Arduino and Mango Step by step working example
Buy or make a Arduino
Download the latest Arduino software I'm using 0020. http://arduino.cc/en/Main/Software
If you are using Arduino Duemilanove or a similar board that runs off USB you’ll have to install the USB drivers. You can find them in the Arduino folder you just downloaded.
plug in a TMP36 temp sensor as shown here: http://tinyurl.com/plbx38
Plug it into Analog port 3 instead of 0 as shown in the link. -
Grab the modbus library from http://www.tucsni.nl/jee/ModbusSlave.zip
you should check his site http://www.tucsni.nl/jee/ he actually says to use the new version here: http://sites.google.com/site/jpmzometa/arduino-mbrt/arduino-modbus-slave
but I havent tested it. -
Unzip modbusslave.zip to your_arduino_install\libraries\ModBusSlave
open the arduino IDE
Paste the following code:
#include <ModbusSlave.h> //TMP36 Pin Variables int temperaturePin = 3; //the analog pin the TMP36's Vout (sense) pin is connected to //the resolution is 10 mV / degree centigrade //(500 mV offset) to make negative temperatures an option int temptest = 1 ; //Arduino sketch example with 2 holding regs: void setup() { /* Modbus setup example, the master must use the same COM parameters */ /* 115200 bps, 8N1, two-device network */ // regs[MB_REG0]=153; // regs[MB_REG1]=456; init_mb_slave(115200, 'n', 0); } void loop() { /* This is all for the Modbus slave */ start_mb_slave(MB_SLAVE, regs, MB_REGS); /* your code goes here */ float temperature = getVoltage(temperaturePin); //getting the voltage reading from the temperature sensor temperature = (((temperature - .5) * 100)*1.8) + 32; //converting from 10 mv per degree wit 500 mV offset //to degrees ((volatge - 500mV) times 100) // Serial.println(temperature); // Serial.println(regs[MB_REG0]); //printing the result // delay(100); temptest = (temperature); regs[MB_REG0]=temptest; /* handle write event */ if (written.num_regs) { /// .... written.num_regs=0; } } /* * getVoltage() - returns the voltage on the analog input defined by * pin */ float getVoltage(int pin){ return (analogRead(pin) * .004882814); //converting from a 0 to 1024 digital range // to 0 to 5 volts (each 1 reading equals ~ 5 millivolts }
upload the code to your Arduino.
Install Mango
Create a new data source.
[url=http://postimage.org/image/1kmj3h7pg/] -
Create a new datapoint
[url=http://postimage.org/image/1syvr8io4/] -
you should now be seeing the current temperature updating every 5 seconds on your datapoint.
You can breathe hard on your tmp36 to see the temp go up in mango.
have fun.
hope this helps somebody as it took me about 2 days of scouring the net to make it finally work. -
Nice. Thanks.
Hello.
I'm trying to compile the sketch buy i get an error in "init_mb_slave(...)" not declared function.
I think that the library i've got is newer because in new examples the configuration is done in this way:
mbs.configure(SLAVE,BAUD,PARITY,TXENPIN);
Can you comment this issue?
thanks -
I would use the library here: http://www.tucsni.nl/jee/ModbusSlave.zip
other than that I have no idea. probably question better for the arduino forums as well. -
Sketch for new library from http://sites.google.com/site/jpmzometa/arduino-mbrt/arduino-modbus-slave
With this code you can:
-See the status of pin 2 in mango (MB_REG0)
-set the status of pin 13 with mango (MB_CTRL)use offset 0,1,... in mango to use MB_REG0, MB_CTRL, MB_TIME,...
#include <ModbusSlave.h> /* First step MBS: create an instance */ ModbusSlave mbs; /* slave registers */ enum { MB_REG0, MB_CTRL, /* Led control on, off or blink */ MB_TIME, /* blink time in milliseconds */ MB_CNT, /* count the number of blinks */ MB_REGS /* total number of registers on slave */ }; int asdf=1; int regs[MB_REGS]; int ledPin = 13; void setup() { /* the Modbus slave configuration parameters */ const unsigned char SLAVE = 1; const long BAUD = 9600; const char PARITY = 'n'; const char TXENPIN = 1; /* Second step MBS: configure */ mbs.configure(SLAVE,BAUD,PARITY,TXENPIN); pinMode(ledPin, OUTPUT); pinMode(2,INPUT); } void loop() { asdf=digitalRead(2); regs[MB_REG0]=asdf; /* Third and las step MBS: update in loop*/ mbs.update(regs, MB_REGS); if(regs[MB_CTRL]==1) digitalWrite(ledPin,1); else digitalWrite(ledPin,0); }
Nice I was struggling with setting values. Ill have to give this a try.
I have a one question. I use the modbus serial for comunication. It is script:
/* First step MBS: create an instance /
ModbusSlave mbs;
/ slave registers */
enum {MB_CTRL, /* Led control on, off or blink /
MB_TIME, / blink time in milliseconds /
MB_CNT, / count the number of blinks /
MB_REGS / total number of registers on slave */};
int regs[MB_REGS];
int ledPin = 13;void setup()
{/* the Modbus slave configuration parameters /
/ Second step MBS: configure */
pinMode(ledPin, OUTPUT);}
void loop()
else{
But i want a blink effect in led and i modified the script:
delay(3000);
delay(3000);
else{
}Well, when i set the bit 1, the led blink but it don't enter in the else.
Anyone had the same problem with supervisory and script?
tank's
*sorry, my english is very weak.
