<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem testing Modbus IP Data Source]]></title><description><![CDATA[<p dir="auto">I've created a modbus IP data source and data point.<br />
I'm also running this server in localhost:502 <a href="http://code.google.com/p/modbus-tk/source/browse/trunk/examples/tcpslave_example.py" rel="nofollow ugc">http://code.google.com/p/modbus-tk/source/browse/trunk/examples/tcpslave_example.py</a></p>
<p dir="auto">If I use th scan nodes feature, Mango successfully finds the single slave in the server. But if I create a Data point for the slave 1 no data is recorded in Mango and no output appears in the server stdout.</p>
<p dir="auto">Am I missing something? This is supposed to work.</p>
]]></description><link>https://forum.mango-os.com/topic/366/problem-testing-modbus-ip-data-source</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 02:39:56 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/366.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Apr 2010 17:50:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem testing Modbus IP Data Source on Wed, 14 Apr 2010 15:00:59 GMT]]></title><description><![CDATA[<p dir="auto">Seems I cant capture traffic in the loopbak interface <a href="http://wiki.wireshark.org/CaptureSetup/Loopback" rel="nofollow ugc">http://wiki.wireshark.org/CaptureSetup/Loopback</a></p>
]]></description><link>https://forum.mango-os.com/post/3607</link><guid isPermaLink="true">https://forum.mango-os.com/post/3607</guid><dc:creator><![CDATA[jjconti]]></dc:creator><pubDate>Wed, 14 Apr 2010 15:00:59 GMT</pubDate></item><item><title><![CDATA[Reply to Problem testing Modbus IP Data Source on Wed, 14 Apr 2010 14:36:07 GMT]]></title><description><![CDATA[<p dir="auto">Wireshark?</p>
]]></description><link>https://forum.mango-os.com/post/3606</link><guid isPermaLink="true">https://forum.mango-os.com/post/3606</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Wed, 14 Apr 2010 14:36:07 GMT</pubDate></item><item><title><![CDATA[Reply to Problem testing Modbus IP Data Source on Wed, 14 Apr 2010 14:28:32 GMT]]></title><description><![CDATA[<p dir="auto">Is there a way to test if Mango is sendign the modbus ip pabkets over the net?</p>
]]></description><link>https://forum.mango-os.com/post/3605</link><guid isPermaLink="true">https://forum.mango-os.com/post/3605</guid><dc:creator><![CDATA[jjconti]]></dc:creator><pubDate>Wed, 14 Apr 2010 14:28:32 GMT</pubDate></item><item><title><![CDATA[Reply to Problem testing Modbus IP Data Source on Tue, 13 Apr 2010 19:12:16 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, i can't help much. I've never used that toolkit. But using the Modbus4J listener test i was able to successfully connect, read and write. Are you sure you're using the right register values?</p>
]]></description><link>https://forum.mango-os.com/post/3604</link><guid isPermaLink="true">https://forum.mango-os.com/post/3604</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 13 Apr 2010 19:12:16 GMT</pubDate></item><item><title><![CDATA[Reply to Problem testing Modbus IP Data Source on Tue, 13 Apr 2010 18:50:31 GMT]]></title><description><![CDATA[<p dir="auto">Tried it, but same result: none.</p>
<p dir="auto">In the Python script I dont see any request from Mango. I did see it while using the "Search for nodes" feature.</p>
]]></description><link>https://forum.mango-os.com/post/3603</link><guid isPermaLink="true">https://forum.mango-os.com/post/3603</guid><dc:creator><![CDATA[jjconti]]></dc:creator><pubDate>Tue, 13 Apr 2010 18:50:31 GMT</pubDate></item><item><title><![CDATA[Reply to Problem testing Modbus IP Data Source on Tue, 13 Apr 2010 17:56:27 GMT]]></title><description><![CDATA[<p dir="auto">Note that registers in Mango are 0-indexed. Modbus documentation is sometimes 1-index. Try subtracting 1 from your register and see if that works.</p>
]]></description><link>https://forum.mango-os.com/post/3602</link><guid isPermaLink="true">https://forum.mango-os.com/post/3602</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 13 Apr 2010 17:56:27 GMT</pubDate></item></channel></rss>
