    Dashboard Designer - Edit Markup Issue with Font Awesome JS
    3 Posts 2 Posters 1.4k Views 2 Watching
    • cmusselmC Offline
      cmusselm
      I have several pages that use Font Awesome icons, and in those pages, I use the Font Awesome JS.
      <script src="https://kit.fontawesome.com/xxxxxxxx.js" crossorigin="anonymous"></script>
      It seems that this causes an issue with the Dashboard Designer's (and Edit pages) ability to view the markup for me to edit. When I go to Dashboard Designer and select a page with the Font Awesome JS, I can see the drag-and-drop page, but when I select Edit Markup the page is blank.
      Here is a quick screenshot of what I see:
      The console.log file has the following as the error:
      Error: Mismatched anonymous define() module: function(){"use strict";function t(e){return(t="function"==typeof Symbol&&"symbol"==typeof Symbol.iterator?function(t){return typeof t}:function(t){return t&&"function"==typeof Symbol&&t.constructor===Symbol&&t!==Symbol.prototype?"symbol":typeof t})(e)}function e(t,e,n){return e in t?Object.defineProperty(t,e,{value:n,enumerable:!0,configurable:!0,writable:!0}):t[e]=n,t}function n(t,e){var n=Object.keys(t);if(Object.getOwnPropertySymbols){var o=Object.getOwnPropertySymbols(t);e&&(o=o.filter((function(e){return Object.getOwnPropertyDescriptor(t,e).enumerable}))),n.push.apply(n,o)}return n}function o(t){for(var o=1;o<arguments.length;o++){var r=null!=arguments[o]?arguments[o]:{};o%2?n(Object(r),!0).forEach((function(n){e(t,n,r[n])})):Object.getOwnPropertyDescriptors?Object.defineProperties(t,Object.getOwnPropertyDescriptors(r)):n(Object(r)).forEach((function(e){Object.defineProperty(t,e,Object.getOwnPropertyDescriptor(r,e))}))}return t}function r(t,e){return function(t){if(Array.isArray(t))return t}(t)||function(t,e){if(!(Symbol.iterator in Object(t)||"[object Arguments]"===Object.prototype.toString.call(t)))return;var n=[],o=!0,r=!1,i=void 0;try{for(var c,a=t[Symbol.iterator]();!(o=(c=a.next()).done)&&(n.push(c.value),!e||n.length!==e);o=!0);}catch(t){r=!0,i=t}finally{try{o||null==a.return||a.return()}finally{if(r)throw i}}return n}(t,e)||function(){throw new TypeError("Invalid attempt to destructure non-iterable instance")}()}function i(t,e){var n=e&&e.addOn||"",o=e&&e.baseFilename||t.license+n,r=e&&e.minify?".min":"",i=e&&e.fileSuffix||t.method,c=e&&e.subdir||t.method;return t.baseUrl+"/releases/"+("latest"===t.version?"latest":"v".concat(t.version))+"/"+c+"/"+o+r+"."+i}function c(t,e){var n=e||["fa"],o="."+Array.prototype.join.call(n,",."),r=t.querySelectorAll(o);Array.prototype.forEach.call(r,(function(e){var n=e.getAttribute("title");e.setAttribute("aria-hidden","true");var o=!e.nextElementSibling||!e.nextElementSibling.classList.contains("sr-only");if(n&&o){var r=t.createElement("span");r.innerHTML=n,r.classList.add("sr-only"),e.parentNode.insertBefore(r,e.nextSibling)}}))}var a,u=function(){},f="undefined"!=typeof global&&void 0!==global.process&&"function"==typeof global.process.emit,s="undefined"==typeof setImmediate?setTimeout:setImmediate,d=[];function l(){for(var t=0;t<d.length;t++)d[t][0](d[t][1]);d=[],a=!1}function h(t,e){d.push([t,e]),a||(a=!0,s(l,0))}function m(t){var e=t.owner,n=e._state,o=e._data,r=t[n],i=t.then;if("function"==typeof r){n="fulfilled";try{o=r(o)}catch(t){b(i,t)}}p(i,o)||("fulfilled"===n&&v(i,o),"rejected"===n&&b(i,o))}function p(e,n){var o;try{if(e===n)throw new TypeError("A promises callback cannot return that same promise.");if(n&&("function"==typeof n||"object"===t(n))){var r=n.then;if("function"==typeof r)return r.call(n,(function(t){o||(o=!0,n===t?y(e,t):v(e,t))}),(function(t){o||(o=!0,b(e,t))})),!0}}catch(t){return o||b(e,t),!0}return!1}function v(t,e){t!==e&&p(t,e)||y(t,e)}function y(t,e){"pending"===t._state&&(t._state="settled",t._data=e,h(w,t))}function b(t,e){"pending"===t._state&&(t._state="settled",t._data=e,h(A,t))}function g(t){t._then=t._then.forEach(m)}function w(t){t._state="fulfilled",g(t)}function A(t){t._state="rejected",g(t),!t._handled&&f&&global.process.emit("unhandledRejection",t._data,t)}function O(t){global.process.emit("rejectionHandled",t)}function j(t){if("function"!