Pachube Rate Limit
I set up 1 feed with 9 data stream as a pachube publisher. I have the update event set to on change and snapshot send period of 15 minutes. I am not understanding why I get API rate increases every now and then. What in the configuration is causing such a high API request rate? Am I correct in assuming the the way I configured it should send changes to Pachube every 15 minutes? Or is every change in the point causing a pachube publish event regardless of the send period?
* Profile * Feeds * Favourites * Messages * Settings * SubscriptionsAPI request rates
You were last rate-limited less than a minute ago (on Fri Oct 15 04:36:04 +0000 2010).Requests using your API key were denied because you exceeded Pachube's rate limit policy.
Here are your API request counters for the last 3 minutes:
* 2010-10-15-04:36 --> 12 * 2010-10-15-04:35 --> 29 * 2010-10-15-04:34 --> 29 -
The publisher sends a message to Pachube every time a point value changes.
Well that would explain the spikes. :-)
I have simple feature request..Deadband option like that presented in the datalogger.
What is send period of 15 minutes do? It was not described in the help for this.
It sends a snapshot of all the points every 15 minutes.
