    Send / Receive ASCII string through serial port?
    9 Posts 4 Posters 10.1k Views 1 Watching
      mrk22
      Is there anyway in Mango to send an ASCII string to a serial device and capture the response? I'm trying to connect to a RS-485 thermostat. A sample request for the set temperature of the thermostat would be:
      "SN1 SH=?" and the reply would be "SN1 SH=68"
      Thanks!
        No, not currently. The number of possibilities that people might need from something like this are too vast to build a general data source. You would be much better off building a module in M2M2 specifically for your equipment.
        • O Offline
          oja
          I tried workaround for this. I create simple JAR with openPort, closePort and sendData method with RxTx library.
          This JAR I sent to jre/lib/ext folder with RxTx library.
          Last step was create Meta data source point with some field with Cron timing.
          In Javascript (Rhino) I wrote import of my JAR and called my methods.
          Now I am busy, but I want to create simple example and zip with my serial communicator classes.
          It works.
          Oja
          • O Offline
            oja
            Java script code for ASCII serial
            importPackage(com.alarex.serialcommunicator);
            var serial = new SerialCommunicator();
            var command = 'ati\r\n';
            x = serial.openPort("/dev/ttyS0", 115200, 8, 1, SerialCommunicator.PARITY_NONE, SerialCommunicator.FLOWCONTROL_NONE);
            //sendDataAsString(String, timeout for response, timeout for last byte from response - detect packet end)
            vysledek = serial.sendDataAsString(command,1000,100);
            serial.closePort();
            return vysledek;
            You can call sendDataAsString multiple and return part1+","+part2+"," part3
            and split in other fields in datasource.
            • O Offline
              oja
              Copy SerialCommunicator.jar to ...jre/lib/ext . RxTx library have to be installed.
              After copy you have to restart apache-tomcat.
              I attached datapoint settings picture
                mrk22
                OJA,
                Thank you for the reply and example. I'll give it a try!
                  mkhadem
                  Oja,
                  The link to your files are removed or can not be found. Please let me know how I can get your code.
                  Mo
                  • O Offline
                    oja
                    Ok, I am attaching it as one ZIP.
