.java:259)
                              at com.serotonin.mango.MangoContextListener.contextInitialized(MangoContextListener.java:98)
                              at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4206)
                              at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
                              at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
                              at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
                              at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
                              at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:675)
                              at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:601)
                              at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:502)
                              at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
                              at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
                              at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
                              at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
                              at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
                              at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
                              at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
                              at org.apache.catalina.core.StandardService.start(StandardService.java:525)
                              at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
                              at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
                              at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
                              at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
                              Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'mango.systemSettings' already exists
                              at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
                              at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
                              at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
                              at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
                              at com.mysql.jdbc.Util.getInstance(Util.java:381)
                              at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1030)
                              at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956)
                              at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3515)
                              at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3447)
                              at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1951)
                              at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2101)
                              at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2548)
                              at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2477)
                              at com.mysql.jdbc.StatementImpl.execute(StatementImpl.java:741)
                              at com.mysql.jdbc.StatementImpl.execute(StatementImpl.java:587)
                              at org.apache.commons.dbcp.DelegatingStatement.execute(DelegatingStatement.java:266)
                              at org.springframework.jdbc.core.JdbcTemplate$1ExecuteStatementCallback.doInStatement(JdbcTemplate.java:420)
                              at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:395)
                              ... 31 more
                              Jun 19, 2012 7:03:13 PM org.apache.catalina.core.ApplicationContext log
                              What went wrong?
                              BR
                              Antsu
                                Can you post your db.* and db.convert.* properties?
                                  Antsu
                                  Did you mean that env.properties?
                                  db.type=mysql
                                  db.pool.maxIdle=10
                                  db.update.log.dir=${catalina.base}/logs/
                                  convert.db.url=~/../..mangoDB
                                    Yes. The properties look ok. But you seem to have existing tables in your mysql schema. You'll need to drop those first, and then try starting up again.
                                      Rgantwer
                                      Hey friends,
                                      I did this using Squirrel SQL, this software bring a plugin that let you copy a table from a derby database and paste that table on MYSql database, so you can export/import copying the tables from one database to another. its helpful .
                                        Maybe not as helpful as you think. Mango will do all of that for you. You just need to create a schema for it to use, and Mango will copy over everything from Derby to MySQL for you.
                                          mrblue106
                                          I had the same problem: I solved this removing the trailing spaces at every lines of env.properties
                                          in my file (probably after a cut&paste from somewhere) I noticed that:
                                          my db.type=mysql was ->> db.type=mysql[space][space]
                                          after deleting the trailing spaces from every lines (I noticed the same problem on username/password and host)the conversion process worked like a charme!
                                          I hope this could help someone else.
                                          Regards
                                          • L Offline
                                            lansoul80
                                            hello all.
                                            I get below messages when I convert derby to mysql, mango 2.2
                                            INFO 2014-05-28 11:22:10,698 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'BACnet', v2.0.5 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,744 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'dataFile', v1.0.1 by Infinite Automation
                                            INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'dataImport', v1.3.1 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'dglux', v1.0.8 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'dnp3', v1.4.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'galil', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,760 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'graphicalViews', v1.4.5 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,791 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'http', v1.4.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,791 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'internal', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,807 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'jmxds', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,807 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'jspViews', v2.0.1 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,823 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'log4JReset', v1.0.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,838 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'maintenanceEvents', v1.4.4 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,838 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'mbus', v1.0.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,838 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'meta', v2.0.1 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,854 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'modbus', v1.4.5 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,854 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'modbusPublisher', v1.2.1 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,869 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'onewire', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,869 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'opcda', v1.5.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,869 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'pachube', v1.4.5 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,885 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'persistent', v1.4.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,885 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'pointLinks', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,901 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'pop3', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'reports', v2.0.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'scheduledEvents', v1.4.3 by (unknown vendor)
