Problem testing Modbus IP Data Source
I've created a modbus IP data source and data point.
I'm also running this server in localhost:502 http://code.google.com/p/modbus-tk/source/browse/trunk/examples/tcpslave_example.pyIf I use th scan nodes feature, Mango successfully finds the single slave in the server. But if I create a Data point for the slave 1 no data is recorded in Mango and no output appears in the server stdout.
Am I missing something? This is supposed to work.
Note that registers in Mango are 0-indexed. Modbus documentation is sometimes 1-index. Try subtracting 1 from your register and see if that works.
Tried it, but same result: none.
In the Python script I dont see any request from Mango. I did see it while using the "Search for nodes" feature.
Sorry, i can't help much. I've never used that toolkit. But using the Modbus4J listener test i was able to successfully connect, read and write. Are you sure you're using the right register values?
Is there a way to test if Mango is sendign the modbus ip pabkets over the net?
Wireshark?
Seems I cant capture traffic in the loopbak interface http://wiki.wireshark.org/CaptureSetup/Loopback
