    Error while polling
    11 Posts 3 Posters 7.8k Views 1 Watching
      jjconti
      I start Mango with a Modbus IP data source created and get this error in the standar output:
      WARN 2010-04-16 10:51:48,781 (com.serotonin.mango.rt.dataSource.PollingDataSour
      ce.scheduleTimeout:66) - Modbus ip Prueba: poll at 2010/04/16 10:51:48 aborted b
      ecause a previous poll started at 2010/04/16 10:51:38 is still running
      WARN 2010-04-16 10:51:54,031 (com.serotonin.mango.rt.dataSource.modbus.ModbusDa
      taSource.receivedException:226) - Modbus exception
      com.serotonin.messaging.WaitingRoomException: No recipient was found waiting for
      response for key com.serotonin.modbus4j.ip.IpWaitingRoomKey@7fa2
      at com.serotonin.messaging.WaitingRoom.response(WaitingRoom.java:69)
      at com.serotonin.messaging.MessageControl.data(MessageControl.java:147)
      at com.serotonin.messaging.InputStreamListener.run(InputStreamListener.j
      ava:76)
      at java.lang.Thread.run(Thread.java:619)
      WARN 2010-04-16 10:51:58,687 (com.serotonin.mango.rt.dataSource.PollingDataSour
      ce.scheduleTimeout:66) - Modbus ip Prueba: poll at 2010/04/16 10:51:58 aborted b
      What can be happening? There is now modbus server to connect.
        I take it you're using UDP. Some background...
        Request messages are sent, and then the thread "sits in the waiting room" for the response to come back. After a timeout the thread leaves the waiting room, shrugs its shoulders, and says that it didn't get a response.
        Later, a response is received, but by that time "no recipient was found waiting for response".
        Solution: increase your timeout.
          jjconti
          I'm using TCP.
          How can I avoid this error?
            jjconti
            Im not responding.
                jjconti
                How much? I have my modbus server turn off.
                  As much as needed to make the message go away. Seriously, i can't be more specific than that.
                  • L Offline
                    luke
                    hi,
                    I have almost the same problem with the WaitingRoomException.
                    I set the timeout to different values with the same result, but the message
                    is received anyways.
                    output:
                    request:
                    00 00 00 00 00 06 03 03 00 01 00 0C ............
                    com.serotonin.messaging.WaitingRoomException: No recipient was found waiting for response for key com.serotonin.modbus4j.ip.xa.XaWaitingRoomKey@8008
                    at com.serotonin.messaging.MessageControl.data(MessageControl.java:153)
                    at com.serotonin.messaging.InputStreamListener.run(InputStreamListener.java:76)
                    at java.lang.Thread.run(Thread.java:595)
                    response:
                    00 00 00 00 00 1B 03 03 18 43 67 12 25 00 00 00 .........Cg.%...
                    00 00 00 00 00 43 67 12 25 00 00 00 00 43 67 12 .....Cg.%....Cg.
                    25 %
                    {voltage 1=231.07088, voltage 6=231.07088, voltage 4=231.07088, voltage 3=0.0, voltage 2=0.0, voltage 5=0.0}
                    Source:
                    package test.sim;
                    import com.serotonin.modbus4j.BatchRead;
                    import com.serotonin.modbus4j.BatchResults;
                    import com.serotonin.modbus4j.ModbusFactory;
                    import com.serotonin.modbus4j.ModbusLocator;
                    import com.serotonin.modbus4j.ModbusMaster;
                    import com.serotonin.modbus4j.code.DataType;
                    import com.serotonin.modbus4j.code.RegisterRange;
                    import com.serotonin.modbus4j.ip.IpParameters;
                    public class BatchTest
                      public static void main(String[] args) throws Exception {
                        IpParameters tcpParameters = new IpParameters();
                        tcpParameters.setHost("10.17.175.43");
                        ModbusFactory modbusFactory = new ModbusFactory();
                        ModbusMaster master = modbusFactory.createTcpMaster(tcpParameters, true);
                    //    master.setTimeout(5000);
                        for(int i = 0; i < 50; i++) {
                          try {
                            BatchRead<String> batchRead = new BatchRead<String>();
                            int slaveId = 3;
                            ModbusLocator locator = new ModbusLocator(slaveId, RegisterRange.HOLDING_REGISTER, 1,
                              DataType.FOUR_BYTE_FLOAT);
                            ModbusLocator locator2 = new ModbusLocator(slaveId, RegisterRange.HOLDING_REGISTER, 3,
                            ModbusLocator locator3 = new ModbusLocator(slaveId, RegisterRange.HOLDING_REGISTER, 5,
                            ModbusLocator locator4 = new ModbusLocator(slaveId, RegisterRange.HOLDING_REGISTER, 7,
                            ModbusLocator locator5 = new ModbusLocator(slaveId, RegisterRange.HOLDING_REGISTER, 9,
                            ModbusLocator locator6 = new ModbusLocator(slaveId, RegisterRange.HOLDING_REGISTER, 11,
                            batchRead.addLocator("voltage 1", locator);
                            batchRead.addLocator("voltage 2", locator2);
                            batchRead.addLocator("voltage 3", locator3);
                            batchRead.addLocator("voltage 4", locator4);
                            batchRead.addLocator("voltage 5", locator5);
                            batchRead.addLocator("voltage 6", locator6);
                            master.init();
                            BatchResults<String> results = master.send(batchRead);
                            System.err.println(results);
                          finally {
                            master.destroy();
                    Thanking you in anticipation!
                      I guess i didn't read the entire question. If your modbus server is turned off, shouldn't you expect an error? There is obviously no appropriate timeout for equipment that will never answer.
                        Luke, what happens if you increase the timeout?
