    Meta Data Point does not work with two context points
    4 Posts 2 Posters 2.4k Views 1 Watching
      jvaughters
      I will start with a simple explanation and add any further detail if needed. I have a Meta Data Source with a point that calculates a very simple difference between two context data points. The script validates during the set up, but the point does not calculate when saved. It works fine if I only use one data point context and a hard number but not two context data points. It does not matter from what other data sources I use, it always fails with two context points. I can have both checked for context, or just one, but still no go. The naming is fine or it wouldn't validate. So I am at a loss with this very simple point.
      Any ideas?
      Any further info needed?
      Thanks in advance.
      PS - I also searched this forum for anything, and did not find much.
      Version is 3.7.x with all updates completed a few days ago.
        If you can share your script and a JSON export of your Data Point that would be the first step to find out what other questions there might be.
          jvaughters
          Here is the json.
          "dataPoints":[
          "xid":"DP_0f1ff7a5-96bf-4daa-a8a6-fe14e1afaab4",
          "name":"Delta Upstairs Attic",
          "enabled":true,
          "loggingType":"INTERVAL",
          "purgeType":"YEARS",
          "pointLocator":{
          "dataType":"NUMERIC",
          "updateEvent":"NONE",
          "contextUpdateEvent":"CONTEXT_UPDATE",
          "context":[
          "varName":"p59",
          "dataPointXid":"DP_937c0338-c38c-45cb-9167-b5fec4e5ce81",
          "updateContext":true
          "varName":"p58",
          "dataPointXid":"DP_a79ff828-72d6-480a-b2fc-6df058f76707",
          "updateContext":false
          "logLevel":"NONE",
          "variableName":"delta_upstairs_attic",
          "scriptPermissions":[
          "superadmin"
          "executionDelaySeconds":0,
          "logCount":5,
          "logSize":1.0,
          "script":"var tempvar1 = p59.value;\nvar tempvar2 = p58.value;\nreturn tempvar1 - tempvar2;",
          "settable":false,
          "updateCronPattern":""
          "eventDetectors":[
          "plotType":"SPLINE",
          "rollup":"NONE",
          "unit":"",
          "simplifyType":"NONE",
          "chartColour":"",
          "chartRenderer":{
          "type":"IMAGE",
          "timePeriodType":"DAYS",
          "numberOfPeriods":1
          "dataSourceXid":"DS_4ddc2b19-9bce-44f9-bf79-812775e6a2da",
          "defaultCacheSize":1,
          "deviceName":"Calcs",
          "discardExtremeValues":true,
          "discardHighLimit":200.0,
          "discardLowLimit":40.0,
          "intervalLoggingPeriod":1,
          "purgeOverride":false,
          "purgePeriod":1,
          "readPermission":"superadmin, user",
          "setPermission":"superadmin, user",
          "tags":{
          "textRenderer":{
          "type":"ANALOG",
          "useUnitAsSuffix":false,
          "suffix":"",
          "format":"0.00"
          "tolerance":0.0
            jvaughters
            Joel,
            I am embarrassed, but you helped me find it with the json. I did not realize I had limits set on the discard values. I new it was something simple. Problem solved. I must have copied this point.
