    Pachube
    15 Posts 4 Posters 12.4k Views 1 Watching
      I'm playing around with Pachube and it looks really interesting. I don't know if I'm the only one but their website seems so confusing although I'm starting to understand it.
      I created an input but I can not find the feed ID or datastream ID that the Mango publisher asks for
      I also couldn't find this for an output that I wanted to map to a Pachube data source in Mango
      I would greatly appreciate being pointed in the right direction.
      Thanks.
        After playing around a bit more I'm going to answer my own question.
        The feed ID is the number at the end of the URL that ends in xml. Looks like for now they are 4 digit numbers but looks like will soon go to 5 as more people create feeds.
        The Data Stream ID is the number that shows up on the far left of the datapoints under that feed. These numbers seem to usually start at 0 and go up.
        The mistake I made was I set up a feed but did not add any data streams which is why I couldn't find it's number.
          All correct. The feed ids appear to be sequential, so they will eventually become 5 digit numbers, yes. And data stream ids are automatically generated starting from 0, but i believe they can be overridden with custom labels.
            peadar
            hi, well done with the recent version of mango! this product just keeps improving day by day..
            i set up a basic pachube publisher and all seems work fine under the free account from pachube.
            my test scenario:
            i read two fields from a database and then use the pachube publisher to send to pachube.
            however i cant seem to stay under the rate limit! i understand the limitations and and am happy to comply, however, when i look at my upload stats on the pachube site, it says i'm publishing too many per minute.
            my question: how does one slow down the rate at which mango publishes to pachube?
            i've tried sending on "all updates" which seems to blast pachube with reems of data.
            my data changes about once every minute, my sql data source collects every 2 minutes.
            If i set to "changes only" it works ok until a data change which then blasts the pachube with up to 28 api requests in 7 seconds.
            i know i'm missing something, i just cant see what :-)
            please let me know if i've got something wrong...
            Peadar
              What version are you using? A problem was discovered in 1.9.0, and fixed in 1.10.0. Some quick testing didn't reveal any 1.10.0 issues like you describe.
                peadar
                its the latest upgrade 1.10.0
                  peadar
                  ah think i made a mistake
                  its working now
                  will come back later and explain...sorry
                    peadar
                    Ok, i'm gonna volunteer a walkthrough to integrating with pachube...it should be ready by the end of the day...
                    Pachube are a bit weak on the documentation side, despite the absolutely fantastic product they have.
                    i think the 'mango - pachube' marriage is one made in (ahem...geek) heaven :-)
                    anyhoo....watch this space :-)
                    ps. thanks again for the quick reply...
                      peadar
                      Ok, here's a quick and dirty guide on how to create a pachube publisher in mango to a pachube feed
                      1. 'signup' for a free account with pachube at www.pachube.com
                      2. you'll be sent a welcome email with an API key, so copy that key to the clipbaord
                      3. go back and sign in to pachube
                      **4. ** on the right hand side of the page, click "register a feed"
                      feed type = Manual
                      feed title = test
                      then click 'add' under datastreams
                      ID = 1
                      type = basicSI
                       add another datastream
                      ID = 2
                      type = basicSI
                      	these are your 'Datastream ID"s for mango
                      5. Now click 'save feed' and you'll be taken to your feeds page:
                      **6. ** note the 4 or 5 digit number just before ".xml", ".csv", ".json". this is your 'Feed ID' for mango.
                      **7. ** Create a pachube publisher in Mango
                      name = test
                      update events = changes only
                      send regular snapshots = Do not Tick
                      API Key = paste in the key from the welcome email from pachube
                      Add one or two points you'd like to publish, then fill in the boxes:
                      	Feed ID = see step 6
                      	Datastream ID = see step 4
                      8. click 'save' and enable the publisher.
                      9. if all goes well, you should be able to see a green 'live' in your "my feeds" page on pachube.
                      Bear in mind this may take a few minutes to come live. mine took about 5-10 mins initially.
                      10. click "use a feed" on the right of the page to see what you can now do with all this data flying about the internet
                      11. let me know how you get on :-)
                      here's one i did earlier:
                      http://www.securi-trax.com/?p=141
                        Thanks for this peadar. Can you describe what was going wrong before so that others can avoid, or so that the software can be enhanced to avoid?
                          peadar
                          nothing wrong with mango at all!
                          The hiccup is, its not so clear from an initial glance how mango correlates to pachube in relation to feed ID and Datastream ID.
                          It's easy now i understand it, but is a steep learning curve for a novice like me. Plus Pachube is a little weak on the documentation side of things
                          in my case i didn't put the correct 'Feed ID' into mango so although the publisher was sending the API key and getting a response, it was a 404 or 503 response, so i imagine mango just kept trying to send it until a 200 would come back.
                          sorry for the confusion, i'll try not to accomplish large tasks like this at night time...all was clear after a few hours kip :-)
                          hope that can help a few of the members
                          Peadar
                            Ok, thanks. We'll take a look at how non-200 responses are getting handled and see if there's anything more elegant than pounding Pachube with requests.
                              Follow-up: the pachube send thread has been changed so that 4xx-type HTTP errors are treated as non-recoverable, under the assumption that the same request sent again will have the same result. This will prevent the publisher from trying to resend the same data over and over, and your receiving a complaint from Pachube.
                                mhradom
                                I am successfully pushing data out to Pachube from Mango. Thanks for the tutorial above it was a BIG help. Pachube documentation is lacking or hard to find. Go to www.pachube.com and type in "Mikes House" in the search field and you will see me on the map. Double click the push pin and you will find my first few feeds. More to come. I gave Mango a little plug there as well.
