    Vieuw.jsp error
    User help
    2
    14
    4.8k
    • S
      sprokkie
      when i try the view.jsp page i got this error
      DEBUG: DEPRECATED: dojo.widget.Manager.getImplementationName Could not locate widget implementation for "simplepoint" in "view.widget" registered to namespace "view". Developers must specify correct namespaces for all non-Dojo widgets -- will be removed in version: 0.5
      What did i fill in wrong ?
      i chanced the change me in the view-xid
      sprokkie
      • M
        Can you post your code?
        • S
          sprokkie
          Mango - Open Source M2M - http://mango.serotoninsoftware.com
          Copyright (C) 2006-2009 Serotonin Software Technologies Inc.
          @author Matthew Lohbihler
          This program is free software: you can redistribute it and/or modify
          it under the terms of the GNU General Public License as published by
          the Free Software Foundation, either version 3 of the License, or
          (at your option) any later version.
          This program is distributed in the hope that it will be useful,
          but WITHOUT ANY WARRANTY; without even the implied warranty of
          MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
          GNU General Public License for more details.
          You should have received a copy of the GNU General Public License
          along with this program.  If not, see http://www.gnu.org/licenses/.
          --%><%@ include file="/WEB-INF/jsp/include/tech.jsp" %>
          <%@ taglib prefix="view" tagdir="/WEB-INF/tags/view" %>
          <html>
          <head>
          <link href="resources/common.css" type="text/css" rel="stylesheet"/>
          <view:init username="admin"/>
          </head>
          <body>
          <h1>Custom View Example</h1>
          <p>
          The active components of this example have been commented out. To reactivate, remove the <%-- --%> style
          comment tags (but not what is between them!) and replace the view:init username and all xid attributes with valid
          values.
          </p>
          <p>
          <b>You will receive errors if you do not provide valid attribute values!</b> Read the error messages for clues about
          what needs to be fixed. You can remove these instructions when you are done.
          </p>
          <p>
          You can create as many custom views as you want. Simply create a new JSP file in the main directory (where the
          index.jsp is).
          </p>
          <h3>A simple table of some values</h3>
          <table>
          <tr>
          A simplePoint tag is used to display the value of a single point.
          - xid: the point to use (required)
          - disabledValue: the value to display if the point is disabled (defaults to "")
          - raw: whether the value should be fully rendered according to the text renderer, or should be provided in its
          raw form. For example, a raw numeric is does not include a suffix, a raw multistate is its integer value,
          and a raw binary is 0 or 1. (Defaults to false).
          <td align="right" style="padding-right:20px">A point value:</td>
          <td><view:simplePoint xid="DS_337334" disabledValue="(disabled)"/></td>
          </tr>
          <tr>
          <td align="right" style="padding-right:20px">A raw point value:</td>
          <td><view:simplePoint xid="DS_301245" raw="true"/></td>
          </tr>
          </table>
          Display charts with the chart tag. Include points in the chart with the chartPoint child tag. Most attributes should
          require no explanation.
          - color: this attribute can be an HTML-style hex, or any color name in the HTML specification.
          <h3>A chart</h3>
          <view:chart duration="1" durationType="hours" width="800" height="300">
          <view:chartPoint xid="DS_3011245" color="#2468AC"/>
          </view:chart>
          </body>
          </html>
          sprokkie
          • M
            Do the point references (DS_337334, DS_301245, and DS_3011245) actually reference valid points? When i use the same code in my instance and update the references, the code works fine.
            • S
              sprokkie
              DS_3011245 was wrong it should be DS_301245.
              I corrected that and now i have this error
              DEBUG: dojo.widget.Parse: error: [Error: Could not locate widget implementation for "simplepoint" in "view.widget" registered to namespace "view", file: http://172.16.100.226:8090/resources/dojo/dojo.js, line: 9096]
              strange isn't it
              • M
                The dojo errors will go away when the other issues are corrected. Check for messages in your Tomcat console. There will likely be a message there that indicates what you should do.
                • M
                  For example, i got this message before i corrected the problem:
                  Stacktrace:
                          at org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:505)
                          at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:398)
                          at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:342)
                          at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:267)
                          at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
                          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
                          at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
                          at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
                          at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
                          at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
                          at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
                          at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
                          at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
                          at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
                          at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
                          at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
                          at java.lang.Thread.run(Thread.java:619)
                  Caused by: javax.servlet.ServletException: javax.servlet.jsp.JspException: Point with XID 'DS_337334' not found
                          at org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:862)
                          at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:791)
                          at org.apache.jsp.testCustom_jsp._jspService(testCustom_jsp.java:142)
                          at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
                          at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:374)
                          ... 15 more
                  Caused by: javax.servlet.jsp.JspException: Point with XID 'DS_337334' not found
                          at com.serotonin.mango.web.taglib.ViewTagSupport.getDataPointVO(ViewTagSupport.java:48)
                          at com.serotonin.mango.web.taglib.SimplePointTag.doStartTag(SimplePointTag.java:59)
                          at org.apache.jsp.tag.web.view.simplePoint_tag._jspx_meth_mango_005fsimplePoint_005f0(simplePoint_tag.java:137)
                          at org.apache.jsp.tag.web.view.simplePoint_tag.doTag(simplePoint_tag.java:103)
                          at org.apache.jsp.testCustom_jsp._jspx_meth_view_005fsimplePoint_005f0(testCustom_jsp.java:176)
                          at org.apache.jsp.testCustom_jsp._jspService(testCustom_jsp.java:109)
                          ... 18 more
                  The important part was Point with XID 'DS_337334' not found.
                  • S
                    sprokkie
                    this is my log file
                    Stacktrace:
                    at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:859)
                    at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:574)
                    at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1527)
                    at org.apache.jsp.costumview_jsp._jspService(costumview_jsp.java:142)
                    ... 15 more
                    at org.apache.jsp.costumview_jsp._jspx_meth_view_005fsimplePoint_005f0(costumview_jsp.java:176)
                    at org.apache.jsp.costumview_jsp._jspService(costumview_jsp.java:109)
                    ... 18 more
                    XID DS_337334 is a valid XID
                    I looked it up and checked it 3 times
                    I changed it for another xid even copy the original datasource to get a new xid.
                    for some reason the xid are not recognized.
                    • M
                      The "DS" part concerns me. Are you sure you're not referencing a data source rather than a data point?
                      • S
                        sprokkie
                        i use the name in the xid box
                        see image
                        • M
                          That's a data source, Sprokkie, not a data point. Note that you are in a "data source" editing page, and there is a list of "points" at the bottom (that box with the big title that says "Points"). When the error message says that it can't find the "data point", you can assume it's probably trying to match against a data point.
                          • S
                            sprokkie
                            that did the trick. thx
                            I located the datapoint it starts wit DP :)
                            Now it works.
                            now i need to find a way to use this on a remote server
                            • M
                              Ok, good.
                              Just a general note that XIDs for data sources only start with "DS" by default (and the same with "DP" and data points). They can otherwise have any value as long as it is unique.
