Installation Failure. Need Help
I followed the instructions exactly even loading JDK 8 and changing the port from 8080 and I stops while setting up the database at 40%.
Below is the image of the error:
Version 3.6 and upwards requires the use of open JDK for starters I believe.
https://help.infiniteautomation.com/installing-java
Check out the recommended install instructions and see how you goFox
@davidmarch
exact same problem i have encountered post upgrade. Same problem with either Oracle or the OpenJDK.
See my previous thread:link text. I have put this aside now until I have got more than to investigate.
Hope you have better luck. -
Thanks. I just noticed the OpenJDK. The other documentation and videos had it as Oracle Version 8. I assumed I was ok, since it was not a commercial application. I will try the open.
Dave -
I tried the openJDK and loaded its destination into the environmental variables. No luck. Still same error
I downloaded the Mango Commercial Enterprise Evaluation version and the installation worked fine. Must have something to do with the Free download. The Commercial Enterprise Evaluation, says its the free version.
@davidmarch
good find. -
Enterprise has all the modules rather than the bare minimum. That would explain a lot.