=typeof t)throw new TypeError("Promise resolver "+t+" is not a function");if(this instanceof j==!1)throw new TypeError("Failed to construct 'Promise': Please use the 'new' operator, this object constructor cannot be called as a function.");this._then=[],function(t,e){function n(t){b(e,t)}try{t((function(t){v(e,t)}),n)}catch(t){n(t)}}(t,this)}j.prototype={constructor:j,_state:"pending",_then:null,_data:void 0,_handled:!1,then:function(t,e){var n={owner:this,then:new this.constructor(u),fulfilled:t,rejected:e};return!e&&!t||this._handled||(this._handled=!0,"rejected"===this._state&&f&&h(O,this)),"fulfilled"===this._state||"rejected"===this._state?h(m,n):this._then.push(n),n.then},catch:function(t){return this.then(null,t)}},j.all=function(t){if(!Array.isArray(t))throw new TypeError("You must pass an array to Promise.all().");return new j((function(e,n){var o=[],r=0;function i(t){return r++,function(n){o[t]=n,--r||e(o)}}for(var c,a=0;a<t.length;a++)(c=t[a])&&"function"==typeof c.then?c.then(i(a),n):o[a]=c;r||e(o)}))},j.race=function(t){if(!Array.isArray(t))throw new TypeError("You must pass an array to Promise.race().");return new j((function(e,n){for(var o,r=0;r<t.length;r++)(o=t[r])&&"function"==typeof o.then?o.then(e,n):e(o)}))},j.resolve=function(e){return e&&"object"===t(e)&&e.constructor===j?e:new j((function(t){t(e)}))},j.reject=function(t){return new j((function(e,n){n(t)}))};var S="function"==typeof Promise?Promise:j;function E(t,n){var o=n.fetch,r=n.XMLHttpRequest,i=n.token;return new S((function(n,c){if("function"==typeof o)o(t,{mode:"cors",cache:"default",headers:new Headers(e({},"fa-kit-token",i))}).then((function(t){if(t.ok)return t.text();throw new Error("")})).then((function(t){n(t)})).catch(c);else if("function"==typeof r){var a=new r;a.addEventListener("loadend",(function(){this.responseText?n(this.responseText):c(new Error(""))}));["abort","error","timeout"].map((function(t){a.addEventListener(t,(function(){c(new Error(""))}))})),a.open("GET",t),a.setRequestHeader("fa-kit-token",i),a.send()}else{c(new Error(""))}}))}function _(t,e){var n=arguments.length>2&&void 0!==arguments[2]?arguments[2]:function(){},r=e.document||r,a=c.bind(c,r,["fa","fab","fas","far","fal","fad","fak"]);t.autoA11y.enabled&&n(a);var u=[{id:"fa-main",addOn:void 0}];t.v4shim.enabled&&u.push({id:"fa-v4-shims",addOn:"-v4-shims"}),t.v4FontFaceShim.enabled&&u.push({id:"fa-v4-font-face",addOn:"-v4-font-face"});var f=u.map((function(n){return new S((function(r,c){E(i(t,{addOn:n.addOn,minify:t.minify.enabled}),e).then((function(i){r(P(i,o({},e,{baseUrl:t.baseUrl,version:t.version,id:n.id})))})).catch(c)}))}));return S.all(f)}function P(t,e){var n=document.createElement("style"),o=document.createTextNode(function(t,e,n){var o=t;return[[/(url\("?)\.\.\/\.\.\/\.\./g,function(t,n){return"".concat(n).concat(e)}],[/(url\("?)\.\.\/webfonts/g,function(t,o){return"".concat(o).concat(e,"/releases/v").concat(n,"/webfonts")}],[/(url\("?)https:\/\/kit-free([^.])*\.fontawesome\.com/g,function(t,n){return"".concat(n).concat(e)}]].forEach((function(t){var e=r(t,2),n=e[0],i=e[1];o=o.replace(n,i)})),o}(t,e.baseUrl,e.version));return n.appendChild(o),n.media="all",e.id&&n.setAttribute("id",e.id),e&&e.detectingConflicts&&e.detectionIgnoreAttr&&n.setAttributeNode(document.createAttribute(e.detectionIgnoreAttr)),n}function F(t,e){e.autoA11y=t.autoA11y.enabled,"pro"===t.license&&(e.autoFetchSvg=!0,e.fetchSvgFrom=t.baseUrl+"/releases/"+("latest"===t.version?"latest":"v".concat(t.version))+"/svgs",e.fetchUploadedSvgFrom=t.uploadsUrl);var n=[];return t.v4shim.enabled&&n.push(new S((function(n,r){E(i(t,{addOn:"-v4-shims",minify:t.minify.enabled}),e).then((function(t){n(C(t,o({},e,{id:"fa-v4-shims"})))})).catch(r)}))),n.push(new S((function(n,r){E(i(t,{minify:t.minify.enabled}),e).then((function(t){var r=C(t,o({},e,{id:"fa-main"}));n(function(t,e){var n=e&&void 0!==e.autoFetchSvg?e.autoFetchSvg:void 0,o=e&&void 0!==e.autoA11y?e.autoA11y:void 0;void 0!