    Point variable use index
    User help
    2
    8
    1.2k
    • seanS
      sean
      when I have maybe 10 datapoint's xid like "DP_c01_temperature" "DP_c02_temperature" ... "DP_c10_temperature"
      I want use ng-repeat to get 1 to 10 index code like this
      <div ng-repeat="x in [].constructor(10) track by index">
        <ma-get-point-value point-xid="DP_c{{index}}_temperature" point="c{{index}}_temperature"></ma-get-point-value>
        <div class="value">C{{index}} Temperature: <span ng-bind="c{{index}}_temperature.value"></span></div>
      but point in console Error: [$parse:syntax] Syntax Error: Token '{' is an unexpected token at column 4 of the expression [c{{index}}_temperature] starting at [{{index}}_temperature].
      How can I fix it ?
      • MattFoxM
        @sean said in Point variable use index:
        Right idea, wrong execution:
        You cannot make a point variable from a text string.
        Use an object on init. Assuming your constructor generates a list of integers...
        <div ng-init="pts={}"><!-- create storage object for point items -->
        <div ng-repeat="idx in [0,1,2,3,4,5,6,7,8,9,10] track by $index">
          <ma-get-point-value point-xid="DP_c{{idx}}_temperature" point="pts['c'+idx+'_temperature']"></ma-get-point-value><!-- Initialist object index-->
          <div class="value">C{{idx}} Temperature: <span ng-bind="pts['c{{idx}}_temperature'].value"></span><!-- Bind from established index --></div>
        • seanS
          sean
          Thank you ! for It working
          • MattFoxM
            Anytime!
            • seanS
              sean
              I got new idea
              use component
                app.component("pointCom", {
                  bindings: {
                        point: "<",
                        qty: "@",
                        min: "@",
                        max: "@"
                      controller: dataController,
                      controllerAs: "dc",
                      template:`
                      <span>Render</span>
                      <div ng-bind-html="dc.sour">
                    dataController.$inject = ["$scope"]
                    function dataController($scope){
                        let dc = this
                        let P = dc.point
                        let Q = dc.qty
                        let min = dc.min
                        let max = dc.max
                        let num = 0
                        this.$onChanges = function() {
                            let p = dc.point
                            dc.sour = ''
                            max = dc.max
                            num = dc.min
                            console.log(school)
                            if (max !== undefined){
                                Q = max
                            } else {
                                Q = dc.qty
                            if (p !== undefined){
                                for (let i=0; i < Q; i++){
                                num = Number(num)
                                num = num.pad(3)
                                dc.sour += `
                                <ma-get-point-value point-xid="DP_${num}_Meter_kWh" point="c${num}_Meter_kWh"></ma-get-point-value>
                                <ma-get-point-value point-xid="DP_${num}_Meter_V" point="c${num}_Meter_V"></ma-get-point-value>
                                <ma-get-point-value point-xid="DP_${num}_Meter_A" point="c${num}_Meter_A"></ma-get-point-value>
                                num++
                              console.log(dc.sour)
                              angular.element(dc.sour)
                          Number.prototype.pad = function(size) {
                          	let s = String(this)
                          	while (s.length < (size || 2)) {s = "0" + s;}
                          	return s
              but in the html dom
              <ma-get-point-value> just dispear like this pic
              how do I fix it?
              in console.log can see dc.sour
              <ma-get-point-value point-xid="DP_001_Meter_kWh" point="c001_Meter_kWh"></ma-get-point-value>
                                <ma-get-point-value point-xid="DP_001_Meter_V" point="c001_Meter_V"></ma-get-point-value>
                                <ma-get-point-value point-xid="DP_001_Meter_A" point="c001_Meter_A"></ma-get-point-value>
              • MattFoxM
                Angularjs doesnt let you output html through a variable. That is what templates are for. You need to tell the controller that the html string is valid and needs to be outputted as part of the template.
                https://benohead.com/blog/2015/04/21/angularjs-binding-html-code-with-ng-bind-html-and-sce-trustashtml/
                Use $sce.trustAsHtml with your html inside the brackets.
                Be sure to inject $sce into your controller.
                • seanS
                  sean
                  thank you
                  use $sce can show inside component
                  but can't use bind {{c001_Meter_kWh.value}} in other side to see value
                  how to fix it?
                  • MattFoxM
                    You are over complicating it.
                    Use what I wrote originally as your template and rather than adding html and trying to make angular js evaluate it. $sce is for outputting html, not another directive. I should have looked more closely at what you are doing....
                    increment a counter then make it ng-repeat n times depending on how big your number value is.
                        bindings: {
                              point: "<",
                              qty: "@",
                              min: "@",
                              max: "@"
                            controllerAs: "dc",
                            template:`
                            <span>Render</span>
                           <div ng-repeat="idx in dc.sour track by $index">
                            <ma-get-point-value point-xid="DP_{{idx}}_Meter_kWh" point="dc.pts['c'+idx+'_Meter_kWh']"></ma-get-point-value>
                            <ma-get-point-value point-xid="DP_{{idx}}_Meter_V" point="dc.pts['c'+idx+'_Meter_V']"></ma-get-point-value>
                            <ma-get-point-value point-xid="DP_{{idx}}_Meter_A" point="dc.pts['c'+idx+'_Meter_A']"></ma-get-point-value>
                              let dc = this
                              let P = dc.point
                              let Q = dc.qty
                              let min = dc.min
                              let max = dc.max
                              let num = 0
                                  let p = dc.point
                                  dc.sour = []
                                  max = dc.max
                                  num = dc.min
                                  console.log(school)
                                      Q = max
                                  } else {
                                      Q = dc.qty
                                      num = Number(num)
                                      num = num.pad(3)
                                      dc.sour.push(num)
                                	return s
                    Try that and see how you go. Haven't tested this