                                            INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'scripting', v1.0.4 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'serial', v1.1.0 by Infinite Automation
                                            INFO 2014-05-28 11:22:10,916 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'snmp', v1.4.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,932 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sqlConsole', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,932 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sqlds', v1.5.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,948 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sstGlobalScripts', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,948 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sstGraphics', v1.0.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,948 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'sstTheme', v1.0.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,963 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'templateConfig', v1.0.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,963 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'virtualDS', v1.4.2 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,963 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'vmstat', v1.4.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:10,979 (com.serotonin.m2m2.Main.loadModules:399) - Loading module 'watchlists', v1.5.3 by Infinite Automation Software
                                            INFO 2014-05-28 11:22:12,213 (com.serotonin.m2m2.web.M2M2ContextListener.contextInitialized:31) - Mango Automation context starting
                                            INFO 2014-05-28 11:22:12,213 (com.serotonin.m2m2.web.M2M2ContextListener.contextInitialized:39) - Mango Automation context started
                                            INFO 2014-05-28 11:22:12,854 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/users.shtm] onto handler 'usersController'
                                            INFO 2014-05-28 11:22:12,885 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_source.shtm] onto handler 'dataSourceController'
                                            INFO 2014-05-28 11:22:12,994 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/publisher_edit.shtm] onto handler 'publisherEditController'
                                            INFO 2014-05-28 11:22:13,057 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/login.htm] onto handler 'loginController'
                                            INFO 2014-05-28 11:22:13,057 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/shutdown.htm] onto handler 'shutdownController'
                                            INFO 2014-05-28 11:22:13,088 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_source_properties.shtm] onto handler 'dataSourcePropertiesController'
                                            INFO 2014-05-28 11:22:13,088 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/startup.htm] onto handler 'startupController'
                                            INFO 2014-05-28 11:22:13,119 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/webcam_live_feed.htm] onto handler 'webcamLiveFeedController'
                                            INFO 2014-05-28 11:22:13,135 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/unauthorized.htm] onto handler 'unauthorizedController'
                                            INFO 2014-05-28 11:22:13,135 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_point_edit.shtm] onto handler 'dataPointEditController'
                                            INFO 2014-05-28 11:22:13,166 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_source_properties_error.shtm] onto handler 'dataSourceErrorController'
                                            INFO 2014-05-28 11:22:13,182 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_source_edit.shtm] onto handler 'dataSourceEditController'
                                            INFO 2014-05-28 11:22:13,182 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile/users.shtm] onto handler 'usersController'
                                            INFO 2014-05-28 11:22:13,244 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile.shtm] onto handler 'mobileController'
                                            INFO 2014-05-28 11:22:13,244 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/help.shtm] onto handler 'helpController'
                                            INFO 2014-05-28 11:22:13,244 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/logout.htm] onto handler 'logoutController'
                                            INFO 2014-05-28 11:22:13,869 (com.serotonin.m2m2.Lifecycle.lic:400) - Checking license...
                                            INFO 2014-05-28 11:22:13,869 (com.serotonin.m2m2.Lifecycle.loadLic:514) - License file not found
                                            INFO 2014-05-28 11:22:13,963 (com.serotonin.m2m2.db.BasePooledProxy.initializeImpl:36) - Initializing pooled connection manager
                                            INFO 2014-05-28 11:22:14,682 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:36) - Starting instance with core version 2.2.2, db 9
                                            INFO 2014-05-28 11:22:15,635 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
                                            INFO 2014-05-28 11:22:15,651 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.modbus.dwr.ModbusEditDwr
                                            INFO 2014-05-28 11:22:15,651 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
                                            INFO 2014-05-28 11:22:15,682 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
                                            INFO 2014-05-28 11:22:15,682 (com.serotonin.m2m2.Lifecycle.configureDwr:813) - Duplicate definition of DWR class ignored: br.org.scadabr.dnp3.dwr.DnpEditDwr
                                            INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_point_details.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/pending_alarms.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/event_handlers.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/data_sources.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,729 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/point_hierarchy.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mailing_lists.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/publishers.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/system_settings.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/modules.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/emport.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/upload.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/download.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile_data_point_details.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/templateConfig.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/dataImport.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/dglux.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,744 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/dglux/login.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/views.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/public_view.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/view_edit.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/maintenance_events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/point_links.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/reportChart.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/reports.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,760 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/scheduled_events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/sqlConsole.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/globalScripts.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/watch_list.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile/login.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile/watch_list.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            INFO 2014-05-28 11:22:15,776 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:411) - Mapped URL path [/mobile/logout.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
                                            it looks there is no error, but it stops here everytime I start mango.
                                            I checked mysql database, all the tables were created, but not all of the datas converted into mysql.
