    Building Mango in Eclipse
    42 Posts 13 Posters 89.6k Views 1 Watching
      mmn666
      Hi mlohbihler,
      yes this folder exist and have into:
      /audio
      /exception
      /graphics
      /images
      /resources
      /uploads
      /WEB-INF
      customViewExample.jsp
      index.jsp
      soundmanager2.swf
      soundmanager2_flash9.swf
      i guess the ant is used to build and get what i need to build the project and deploy.
      but i don't use the ant because Andras said this is not necessary
      sorry my ignorance...
      and thanks for your patience
      regards,
      Mario
        What do you see when you hit http://localhost:8080/manager/list (changing host info as necessary)? This assumes that you left the manager application in the deployment. You should be able to find your u/p in the conf/tomcat-users.xml file.
          mmn666
          I try do everything from beginning again...because i could't access http://localhost:8080/manager/list
          so i install the tomcat6 again
          and when i try build i have another error
           [copy] Copying 2797 files to /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango
          BUILD FAILED
          /home/mario/workspace7/SuperMango/build.xml:117: Failed to copy /home/mario/workspace7/SuperMango/build/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class to /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class due to java.io.FileNotFoundException /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class (No such file or directory)
          Total time: 3 seconds
          regards,
          Mario
            Andras
            Regarding your problem to access the manager: did you check that the manager role was assigned to the user with which you tried to access the manager ?
            In conf/tomcat-users.xml you should have something like
            <tomcat-users>
            <role rolename="manager"/>
            <user username="manager" password="manager" roles="manager"/>
            </tomcat-users>
            to be able to access http://localhost:8080/manager/html with user manager
              mmn666
              Hi Andras,
              in my tomcat-users.xml i have this
              <tomcat-users>
              <role rolename="tomcat"/>
              <role rolename="role1"/>
              <user username="tomcat" password="tomcat" roles="tomcat"/>
              <user username="manager" password="manager" roles="tomcat,manager"/>
              <user username="both" password="tomcat" roles="tomcat,role1"/>
              <user username="role1" password="tomcat" roles="role1"/>
              </tomcat-users>
              and in my build.properties i have
              tomcat.home=/home/mario/Programas/apache-tomcat-6.0.20
              tomcat.manager.url=http://localhost:8080/manager
              tomcat.manager.username=manager
              tomcat.manager.password=manager
              tomcat.hostname=webapps/ROOT
              App name and app path are separated to accomodate root deployments. (i.e. 'ROOT' vs. '/')
              tomcat.appdir=mango
              tomcat.apppath=/mango
              and when i run the build.xml to createConfigFiles
              Buildfile: /home/mario/workspace7/SuperMango/build.xml
              createConfigFiles:
              [copy] Copying 1 file to /home/mario/workspace7/SuperMango/build/WEB-INF/classes
              BUILD SUCCESSFUL
              Total time: 466 milliseconds
              but when i run to deploy[default]
              compile:
              static:
              build:
              copy:
              [copy] Copying 2797 files to /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango
              BUILD FAILED
              /home/mario/workspace7/SuperMango/build.xml:117: Failed to copy /home/mario/workspace7/SuperMango/build/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class to /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class due to java.io.FileNotFoundException /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class (No such file or directory)
              Total time: 2 seconds
              other thing i observe is the fact when i started tomcat by the eclipse, i can't access the "http://localhost:8080/" , returning a HTTP Status 404
              but when i started the tomcat by console like root, i can access the homepage of tomcat("http://localhost:8080/") and "http://localhost:8080/manager/html" normally
              regards,
              Mario
                Hi Mario,
                If you're going to have a context path of "mango", then your hostname should not include "ROOT". Try changing the following build.properties value:
                  mmn666
                  Hi mlohbihler,
                  i changed to
                  but don't have any effect...
                  compile:
                  static:
                  build:
                  copy:
                  BUILD FAILED
                  regards,
                  Mario
                    Maybe a silly question, but can you say how much of this path actually exists:
                      mmn666
                      maybe is not a silly question hehehehe
                      only this is real
                      regards,
                      Mario
                        Incidentally, i strongly recommend changing the password in your tomcat-users file. There is a known crawler that looks for unprotected Tomcat instances and uses the manager to upload and start applications.
                          That comment above was for all forum users, not just Mario.
                          So, Mario, are you sure the user under which the build is running has permissions to write to the "webapps" directory?
                            mmn666
                            Hi mlohbihler,
                            i change the permission and works now i have the folder
                            and the build is ok
                            compile:
                            static:
                            build:
                            copy:
                            deploy:
                            BUILD SUCCESSFUL
                            Total time: 26 seconds
                            now i will try access http://localhost:8080/mango
                            right?
