<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Installation Failure. Need Help]]></title><description><![CDATA[<p dir="auto">I followed the instructions exactly even loading JDK 8 and changing the port from 8080 and I stops while setting up the database at 40%.<br />
Below is the image of the error:<br />
<img src="https://camo.nodebb.org/fe6ed742edda9cc0a8ef5e5d511bd0059e043445?url=https%3A%2F%2Fi.imgur.com%2Fncfe4gE.png" alt="0_1589116133264_50074393-495d-41c2-9b88-80a9056335cc-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/topic/4798/installation-failure-need-help</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 04:30:26 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4798.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 May 2020 12:48:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Installation Failure. Need Help on Mon, 11 May 2020 01:03:15 GMT]]></title><description><![CDATA[<p dir="auto">Enterprise has all the modules rather than the bare minimum. That would explain a lot.</p>
]]></description><link>https://forum.mango-os.com/post/25168</link><guid isPermaLink="true">https://forum.mango-os.com/post/25168</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Mon, 11 May 2020 01:03:15 GMT</pubDate></item><item><title><![CDATA[Reply to Installation Failure. Need Help on Mon, 11 May 2020 01:02:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidmarch" aria-label="Profile: davidmarch">@<bdi>davidmarch</bdi></a><br />
good find.</p>
]]></description><link>https://forum.mango-os.com/post/25167</link><guid isPermaLink="true">https://forum.mango-os.com/post/25167</guid><dc:creator><![CDATA[cwangv]]></dc:creator><pubDate>Mon, 11 May 2020 01:02:54 GMT</pubDate></item><item><title><![CDATA[Reply to Installation Failure. Need Help on Mon, 11 May 2020 00:59:24 GMT]]></title><description><![CDATA[<p dir="auto">I downloaded the Mango Commercial Enterprise Evaluation version and the installation worked fine. Must have something to do with the Free download. The Commercial Enterprise Evaluation, says its the free version.</p>
]]></description><link>https://forum.mango-os.com/post/25166</link><guid isPermaLink="true">https://forum.mango-os.com/post/25166</guid><dc:creator><![CDATA[davidmarch]]></dc:creator><pubDate>Mon, 11 May 2020 00:59:24 GMT</pubDate></item><item><title><![CDATA[Reply to Installation Failure. Need Help on Mon, 11 May 2020 00:12:15 GMT]]></title><description><![CDATA[<p dir="auto">I tried the openJDK and loaded its destination into the environmental variables. No luck. Still same error</p>
]]></description><link>https://forum.mango-os.com/post/25165</link><guid isPermaLink="true">https://forum.mango-os.com/post/25165</guid><dc:creator><![CDATA[davidmarch]]></dc:creator><pubDate>Mon, 11 May 2020 00:12:15 GMT</pubDate></item><item><title><![CDATA[Reply to Installation Failure. Need Help on Sun, 10 May 2020 23:39:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I just noticed the OpenJDK. The other documentation and videos had it as Oracle Version 8. I assumed I was ok, since it was not a commercial application. I will try the open.<br />
Dave</p>
]]></description><link>https://forum.mango-os.com/post/25164</link><guid isPermaLink="true">https://forum.mango-os.com/post/25164</guid><dc:creator><![CDATA[davidmarch]]></dc:creator><pubDate>Sun, 10 May 2020 23:39:06 GMT</pubDate></item><item><title><![CDATA[Reply to Installation Failure. Need Help on Sun, 10 May 2020 21:40:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidmarch" aria-label="Profile: davidmarch">@<bdi>davidmarch</bdi></a><br />
exact same problem i have encountered post upgrade. Same problem with either Oracle or the OpenJDK.<br />
See my previous thread:<a href="https://forum.infiniteautomation.com/topic/4791/upgrade-from-3-6-5-to-3-7-failed-on-windows-10-pro" rel="nofollow ugc">link text</a>. I have put this aside now until I have got more than to investigate.<br />
Hope you have better luck.</p>
]]></description><link>https://forum.mango-os.com/post/25163</link><guid isPermaLink="true">https://forum.mango-os.com/post/25163</guid><dc:creator><![CDATA[cwangv]]></dc:creator><pubDate>Sun, 10 May 2020 21:40:48 GMT</pubDate></item><item><title><![CDATA[Reply to Installation Failure. Need Help on Sun, 10 May 2020 19:27:03 GMT]]></title><description><![CDATA[<p dir="auto">Version 3.6 and upwards requires the use of open JDK for starters I believe.<br />
<a href="https://help.infiniteautomation.com/installing-java" rel="nofollow ugc">https://help.infiniteautomation.com/installing-java</a><br />
Check out the recommended install instructions and see how you go</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/25162</link><guid isPermaLink="true">https://forum.mango-os.com/post/25162</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Sun, 10 May 2020 19:27:03 GMT</pubDate></item></channel></rss>
