    Change Bar Display bar-color based on point value
    10 Posts 4 Posters 6.0k Views 4 Watching
    • T Offline
      tomatopi
      I'm trying to create a bar display of a point value, but I wanted the bar-color to be dependent on the value of the point.
      I tried ng-style={color:...}, but that changed the text color along with the bar color making the text illegible.
      I tried to put the same logic into bar-colour, but it didn't work.
      I'm still trying to learn more about components, but I find it confusing since many documents are based on v3 or older. Duplicating the logic in the built-in bar display but with the color change and different defaults built in would be ideal, but I can't seem to wrap my brain around making it work. I created the userModule based on the tutorial, but that's as far as I got.
        MattFox @tomatopi
        @tomatopi this is likely your best shot, but because they're using amcharts 3 you can't do what you want natively. https://stackoverflow.com/a/35995962
        You'd basically be having to write a modified version of the serialChart directive just so you have this function.
        • T Offline
          tomatopi @MattFox
          @MattFox Well, dang, that's far more involved than I expected.
          I'm trying to find the best way to display moisture levels that's easy to glance at (since there will be near 100 of them). I want four colours to represent moisture content. Red (too dry), Orange (getting dry), Green (ideal), and Blue (over wet). Similar to a bar display or a tank or VU meter or something. I may fall back to a gauge display and have the third band end early so blue becomes blank.
          I don't think I'm far enough into Mango/amcharts to write a modified serialChart directive.
          MattFoxM joeamiragliaJ 2 Replies Last reply Reply Quote 0
            MattFox @tomatopi
            @tomatopi a VU meter sounds like a good component to make... I think I'll give it a go..
            • joeamiragliaJ Offline
              joeamiraglia @tomatopi
              @tomatopi Would this work for you?
              https://www.amcharts.com/demos-v3/bullet-chart-v3/
              • T Offline
                tomatopi @joeamiraglia
                @joeamiraglia That could very well do the trick. It would be similar to a VU meter, I think.
                Is there any examples of how to implement that? A forum search led me to one thread, but it didn't really show a working example.
                  CraigWeb @tomatopi
                  @tomatopi
                  Here is a example of a built in bardisplay:
                  <ma-get-point-value point="myPoint" point-xid="DP_bartest"></ma-get-point-value>
                  <ma-bar-display style="height: 100px; width: 40px; background-color:#a5a5a5"  bar-color="{{myPoint.value <10 ? 'red' : myPoint.value <20 ? 'orange': 'green'}}" point="myPoint" minimum="0" maximum="100" direction="bottom-to-top"></ma-bar-display>
                  You can use javascript ternary operators to decide on the color of the bar, you can also chain ternary operators to have 3 diff
                  T 2 Replies Last reply Reply Quote 0
                  • T Offline
                    tomatopi @CraigWeb
                    @CraigWeb I tried that before and it didn't work. I tried again and now it is working.
                    Probably a syntax error on my part. I may have used { ... } instead of {{ ... }} for the logic replicating what was in ng-style.
                    The learning curve is a little steep. Most searches for AngularJS comes back newer Angular information, or links on the forum are often broken or redirect to something newer. What programming I do is more server-side and not Java based so it's a little frustrating. It's nice to see more activity here now. Most definitely a help.
                    Thanks!
                    • T Offline
                      tomatopi @CraigWeb
                      @CraigWeb I was trying this again and it couldn't get it to work, but I found the issue.
                      I used point="1water" and got a console error:
                      Token 'water' is unexpected token at column 2 of the expression [1water] starting at [water].
                      If I used point="water1", then it works. So if the first character of a point variable is a number, it barfs. I'm curious why that is? Is it documented anywhere? Seems a pretty important gotcha.
                        CraigWeb @tomatopi
                        @tomatopi
                        point="water"
                        This code is assigning the point-value object to a variable in the local scope called water. Since we are working in javascript, variables must be valid javascript variables.