                            regards,
                            Mario
                              Sure, give it a try.
                                mmn666
                                i try access http://localhost:8080/mango/(http://localhost:8080/mango/login.htm) and i have a error report
                                com.serotonin.web.dwr.LocalizableMessageConverter.convertOutbound(LocalizableMessageConverter.java:25)
                                and like in topic
                                http://mango.serotoninsoftware.com/forum/posts/list/345.page
                                the problem is my browser the firefox,when i desativated a plugin... ...works!!!
                                thank you very much...
                                hartelijk dank
                                best regards,
                                Mario
                                  You're using 1.8.1? That problem should have been fixed.
                                  Give this jar file a try, but keep the old one just in case it all goes horribly wrong.
                                    Jay
                                    Hi all,
                                    I'm having a problem running/compiling mango using eclipse, and was wondering if someone here might know what I did wrong...
                                    I've followed all the steps described by Andras to build the project in Eclipse, including "add external jar" to add the following jars from ${tomcat.home}/lib
                                    servlet-api
                                    jsp-api
                                    When I try to build, I get several compile errors starting with
                                    [javac] C:\Dev\testing\workspace\Mango\src\com\serotonin\mango\vo\User.java:26: package javax.servlet.http does not exist
                                    [javac] import javax.servlet.http.HttpSessionBindingEvent;
                                    Finally, I copied the files
                                    servlet-api.jar and
                                    jsp-api.jar
                                    into ...war\WEB-INF\lib.
                                    Then the build process successfully compiles and copies files to Tomcat's webapps folder. In fact, it does this even if I remove the "external jars" servlet-api and jsp-api from classpath (using eclipse)!
                                    However, when I try to run the application, it returns a HTTP Status 500 page with a null pointer exception in javax.servlet.http.HttpServlet.service
                                    org.apache.jasper.JasperException: java.lang.NullPointerException
                                    org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:536)
                                    org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:368)
                                    org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
                                    org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
                                    javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
                                    I suspect this is related to the servlet-api jar.
                                    Anyone have any suggestions...?
                                    Jay
                                      jmo
                                      I'm having the same problem...
                                      I'll work on it more tonight or tomorrow and see what happens...
                                      • L Offline
                                        lordportux
                                        hello team!
                                        I´m trying to build mango source 1.12.4 and I got the next error:
                                        > [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\DataSourceVO.java:434: error: name has private access in DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.head.name", from.name, name);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\DataSourceVO.java:435: error: xid has private access in DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "common.xid", from.xid, xid);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\DataSourceVO.java:436: error: enabled has private access in DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "common.enabled", from.enabled, enabled);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\br\org\scadabr\vo\dataSource\dnp3\Dnp3DataSourceVO.java:164: error: rbePeriodType has private access in Dnp3DataSourceVO
                                        [javac]         AuditEventType.maybeAddPeriodChangeMessage(list, "dsEdit.dnp3.rbePeriod", from.rbePeriodType,
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\br\org\scadabr\vo\dataSource\dnp3\Dnp3DataSourceVO.java:165: error: rbePollPeriods has private access in Dnp3DataSourceVO
                                        [javac]                 from.rbePollPeriods, rbePeriodType, rbePollPeriods);
                                        [javac]                     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\br\org\scadabr\vo\dataSource\dnp3\Dnp3DataSourceVO.java:166: error: synchPeriods has private access in Dnp3DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.dnp3.synchPeriod", from.synchPeriods, synchPeriods);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\br\org\scadabr\vo\dataSource\dnp3\Dnp3DataSourceVO.java:167: error: staticPollPeriods has private access in Dnp3DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.dnp3.staticPeriod", from.staticPollPeriods,
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\br\org\scadabr\vo\dataSource\dnp3\Dnp3DataSourceVO.java:169: error: sourceAddress has private access in Dnp3DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.dnp3.sourceAddress", from.sourceAddress,
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\br\org\scadabr\vo\dataSource\dnp3\Dnp3DataSourceVO.java:171: error: slaveAddress has private access in Dnp3DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.dnp3.slaveAddress", from.slaveAddress, slaveAddress);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\br\org\scadabr\vo\dataSource\dnp3\Dnp3DataSourceVO.java:172: error: retries has private access in Dnp3DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.dnp3.retries", from.retries, retries);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\br\org\scadabr\vo\dataSource\dnp3\Dnp3DataSourceVO.java:173: error: retries has private access in Dnp3DataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.modbus.retries", from.retries, retries);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:207: error: updatePeriodType has private access in ModbusDataSourceVO
                                        [javac]         AuditEventType.maybeAddPeriodChangeMessage(list, "dsEdit.updatePeriod", from.updatePeriodType,
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:208: error: updatePeriods has private access in ModbusDataSourceVO
                                        [javac]                 from.updatePeriods, updatePeriodType, updatePeriods);
