    Embedded platform to run mango on - what ideas do people have
    20 Posts 12 Posters 19.6k Views 1 Watching
      profnova
      Why don't you use a plug pc like this one.
      http://www.geeky-gadgets.com/marvell-sheevaplug-tiny-linux-power-plug-pc/
      • F Offline
        fclauson
        Cool device - but what realistically is the smalles sensiable device for running Mango on
        I would have thought that this little block did not have enough memory
        Francis
          craig
          I was running mango with hundreds of points polling every 5-10s logging every 15 minutes with derby on IBM R50 laptops 1.5GHZ cpu single core and 512 mb ram and it worked, but I replaced the laptops with propers servers and I'm a lot happier now.
            Jokke
            Here is an old thread on the same topic.
            http://mango.serotoninsoftware.com/forum/posts/list/231.page
            Please see it for explanation about ARM CPU based systems like the sheevaplug. If there has not been anything new recently on JVM side, I would say those cannot be used with mango.
            In atom based systems I don't see any problem, using such currently.
            BR
            Jokke
            • Z Offline
              zatalian
              I would like to run mango on a beagleboard, but i'm also unsure about the preformance of java.
              Are there any (non graphical) benchmarks i could run?
              I found some vm's (zero, shark, cacao) that i could try, that seem to be faster... any idea if they are any good?
              It seems like android is ported to the beagleboard. Android uses java right? Or is this just simplistic thinking of me?
                I asked ARM about their Java support, but didn't find their response encouraging. They didn't say anything about any future plans.
                Note that Android is based upon Java, but is not anything close to a full JDK. I haven't tried it out myself, but i would not expect Mango to run on Android unmodified.
                  ... but, you may have better luck with [url=http://automation.serotoninsoftware.com]Mango Automation
                  • F Offline
                    ftomiBR
                    Is it possible to run 'mango automation' from an embedded OS without modifications?
                    I was looking at some nice ARM-based platforms like this http://www.friendlyarm.net/products/mini6410
                    It may not support mango but do you think would it be possible to use mango automation there?
                    • O Offline
                      oja
                      I think, that will be problem with JAVA version. Some sources are talking about J2ME edition for FriendlyArm or old 1.4 JDK .
                      I think about AlixBoards with AMD Geode
                        I've built 5 mango system using the Intel D510MO Mini-ITX Motherboard and either a solid state hard drive or a laptop hard drive and they work great. No fan, supper quite and very small.
                        I run Ununtu server 10.04 and in the end it makes a really nice package that costs about $250 in hardware.
                        I'd love to find a solution for $100 for monitoring just a few data points but haven't had time to experiment at all.
                          Porting Mango back to 1.4 would not be a trivial task but in theory is possible. We (Serotonin) would certainly be willing to discuss this as a commercial endeavour.
                            jalles
                            decidedly not in your price range:
                            http://www.dh-electronics.de/eindex.htm
                            generally they run Embedded WinXP, and provide LON support.
                            • H Offline
                              hugo007
                              This tuturial is for thoose want to build a small box to run Mango or ScadaBr
                              Since I was looking for a small pc I remember to use a Alix board that is more cheap than a pc and more compact and try to build a linux debian based system and them install MANGO
                              In this tuturial I will try to explain the steeps I take to sucssefuly install the debian and then the Mango. My choise of using mango was because I can't get ScadaBr running because of the installer script so I turn to Mango
                              In my configuration I will use:
                              An Arduino Duemilanove
                              an Alix Board 2D from PC Engines GmbH, can be bought at http://pcengines.ch/alix.htm
                              1 CF card 4Gb (for debian instalation and MANGO)
                              After a seach on google I found a website with some instrutions that help me to get all up and running
                              You can see all the instrutions where http://www.gooze.eu/howto/debian-installation-on-alix-board-howto/setting-time but for now I will try to resume some of then.
                              In case you have some dificult I sugest you to read the instrutions on the above link.
                              You will need a pc with a CFcard reader to start the instalation on the CFcard, in my case I'm using a Linux Mint distro but any other will do
                              I will assume you have some linux experience and soo I will not go to deep
                              Soo insert the CFcard on your reader.You will need to know waht was the /dev/sdXXX your system give to the CFcard. There are diferent ways to see this, I will describe 2 ways:
                              before insert the card open a console and type: "tail -f /var/log/messages" then insert the CFcard, you will see the text will flick and there you can read the /dev/sdXX that was assigned to your card
                              after that just hit CTRL+C to exit from the tail.Now you know the id of your device
                              Another way is just use the gparted wich is a disk tool to manage partitions on linux with a nice GUI.there you can also see the "/dev" id of your card
                              we will use the "dd" command to copy an image to CFcard with a prebuild of a debian instalation
                              open again a console in case you close the last one and download the image
                              $wget http://download.gooze.eu/embedded/debian/images/debian.tar.gz
                              then extact the tar using:
                              $tar -xvf debian.tar.gz
                              After that we can transfer the image to the CFcard using:
                              $ dd if=debian.img of=/dev/sd[b,c,d]
                              double check the command because if you make some mustake you can delete or harddrive!!!
                              it will take a while so just wait until you get the prompt again with the details of the duration and speed of the copy
                              After that remove the card and insert the CFcard on the alix board.Before you power it you will need a Serial cable to connect the alix board to your computer
                              You will also need a hiperterminal client, I had used gtkterm but you can use "screen" ou putty, its up to you.
                              The baud is 38400N,8,1
                              Open the port with with configuration and the power the alix board.
