    Arduino and Mango Step by step working example
    8 Posts 4 Posters 24.7k Views 1 Watching
      JointTech
      1. Buy or make a Arduino
      2. Download the latest Arduino software I'm using 0020. http://arduino.cc/en/Main/Software
      3. If you are using Arduino Duemilanove or a similar board that runs off USB you’ll have to install the USB drivers. You can find them in the Arduino folder you just downloaded.
      4. plug in a TMP36 temp sensor as shown here: http://tinyurl.com/plbx38
        Plug it into Analog port 3 instead of 0 as shown in the link.
      5. Grab the modbus library from http://www.tucsni.nl/jee/ModbusSlave.zip
        you should check his site http://www.tucsni.nl/jee/ he actually says to use the new version here: http://sites.google.com/site/jpmzometa/arduino-mbrt/arduino-modbus-slave
        but I havent tested it.
      6. Unzip modbusslave.zip to your_arduino_install\libraries\ModBusSlave
      7. open the arduino IDE
      8. Paste the following code:
      #include <ModbusSlave.h>
      //TMP36 Pin Variables
      int temperaturePin = 3; //the analog pin the TMP36's Vout (sense) pin is connected to
                              //the resolution is 10 mV / degree centigrade
                              //(500 mV offset) to make negative temperatures an option
      int temptest = 1 ;
      //Arduino sketch example with 2 holding regs:
      void setup()
      	  /* Modbus setup example, the master must use the same COM parameters */
      	  /* 115200 bps, 8N1, two-device network */
      //	  regs[MB_REG0]=153;
      //	  regs[MB_REG1]=456;
      	  init_mb_slave(115200, 'n', 0);
      void loop()
          /* This is all for the Modbus slave */
          start_mb_slave(MB_SLAVE, regs, MB_REGS);
          /* your code goes here */
       float temperature = getVoltage(temperaturePin);  //getting the voltage reading from the temperature sensor
       temperature = (((temperature - .5) * 100)*1.8) + 32;          //converting from 10 mv per degree wit 500 mV offset
                                                        //to degrees ((volatge - 500mV) times 100)
      // Serial.println(temperature);
      // Serial.println(regs[MB_REG0]);    //printing the result
      // delay(100);
      temptest = (temperature);
      regs[MB_REG0]=temptest;
          /* handle write event */
          if (written.num_regs) {
      	  written.num_regs=0;
       * getVoltage() - returns the voltage on the analog input defined by
       * pin
      float getVoltage(int pin){
      return (analogRead(pin) * .004882814); //converting from a 0 to 1024 digital range
                                              // to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
      1. upload the code to your Arduino.
      2. Install Mango
      3. Create a new data source.
        [url=http://postimage.org/image/1kmj3h7pg/]image
      4. Create a new datapoint
        [url=http://postimage.org/image/1syvr8io4/]image
      5. you should now be seeing the current temperature updating every 5 seconds on your datapoint.
        You can breathe hard on your tmp36 to see the temp go up in mango.
      have fun.
      hope this helps somebody as it took me about 2 days of scouring the net to make it finally work.
        Nice. Thanks.
          jose francisco
          Hello.
          I'm trying to compile the sketch buy i get an error in "init_mb_slave(...)" not declared function.
          I think that the library i've got is newer because in new examples the configuration is done in this way:
          mbs.configure(SLAVE,BAUD,PARITY,TXENPIN);
          Can you comment this issue?
          thanks
            JointTech
            I would use the library here: http://www.tucsni.nl/jee/ModbusSlave.zip
            other than that I have no idea. probably question better for the arduino forums as well.
              jose francisco
              Sketch for new library from http://sites.google.com/site/jpmzometa/arduino-mbrt/arduino-modbus-slave
              With this code you can:
              -See the status of pin 2 in mango (MB_REG0)
              -set the status of pin 13 with mango (MB_CTRL)
              use offset 0,1,... in mango to use MB_REG0, MB_CTRL, MB_TIME,...
              #include &lt;ModbusSlave.h&gt;
              /* First step MBS: create an instance */
              ModbusSlave mbs;
              /* slave registers */
              enum {
                      MB_REG0,
                      MB_CTRL,        /* Led control on, off or blink */
                      MB_TIME,        /* blink time in milliseconds */
                      MB_CNT,        /* count the number of blinks */
                      MB_REGS	 	/* total number of registers on slave */
              int asdf=1;
              int regs[MB_REGS];
              int ledPin = 13;
              void setup()
              /* the Modbus slave configuration parameters */
              const unsigned char SLAVE = 1;
              const long BAUD = 9600;
              const char PARITY = 'n';
              const char TXENPIN = 1;
                     /* Second step MBS: configure */
                      pinMode(ledPin, OUTPUT);
                      pinMode(2,INPUT);
              void loop()
                     asdf=digitalRead(2);
                    regs[MB_REG0]=asdf;
                /* Third and las step MBS: update in loop*/
                     mbs.update(regs, MB_REGS);
                 if(regs[MB_CTRL]==1)
                   digitalWrite(ledPin,1);
                   else
                   digitalWrite(ledPin,0);
                JointTech
                Nice I was struggling with setting values. Ill have to give this a try.
                  relristein
                  I have a one question. I use the modbus serial for comunication. It is script:
                  /* First step MBS: create an instance /
                  ModbusSlave mbs;
                  slave registers */
                  enum {
                  MB_CTRL, /* Led control on, off or blink /
                  MB_TIME, /
                  blink time in milliseconds /
                  MB_CNT, /
                  count the number of blinks /
                  MB_REGS /
                  int regs[MB_REGS];
                  int ledPin = 13;
                  void setup()
                  /* the Modbus slave configuration parameters /
                  void loop()
                  else{
                  But i want a blink effect in led and i modified the script:
                  delay(3000);
                  delay(3000);
                  else{
                  Well, when i set the bit 1, the led blink but it don't enter in the else.
                  Anyone had the same problem with supervisory and script?
                  tank's
                  *sorry, my english is very weak.
                  With your input, this post could be even better đź’—