                                        [javac]                     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:209: error: quantize has private access in ModbusDataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.quantize", from.quantize, quantize);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:210: error: timeout has private access in ModbusDataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.modbus.timeout", from.timeout, timeout);
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:211: error: retries has private access in ModbusDataSourceVO
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:212: error: contiguousBatches has private access in ModbusDataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.modbus.contiguousBatches", from.contiguousBatches,
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:215: error: createSlaveMonitorPoints has private access in ModbusDataSourceVO
                                        [javac]                 from.createSlaveMonitorPoints, createSlaveMonitorPoints);
                                        [javac]                     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:216: error: maxReadBitCount has private access in ModbusDataSourceVO
                                        [javac]         AuditEventType.maybeAddPropertyChangeMessage(list, "dsEdit.modbus.maxReadBitCount", from.maxReadBitCount,
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:219: error: maxReadRegisterCount has private access in ModbusDataSourceVO
                                        [javac]                 from.maxReadRegisterCount, maxReadRegisterCount);
                                        [javac]                     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\vo\dataSource\modbus\ModbusDataSourceVO.java:221: error: maxWriteRegisterCount has private access in ModbusDataSourceVO
                                        [javac]                 from.maxWriteRegisterCount, maxWriteRegisterCount);
                                        [javac]                     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:35: error: DummyServletContext is not abstract and does not override abstract method getJspConfigDescriptor() in ServletContext
                                        [javac] public class DummyServletContext implements ServletContext {
                                        [javac]        ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:54: error: getAttributeNames() in DummyServletContext cannot implement getAttributeNames() in ServletContext
                                        [javac]     public Enumeration<?> getAttributeNames() {
                                        [javac]                           ^
                                        [javac]   return type Enumeration<?> is not compatible with Enumeration<String>
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:77: error: getInitParameterNames() in DummyServletContext cannot implement getInitParameterNames() in ServletContext
                                        [javac]     public Enumeration<?> getInitParameterNames() {
                                        [javac]                           ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:155: error: getServletNames() in DummyServletContext cannot implement getServletNames() in ServletContext
                                        [javac]     public Enumeration<?> getServletNames() {
                                        [javac]                           ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:161: error: getServlets() in DummyServletContext cannot implement getServlets() in ServletContext
                                        [javac]     public Enumeration<?> getServlets() {
                                        [javac]                           ^
                                        [javac]   return type Enumeration<?> is not compatible with Enumeration<Servlet>
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:131: error: getResourcePaths(String) in DummyServletContext cannot implement getResourcePaths(String) in ServletContext
                                        [javac]     public Set<?> getResourcePaths(String arg0) {
                                        [javac]                   ^
                                        [javac]   return type Set<?> is not compatible with Set<String>
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:53: error: method does not override or implement a method from a supertype
                                        [javac]     @Override
                                        [javac]     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:76: error: method does not override or implement a method from a supertype
                                        [javac]     @Override
                                        [javac]     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:130: error: method does not override or implement a method from a supertype
                                        [javac]     @Override
                                        [javac]     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:154: error: method does not override or implement a method from a supertype
                                        [javac]     @Override
                                        [javac]     ^
                                        [javac] C:\Users\Lordportux\workspace\myMangoBranch\src\com\serotonin\mango\util\test\DummyServletContext.java:160: error: method does not override or implement a method from a supertype
                                        [javac]     @Override
                                        [javac]     ^
                                        [javac] Note: Some input files use or override a deprecated API.
                                        [javac] Note: Recompile with -Xlint:deprecation for details.
                                        [javac] 32 errors
                                        what's the problem? :(
                                          johnparker16
                                          In addition, i suggest modifying the code in your tomcat-users computer file. There is a known crawler that looks for credit card Tomcat circumstances and uses the administrator to publish and start programs.
                                            chahin
                                            am trying to run th build.xml file but i found some Error :shock: :
                                            for example : /*** Compiling 616 source files to C:\workspace-pfe\mango\build\WEB-INF\classes
                                            [javac] C:\workspace-pfe\mango\src\com\serotonin\mango\vo\User.java:26: error: package javax.servlet.http does not exist
                                            [javac] import javax.servlet.http.HttpSessionBindingEvent; ***/
                                            help please :cry:
                                            REM: i download the code source from http://sourceforge.net/projects/scadabr/files/Software/mango-src/mango-source-1.12.3.zip/download (VERSION 1.12.3)