                              You should start to see some lines of a test memory wich is normal on the alix board and the wait until you see the debian instalation menu.This can take a while , do not remove the power, if soo perhaps you will need to reinstall the image of the last step
                              Follow the setup as normal(if you have trouble read the instrutions on the link I give above)
                              After the instalation is complete install ssh for remote acess.I will assume you already have internet conection on the alix
                              $apt-get install openssh-server
                              If you want to install mysql to support the Mango databases you can just install it by using:
                              $apt-get install mysql-server
                              Mango needs to have JAVA installed
                              In my case using "apt-get install sun-java6-jdk" it give me a message no package found then I had need to add a source to a new repository
                              use vi or nano and add the folowing line to /etc/apt/sources.list "deb http://archive.canonical.com/ lucid partner" without the " of course
                              Save it and update all sources using "apt-get update"
                              after that you should be able to install java then type "apt-get install sun-java6-jdk"
                              Then install a ntp package to automaticaly update the time of your system
                              $apt-get install ntpdate
                              $ntpdate pt.pool.ntp.org
                              In my case I'm using a Portuguese NTP server, adapt to your needs
                              after that confirm the date and time using
                              $date
                              It must display the right time and date now.
                              Now that we have all the requirements lets move to the MANGO instalation.
                              Visit the link http://mango.serotoninsoftware.com/download.jsp
                              Here we can find the parts we need
                              Open a console again and choose a location to store the instalation.I had installed on /usr
                              $cd /usr/local
                              Lets Dowload the TOMCAT:
                              $wget http://mango.serotoninsoftware.com/downloads/apache-tomcat-6.0.20.tar.gz
                              Extract it:
                              tar -xvf apache-tomcat-6.0.20.tar.gz
                              Rename the folder to tomcat just to be more simple
                              $ mv -R apache-tomcat-6.0.20 tomcat
                              $ cd tomcat/bin
                              For test the apachTomCat lets fireup it and see if it runs.To do this just do:
                              $ ./startup.sh
                              This will start the Service and now he would be able to open the welcome page of tomcat opening http://ip_of_box:8080
                              If you see the page you are ok, close it and lets stop it for now using :
                              $ ./shutdown.sh
                              Now we need to remove some folders inside the webapps/ROOT folder to store the MANGO
                              to do this use:
                              $cd /usr/local/tomcat/webapps/ROOT
                              Remove all folders using:
                              $rm -R
                              This will remove all folders and files on this location, we need to remove it because this is the root dir of tomcat, this are the files and folder displayed when you start Tomcat, since we want just the MANGO lets now dowload it for this directory and extact it were
                              Assuming you stil are in the same folder ("/usr/local/tomcat/webapps/ROOT") download the MANGO
                              $wget http://mango.serotoninsoftware.com/downloads/mango-1.13.0.tar.gz
                              Extact it :
                              $tar -xvf mango-1.13.0.tar.gz
                              To confirm all files and folder are now here just do an "ls -al" to list the directory:
                              $ls -al
                              you should see something like this:
                              root@supervisao:/usr/local/tomcat/webapps/ROOT# ls -al
                              total 28532
                              drwxr-xr-x 10 root root 4096 Jan 1 2000 .
                              drwxr-xr-x 7 root root 4096 May 14 2009 ..
                              drwxr-xr-x 12 root root 4096 Dec 19 15:52 WEB-INF
                              drwxr-xr-x 3 root root 4096 Dec 19 15:52 audio
                              drwxr-xr-x 3 root root 4096 Jan 1 2000 backup
                              -rw-r--r-- 1 root root 6619 Mar 6 2011 customViewExample.jsp
                              drwxr-xr-x 2 root root 4096 Dec 19 15:52 exception
                              drwxr-xr-x 18 root root 4096 Dec 18 23:34 graphics
                              drwxr-xr-x 3 root root 4096 Dec 19 15:52 images
                              -rw-r--r-- 1 root root 1712 Mar 6 2011 index.jsp
                              -rw-r--r-- 1 root root 29117044 Dec 19 15:52 mango-1.13.0.zip
                              drwxr-xr-x 3 root root 4096 Dec 19 15:52 resources
                              -rw-r--r-- 1 root root 2436 Mar 6 2011 soundmanager2.swf
                              -rw-r--r-- 1 root root 8119 Mar 6 2011 soundmanager2_flash9.swf
                              drwxr-xr-x 2 root root 4096 Jan 19 12:15 uploads
                              If this is your output to you are almost finish the instalation.
                              In my case In using an arduino to comunicate to outside world via USB port.In this case I need to include a file on java dir to be able to comunicate with serial ports ("dev/ttyUSB0 in my case")
                              If this is also your case lets just download the librxtxSerial.so and import it:
                              $wget http://mango.serotoninsoftware.com/downloads/librxtxSerial.so
                              Now we need to save in <jdk1.6-home>/jre/lib/i386
                              To find this location on your instalation just use:
                              $updatedb
                              $locate /jre/lib/i386
                              This will display the path of you java, now lets move the librxtxSerial.so to that location.Im my case it was:
                              $mv librxtxSerial.so /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/i386/
                              It's everything done
                              Lets start the Tomcat and test it on your alix Board:)
                              $cd /usr/local/tomcat/bin
                              $./startup.sh
                              In the first run the system will build the MANGO database soo it can take a while until the page loads.
                              It could take about 40 secounds soo be patient
                              When the page loads just enter the default login :admin admin and your MANGO small box is ready!!
                              I hope this tuturial help those you want to test it on a alix board.
                              I not a linux expert then it is possible to some steps could be wrong and could be a better way to do it.
                              This manual can be modified to get better and sugestions are acepted
                              email:hugo.santos@
