    /data-sources API - Limits results to 100 items
    User help
    2
    4
    913
    • cmusselmC
      cmusselm
      When running the /data-sources GET via the API the total reports the actual number of data sources we have, but the items array is limited to 100 data sources.
      Is there a "limit" parameter or paging option that I'm missing?
      How can I get all of the data sources returned to me via the API?
      Chad
      • MattFoxM
        Yes, limit is set to 100 by default. Same goes for datapoints. Try limit=-1 as a parameter. I believe will tell it to pull all.
        Use swagger to test your api calls.
        • cmusselmC
          cmusselm
          Thanks once again, Fox, for the help!
          It took us a little bit to figure out the syntax, but got it working: /rest/v2/data-sources?limit(1000)
          We tried to use -1, but that created a 500 error.
          Could not write JSON: PreparedStatementCallback; bad SQL grammar [select `ds`.`id`, `ds`.`xid`, `ds`.`name`, `ds`.`dataSourceType`, `ds`.`data`, `ds`.`editPermission` from dataSources AS ds limit ?]
          Not a big deal for our purposes though.
          • MattFoxM
            Bizarre, help docs used to mention using -1 as no limit. Glad you have got it sorted!
