    Change a data point with condition
    2 Posts 2 Posters 4.5k Views 2 Watching
    • T Offline
      tungthanh500
      Hello guys, I have a system and I want to control a data point with condition.
      I have following data point, polled through modbus TCP every 15 seconds:
      • Grid THDi L1, L2 and L3
      • Compensation Ratio
      • THDi setpoint (I set as 10)
      I want to make a Meta Data Point with following code:
      maxTHDI = Math.max(thdi_l1.value, thdi_l2.value, thdi_l3.value);
      if (maxTHDI < (setpoint.value - 1)) {
          comp_ratio.set(comp_ratio.value - 0.01);
      } else if (maxTHDI > setpoint.value) {
          if (comp_ratio >0.95) {
              comp_ratio.set(1)}
          else {
              comp_ratio.set (comp_ratio.value + 0.05);
      RuntimeManager.sleep(15000);
      My intention is:
      • If the value of maxTHDi is lower than 9, then i lower the value of comp_ratio by 0.01.
      • if the value of maxTHDi is above 10 then if comp_ratio > 0.95 then comp_ratio = 1 and if comp_ratio is lower 0.95, i will increase comp_ratio by 0.05.
      I want to make this meta point run every 15 second, together with the polling of Modbus data point. However, every time I enable this meta point this kind of error appear in the logs and repeat lots of times:
      INFO  2024-07-19T19:32:26,312 (com.serotonin.m2m2.rt.RuntimeManagerImpl.startDataSource:346) - Data source (name=Setpoint Controller, id=13, type=MetaDataSourceRT) took 12ms to start
      WARN  2024-07-19T19:34:54,511 (com.infiniteautomation.mango.rest.latest.websocket.pointValue.PointValueWebSocketHandler$PointValueWebSocketListener.pointUpdated:253) - Error sending websocket message
      com.infiniteautomation.mango.rest.latest.websocket.WebSocketClosedException: Websocket closed
      	at com.infiniteautomation.mango.rest.latest.websocket.MangoWebSocketHandler.sendStringMessageAsync(MangoWebSocketHandler.java:121) ~[?:?]
      	at com.infiniteautomation.mango.rest.latest.websocket.MangoWebSocketHandler.sendMessage(MangoWebSocketHandler.java:96) ~[?:?]
      	at com.infiniteautomation.mango.rest.latest.websocket.pointValue.PointValueWebSocketHandler.sendMessage(PointValueWebSocketHandler.java:154) ~[?:?]
      	at com.infiniteautomation.mango.rest.latest.websocket.pointValue.PointValueWebSocketHandler$PointValueWebSocketListener.sendNotification(PointValueWebSocketHandler.java:200) ~[?:?]
      	at com.infiniteautomation.mango.rest.latest.websocket.pointValue.PointValueWebSocketHandler$PointValueWebSocketListener.pointUpdated(PointValueWebSocketHandler.java:250) ~[?:?]
      	at com.serotonin.m2m2.rt.DataPointEventNotifyWorkItem.execute(DataPointEventNotifyWorkItem.java:64) ~[mango-5.1.4.jar:?]
      	at com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl$RejectableWorkItemRunnable.run(BackgroundProcessingImpl.java:531) ~[mango-5.1.4.jar:?]
      	at com.serotonin.timer.Task.runTask(Task.java:176) ~[mango-5.1.4.jar:?]
      	at com.serotonin.timer.TaskWrapper.run(TaskWrapper.java:22) ~[mango-5.1.4.jar:?]
      	at com.serotonin.timer.OrderedThreadPoolExecutor$OrderedTaskCollection.run(OrderedThreadPoolExecutor.java:268) ~[mango-5.1.4.jar:?]
      	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
      	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
      	at java.lang.Thread.run(Thread.java:840) [?:?]
      Please suggest me some workaround.
      Thank you
        MattFox @tungthanh500
        @tungthanh500 get rid of the runtime sleep call. Set the context point related to the data point you are validating and set the script to trigger from one of them for a start.
        Alternatively use a cron timer setting set to 15 seconds.
