    Mango 5: Reorganize the default menu into our own structure
    4 Posts 2 Posters 1.3k Views 2 Watching
      ms_brunette
      Hello, users and developers (hope) of Mango 5,
      We are about to start using Mango 5, and its new redesigned menu is very uncomfortable for us. We have own structure of our pages and want to have all non-users menu inside only one admin folder, but I can't found how to reorganize default tree of folders. It is very huge and we don't need big part of them.
      Maybe there is a way to get menu view as it was in Mango 3, and I just don't see it?
      • G Offline
        greychrist @ms_brunette
        @ms_brunette
        Hello there. I can try to help you. The Platform Management -> Edit Menu screen allows you to hide/show any menu items you would like. It also allows you to create new menu items and links. So you could create a new folder (top level menu item), then under that, create only the links you want to present to your users.
        The trick to this is to create each link as a type External Link, then provide the path to the desired page in this format:
        /ui/platform-management/edit-menu
        That example would give you a link that would bring users to the edit menu page. The link must contain the whole path after your base url, so everything after the first slash (/). Choose the option 'Same window' for this external link and it will work exactly the same as the existing link under Platform Management. You can give it whatever name and icon you want, but it's probably best to stick to what your users already know. You can place these links at the root of the menu or under a top-level menu item or folder.
        If you want to create a top-level menu item (folder) to contain your links, under Link to content, choose the Show menu item as a folder checkbox and select the No content radio button.
        Be sure to click the Save button on the main menu editor screen after each individual change to be sure the edit takes and the new folder/links show up on the menu. The menu should show the changes immediately.
        I hope that helps!
        M 1 Reply Last reply Reply Quote 2
          ms_brunette @greychrist
          @greychrist Thank you for the advice. It isn't exactly what I wanted but it works. Thanks again!
          • G Offline
            @ms_brunette Glad I could be of some help! Have a great day!
