    Screens - jumps, drop down order
    User help
    4
    10
    3.9k
    • S
      skiv71
      hi,
      is it possible to jump to another screen via a click button?
      also, of the available screens, the list appears to be in the order of creation... can i sort this alphabetically? or as i see fit?
      thanks
      Neil
      • F
        ftomiBR
        Look at HTML, you can use something like this to create a custom drop down list
         <SCRIPT TYPE="text/javascript">
         function dropdown(mySel)
         var myWin, myVal;
         myVal = mySel.options[mySel.selectedIndex].value;
         if(myVal)
            if(mySel.form.target)myWin = parent[mySel.form.target];
            else myWin = window;
            if (! myWin) return true;
            myWin.location = myVal;
         return false;
         </SCRIPT>
         <FORM
         METHOD=POST onSubmit="return dropdown(this.gourl)">
         <SELECT NAME="gourl">
         <OPTION VALUE="">Choose a Destination...
         <OPTION VALUE="http://localhost/views.shtm?viewId=2">View 2
         <OPTION VALUE="http://localhostviews.shtm?viewId=3">View 3
         <OPTION VALUE="http://localhost/views.shtm?viewId=4">View 4
         </SELECT>
         <INPUT TYPE=SUBMIT VALUE="Go">
         </FORM>
        • F
          ftomiBR
          and here there is a button
          <FORM>
          <INPUT TYPE="BUTTON" VALUE="View 2" ONCLICK="window.location.href='http://localhost/views.shtm?viewId=2'">
          </FORM>
          I also would like to know if there is some script to use a datapoint value to decide if the option will be enabled or not.
          • M
            You could use a server-side script component to conditionally present the button.
            • F
              ftomiBR
              Yes, I've already realized that but actually I'm the PLC guy and got no clues on how to create this conditional button with 'onClick' event in pure javascript
              Could you please post some example?
              • P
                posztos
                Create a Server-side script, select the point on which displaying the button depends. This script should give you the idea:
                return value == 0 ? "" : "button";
                With the code above, if the selected point is 0 nothing is displayed, otherwise a button text is displayed.
                Regards,
                Greg
                • F
                  ftomiBR
                  nice but it do not works with html links or buttons, how can I create a link button there?
                  • F
                    ftomiBR
                    the problem was solved, need to supress the "" from the html code.
                    • F
                      ftomiBR
                      It may be an issue for server-script component
                      I used the property "disabled" in a button and saved the view.
                      When I try to edit the view, this component is also disabled.
                      So I need to enable the button using the datapoint logic to enable the component editing on the view.
