    Drop down box
    5 Posts 3 Posters 3.0k Views 1 Watching
      skiv71
      hi, i've seen code for a drop down selection box...
      http://mango.serotoninsoftware.com/forum/posts/list/598.page
      which i've been able to implement, but instead of numbers, i'd like text, which after selection, writes a corresponding numberic value to the point variable.
      what do i need to change?
      thanks
      Neil
        Something like this... Change:
            s+= "<option value="+ i;
            if (value == i) { s+= " selected ";}
            s+= ">"+i+ "></option>";
        ... to:
            s+= "<option value=1>my label for 1</option>";
            s+= "<option value=2>my label for 2</option>";
            s+= "<option value=3>my label for 3</option>";
        ... and do what you need to do to default the selection (i.e. the "selected" attribute).
          skiv71
          i've been fumbling.... and got this...
          var s="";
          s+="<select name='mode'"
          s+="onchange='mango.view.setPoint("+ point.id +", ""+ pointComponent.id +"", this.selectedIndex)'>'>"
          s+="<option value=0>local</option>"
          s+="<option value=1>remote</option>"
          s+="</select>";
          return s;
          whilst it works, unless the object selection is changed, the present value is not sync'd the real value..
          i saw the for loop in jokke example... but i ended up with 4 entries instead of 2...
          i tried to create a var called 'newval' and make that equal value (from the point value) and then modify the onchange to set a var, i.e. newval=this.selectedIndex
          an then at the end of the script update the mango.view.setpoint bit...
          couldn't get it to work though..
          also, if possible... might be nice to modify the whole thing so that a button [OK] 'onclick' causes the mango.view.setpoint bit to be updated, allowing the user to explore the choices for committing
            Jokke
            It needs to have the "selected" in the option to be sync. The basic structure is this.
            <select onChange='somefunction()'>
            <option value=1 > one </option>
            <option value=2 selected > two </option>
            <option value=3 > three </option>
            </select>
            I used the loop to to write the selected into correct option (and not to write tens of times the same code)
            Here is an example without any loops.
            //Simple Select example
            var s="";
            s+="<select  onChange='mango.view.setPoint("+ point.id +", \""+ pointComponent.id +"\", this.options[this.selectedIndex].value )'>";
            s+= "<option value=1";
            if (value == 1 ) { s+= " selected ";}
            s+= "> one </option>";
            s+= "<option value=2";
            if (value == 2 ) { s+= " selected ";}
            s+= "> two </option>";
            s+= "<option value=3";
            if (value == 3 ) { s+= " selected ";}
            s+= "> three </option>";
            s+= "<option value=4";
            if (value == 4 ) { s+= " selected ";}
            s+= "> four </option>";
            s+="</select>";
            return s;
            I will put some more select examples from my views into the other topic.
            BR
            -Jokke