==o&&t.setAttribute("data-auto-a11y",o?"true":"false");n&&(t.setAttributeNode(document.createAttribute("data-auto-fetch-svg")),t.setAttribute("data-fetch-svg-from",e.fetchSvgFrom),t.setAttribute("data-fetch-uploaded-svg-from",e.fetchUploadedSvgFrom));return t}(r,e))})).catch(r)}))),S.all(n)}function C(t,e){var n=document.createElement("SCRIPT"),o=document.createTextNode(t);return n.appendChild(o),n.referrerPolicy="strict-origin",e.id&&n.setAttribute("id",e.id),e&&e.detectingConflicts&&e.detectionIgnoreAttr&&n.setAttributeNode(document.createAttribute(e.detectionIgnoreAttr)),n}function T(t){var e,n=[],o=document,r=o.documentElement.doScroll,i=(r?/^loaded|^c/:/^loaded|^i|^c/).test(o.readyState);i||o.addEventListener("DOMContentLoaded",e=function(){for(o.removeEventListener("DOMContentLoaded",e),i=1;e=n.shift();)e()}),i?setTimeout(t,0):n.push(t)}function L(t){"undefined"!=typeof MutationObserver&&new MutationObserver(t).observe(document,{childList:!0,subtree:!0})}try{if(window.FontAwesomeKitConfig){var k=window.FontAwesomeKitConfig,I={detectingConflicts:k.detectConflictsUntil&&new Date<=new Date(k.detectConflictsUntil),detectionIgnoreAttr:"data-fa-detection-ignore",fetch:window.fetch,token:k.token,XMLHttpRequest:window.XMLHttpRequest,document:document},x=document.currentScript?document.currentScript.parentElement:document.head,U=document.currentScript;(function(){var t=arguments.length>0&&void 0!==arguments[0]?arguments[0]:{},e=arguments.length>1&&void 0!==arguments[1]?arguments[1]:{};return"js"===t.method?F(t,e):"css"===t.method?_(t,e,(function(t){T(t),L(t)})):void 0})(k,I).then((function(t){t.map((function(t){return x.appendChild(t)})),I.detectingConflicts&&U&&T((function(){U.setAttributeNode(document.createAttribute(I.detectionIgnoreAttr));var t=function(t,e){var n=document.createElement("script");return e&&e.detectionIgnoreAttr&&n.setAttributeNode(document.createAttribute(e.detectionIgnoreAttr)),n.src=i(t,{baseFilename:"conflict-detection",fileSuffix:"js",subdir:"js",minify:t.minify.enabled}),n}(k,I);document.body.appendChild(t)}))})).catch((function(t){console.error("".concat("Font Awesome Kit:"," ").concat(t))}))}}catch(t){console.error("".concat("Font Awesome Kit:"," ").concat(t))}}
      https://requirejs.org/docs/errors.html#mismatch
          at makeError (mangoUi~ngMango~ngMangoServices.js?v=dabd43089c611fb19315:39)
          at N (mangoUi~ngMango~ngMangoServices.js?v=dabd43089c611fb19315:39)
          at Object.a [as require] (mangoUi~ngMango~ngMangoServices.js?v=dabd43089c611fb19315:39)
          at requirejs (mangoUi~ngMango~ngMangoServices.js?v=dabd43089c611fb19315:39)
          at Object.<anonymous> (ace.js?v=65d5f761bca28aff5279:1)
          at Object.2662 (ace.js?v=65d5f761bca28aff5279:1)
          at r (mangoUi.js?v=9ec746427836df6d66ea:1)
          at Module.2746 (ace.js?v=65d5f761bca28aff5279:1)
          at async Promise.all (index 0)
      The work-around to this is to
      1. In Dashboard designer select a page to edit that does not use Font Awesome
      2. Refresh the page
      3. View Edit Markup (It will display the markup now)
      4. Select a page with the Font Awesome JS and I can now edit the markup
      Not sure if this was already documented at all, or if there is a plan to fix the issue.
      Chad
        As far as I know, fontawesome and material icons are already included in Mango and there is no need for the script. All the icons you see in mango are from either font awesome or material icons.
        • cmusselmC Offline
          cmusselm
          Thanks, Craig, for the info. I've removed the Font Awesome JS reference and can still see the icons, so that's good.
          The bad news is that I still get the error posted in my initial post. Not sure what's causing it now. The only thing I thought each page with the error had in common was using Font Awesome, but it must be something else. I even removed all references to Font Awesome and still got an error.
          I have a work-around, so it's not the end of the world, just a little annoying.
          Chad
